vdub_bobby Posted January 13, 2005 Share Posted January 13, 2005 What do you get when you read from the write-only TIA registers, like GRP0, HMP0, etc.? I know you don't get the value that's actually in the registers, but what do you get? I was messing around with PCAE testing some of this but I'm not sure if that emulator correctly emulates this stuff - anybody know? - so I thought I'd ask you smart folk For example, in PCAE, after this: lda #$FF sta GRP0 lda GRP0 A is zero. Quote Link to comment Share on other sites More sharing options...
vdub_bobby Posted January 13, 2005 Author Share Posted January 13, 2005 Trying to follow the trace file in z26... And after this code: lda #$FE sta GRP0 lda GRP0 A holds $1B, which is the address of GRP0, when run by z26. Which seems odd. Quote Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted January 13, 2005 Share Posted January 13, 2005 Have a look at the source codes of Stella or z26 (PCAE is quite outdated and not nearly as reliable as those two). There you should find some information. And search the [stella] mailing list, IIRC your question was diskussed there too. Quote Link to comment Share on other sites More sharing options...
vdub_bobby Posted January 14, 2005 Author Share Posted January 14, 2005 Thanks, I found some stuff on Stella that answered most of my questions. Quote Link to comment Share on other sites More sharing options...
Bruce Tomlin Posted January 14, 2005 Share Posted January 14, 2005 What do you get when you read from the write-only TIA registers, like GRP0, HMP0, etc.? You get the contents of the collision registers, which are mirrored every 16 bytes. And I guess you get bus float from the remaining 4 (?) unused read locations. Quote Link to comment Share on other sites More sharing options...
vdub_bobby Posted January 14, 2005 Author Share Posted January 14, 2005 What do you get when you read from the write-only TIA registers, like GRP0, HMP0, etc.? You get the contents of the collision registers, which are mirrored every 16 bytes. And I guess you get bus float from the remaining 4 (?) unused read locations. Yeah, the stuff I found on Stella (http://www.biglist.com/lists/stella/archives/200107/msg00045.html) said basically the same thing. What is the bus, though? Quote Link to comment Share on other sites More sharing options...
Nukey Shay Posted January 15, 2005 Share Posted January 15, 2005 Riders Then they get off and there's just the driver until he goes home. Quote Link to comment Share on other sites More sharing options...
