lda #NUMBER in three cycles?
vdub_bobby
Can someone tell me if there is a way to load A with an absolute value in three cycles instead of two?
I need to set A to zero and use three cycles, so right now I have a variable that is always set to zero, so I do this:
lda Zero ;+3
But it burns me up to waste a variable like this. Is there another way?
Hi there!
Can you post some more of the surrounding code?
Sure.
	ldx #BAND1HEIGHT;+2	72
jmp BeginBand1	;+3	75
;---Draw Second Band (Band1):
SkipDrawP0Band1
lda Zero  ;+3	63
bcc ReturnFromSkipDrawP0Band1;+3	66
LoopBand1
nop  ;+2	73
nop  ;+2	75
BeginBand1
sta GRP0	;+3  2
lda (P0DataColorPtr),Y;+5  7
sta COLUP0	;+3	10
dey  ;+2	12	decrement absolute scanline value by one here
sec  ;+2	14
;---Next 12 lines (machine cycles 15-50) draw an asymmetrical playfield---
lda PF0Data+1;+3	17
sta PF0	;+3	20	PF0 drawn to screen at machine cycle (MC) 22.7
lda PF1Data+1;+3	23
sta PF1	;+3	26	PF1 drawn to screen at MC 28
lda PF2Data+1;+3	29
sta PF2	;+3	32	PF2 drawn to screen at MC 38.7
lda PF3Data+1;+3	35
sta PF0	;+3	38	PF0 finished at MC 28, drawn to screen again at MC 49.3
lda PF4Data+1;+3	41
sta PF1	;+3	44	PF1 finished at MC 38, drawn to screen again at MC 54.7
lda PF5Data+1;+3	47
sta PF2	;+3	50	PF2 finished at MC 49.3, drawn to screen again at MC 65.3
;---End draw of asym playfield---
;------!!carry must be set!!---
tya  ;+2	52
sbc P0Top	;+3	55
adc #P0HEIGHT	;+2	57
bcc SkipDrawP0Band1;+2/3	59/60	Branch to SkipDraw must not cross page boundary.
lda (P0DataPtr),Y;+5	64
nop  ;+2	66	Draw at beginning of next line.
dex  ;+2	68
bne LoopBand1	;+2/3	70/71
;---Initialization between bands:
ldx #BAND2HEIGHT;+2	72
jmp BeginBand2	;+3	75
It isn't really "wasting" a variable, since I only need it to equal zero during the Kernel, so I could reuse it for something else when I'm not drawing the screen...but I'd still prefer not to use any RAM. This is one of 10 "bands" in my kernel - so my program is already pretty RAM-intensive (60 bytes for the playfield data).
Hi there!
Well, if you'd use the illegal opcade version of skipdraw, your problem would go away:
lda #C_P0_HEIGHT-1; 2
dcp P0_Y; 5 (DEC and CMP)
bcs .doDraw0; 2/3
lda #0; 2
.byte $2c;-1 (BIT ABS to skip next 2 bytes)
.doDraw0:
lda (P0_Ptr),y; 5
sta GRP0; 3 = 18 cycles (constant, if drawing or not!)
Greetings,
Manuel
