Sprite pixels disappearing on the left side of screen
xucaen
Hi, I'm still reading Andrew's tutorial and I'm sure I'll figure this out eventually. I'm certain it's a timing issue.. probably have some wsyncs in the wrong place.. But anyways, I'm only testing moving a sprite up, down, left and right. There is also a simple reflected playfield on the bottom 6 scanlines. When my sprite reaches the left side of the screen one of the top bits disappears, almost as is there is an invisible line doesn the side. I'm attaching two screen shots, the first shows what the screen looks like when it first starts up, the second shows when the sprite reaches the left side. I guess what I'm looking for are some possibilities for me to look at, I don't anyone to hand hold me.. not unless you really care. :D
Thanks!
Jim
Could be anything. Post the source for a diagnose.
Hi, I'm going to do more reading on sprites. I only got up to session 14 then skipped up to session 22, so I definately missed some important information. I cleaned it up the best I could, plus pulled out all my subroutine calls as soon as I learned that each one uses up 6 cycles to call, then 6 cycles to RTS. Yikes! Next I'm going to count the cycles and see if this is a timing issue which I think it is.
So, for anyone who may be interested here's my source. I appreciate any hints, but I'm not looking for a flat out answer.. that would take all the fun and learning out of it.
   processor 6502
   include vcs.h
   include macro.h
  ;set origin to the start of the 4k rom
    SEG
    ORG $F000
; vet up variables
YPosP0 = $80; first address in RAM
HeightP0 = $81
SpeedCounter = $83
ScanLineCount = $84
Reset
      ;Clear RAM and all TIA registers
       ldx #0
       lda #0
Clear   sta 0,x
       inx
       bne Clear
      ;total 9 bytes!
InitializeVariables
       lda #90
       sta YPosP0
       lda #186;we have 6 lines of playfield at the botton so
               ;192-6=186
       sta ScanLineCount
;EndInitializeVariables
StartOfFrame; Beginning of the game
; VerticalSync   ;top 3 scanlines
      ;using macro. this also stops vsync
       VERTICAL_SYNC
;VerticalBlank  ;37 scanlines
       ldx #37    ; 37 scanlines of vertical blank...
vblankloop
       sta WSYNC
       dex
       bne vblankloop
; check the joystick controls here
;MovePlayers
      ; for up and down, we INC or DEC
      ; the Y Position
; MoveDown
       LDA #%00010000 ;Down?
       BIT SWCHA
       BNE EndMoveDown
       LDA ScanLineCount
       CMP YPosP0
       BEQ ResetYDown
       INC YPosP0
       JMP EndMoveDown
ResetYDown
       LDA #11
       STA YPosP0
EndMoveDown
; MoveUp
       LDA #%00100000 ;Up?
       BIT SWCHA
       BNE EndMoveUp
       LDA #11
       CMP YPosP0
       BEQ ResetYUp
       DEC YPosP0
       JMP EndMoveUp
ResetYUp
       LDA ScanLineCount
       STA YPosP0
EndMoveUp
;assum horiz speed will be zero
   LDX #0
; MoveLeft
   LDA #%01000000 ;Left?
   BIT SWCHA
   BNE EndMoveLeft
   LDX #%00010000   ;a 1 in the left nibble means go left
;; moving left, so we need the mirror image
   LDA #%00001000  ;a 1 in D3 of REFP0 says make it mirror
   STA REFP0
EndMoveLeft
; MoveRight
   LDA #%10000000 ;Right?
   BIT SWCHA
   BNE EndMoveRight
   LDX #%11110000   ;a -1 in the left nibble means go right...
;; moving right, cancel any mirrorimage
   LDA #%00000000
   STA REFP0
EndMoveRight
   STX HMP0   ;set the move for player 0
  ;testing. trying to fix obstruction on left side of screen
   LDA WSYNC
;EndMovePlayers
       STX VBLANK
;EndVerticalBlank
;DrawScreen ;192 scanlines
      ;now you have 192 scanlines of picture
      ;remember, that's 160 clocks / 3 = 53 cpu cycles
;RestoreGraphics
       LDA #$00
       STA COLUBK ; Set Background to Black
       LDA #15*8
       STA COLUPF
       LDA #1
       sta CTRLPF
       lda #$1C
       sta COLUP0
       lda #%00000101
       sta NUSIZ0
;end restore graphics
;paint image here
       LDY #0
       STY HeightP0;init height to zero
       LDX ScanLineCount;192-6=186 because we have 6 lines of playfield to draw
       sta WSYNC
       STA HMOVE;set the sprite in motion
loop
       sta WSYNC
       LDA #0
       STA GRP0
       CPX YPosP0
       BNE SkipP0
       LDY #8
       STY HeightP0;if we are at the correct local, set the height
                      ;use this to determine if we should start
                      ;painting
SkipP0
       LDY HeightP0;put HeightP0 into Y for addressing
       BEQ FinishP0
IsP0
       LDA Player_0_up-1,Y;put a line of graphics into A
       STA GRP0; put the line of graphics into the graphics register
       DEC HeightP0; to decriment so we know when to stop
FinishP0;jump here if we are not painting
       DEX
       BNE loop
       LDA #0
       STA GRP0;turn off player graphics
       ldx #6
Draw_Picture_loop
       STA WSYNC
       LDA Playfield_PF0-1,X
       STA PF0
       sta PF1
       sta PF2
       DEX
       bne Draw_Picture_loop
       LDA #%01000010     ; Disable TIA Output
       STA VBLANK
;EndDrawScreen
OverScan
      ;now you have 30 scanlines of overscan
      ;(2280 machine cycles, 6840 color clocks
;initialize graphics
       LDA     #$00   ; put $00 in A
       STA WSYNC
       STA     PF0; clear out first playfield section
       STA     PF1; clear out second playfield section
       STA     PF2; clear out third playfield section
       STA     GRP0   ; clear out player graphic 0
       STA     GRP1   ; clear out player graphic 1
       STA     ENAM0  ; clear out missile 0
       STA     ENAM1  ; clear out missile 1
       STA     ENABL  ; clear out ball
       STA     COLUP0 ; set player 0 to black
       STA     COLUP1 ; set player 1 to black
       STA     COLUPF ; set playfield to black
       STA     COLUBK ; set background to black
;end initialize graphics
       LDX #29
       LDA #2
O1
       STA WSYNC
       DEX
       BNE O1
;EndOverScan
;go back to the beginning:
;inifinate loop
       JMP StartOfFrame
;Graphics
Playfield_PF0
   .byte #%10000001   ;
   .byte #%10000001   ;
   .byte #%01000010   ;
   .byte #%01000010   ;
   .byte #%00100100   ;
   .byte #%00011000   ;
Player_0_up
   .byte #%00001000
   .byte #%00011100
   .byte #%00111110
   .byte #%01111111
   .byte #%11111110
   .byte #%01111100
   .byte #%00111000
   .byte #%00010000
      ;this is the end. change origin to the end of the 4k rom
       org $FFFA
TheEnd
       .word Reset    ;NMI;used in 7800?
       .word Reset    ;RESET
       .word Reset    ;IRQ;used in 7800?
      ;end of file
       END
Hi there!
With a little re-arranging of your loop this'll work:
loop
       LDA #0
       CPX YPosP0
       BNE SkipP0
       LDY #8
                      ;painting
SkipP0
       sta WSYNC
       STA GRP0
       BEQ FinishP0
IsP0
       DEX
       BNE loop
The write to GRP0 was just coming too late in the first line displaying your sprite, due to the extra cycles for setting HeightP0.
I think there is a lesson from Andrew regarding vertical positioning, you should definetely read that for getting a better idea of some more effective strategies for this.
Greetings,
Manuel
