player 0 and 1 are different sizes but using same data table
xucaen
Hi, I'm playing with getting two sprites to display on the screen. For some reason the data that I load into GRP1 appears smaller on the screen than the same data loaded into GRP0. I don't understand why. I don't quite have cycle counting down yet so my timing could be off. I tested this with another example of mine that displays one sprite and a playfield. When I changed all GRP0 to GRP1 the sprite appeared smaller. Has anyone seen this sort of behaviour?
   processor 6502
   include vcs.h
   include macro.h
  ;set origin to the start RAM
  ;this is where variables are declared
    SEG.U vars;this declares Uninitialized space. i.e. RAM
              ; "vars" is the label. YOU NEED THIS!!
    ORG $80   ;$80 is the beginning of RAM
; vet up variables
YPosP0          ds 1
HeightP0        ds 1
YPosP1          ds 1
HeightP1        ds 1
      ;set origin to the start of the 4k rom
       SEG;this end the unitialized space and begins Initialized space
          ; i.e. ROM
       ORG $F000  ;$F000 is the beginning of ROM
Reset
      ;Clear RAM and all TIA registers
       ldx #0
       lda #0
Clear   sta 0,x
       inx
       bne Clear
      ;total 9 bytes!
;             InitializeVariables
       lda #90
       sta YPosP0
       sta YPosP1
;EndInitializeVariables
StartOfFrame; Beginning of the game
; VerticalSync   ;top 3 scanlines
      ;using macro. this also stops vsync
       VERTICAL_SYNC
;VerticalBlank  ;37 scanlines
       ldx #37    ; 37 scanlines of vertical blank...
       SLEEP 23
       STA RESP0;put player 0  at clock 68
       SLEEP 20
       STA RESP1  ;put player 1 at clock 130
vblankloop
       sta WSYNC
       dex
       bne vblankloop
       LDX #0
       STX VBLANK
;EndVerticalBlank
;DrawScreen ;192 scanlines
      ;now you have 192 scanlines of picture
      ;remember, that's 228 clocks or 76 cpu cycles
       LDA #$00       ;2 (load immediate)
       STA COLUBK     ;3  [5] (store zero page); Set Background to Black
       STA COLUPF     ;3  [8]
       STA GRP0       ;3  [11]
       STA GRP1       ;3  [14]
       LDA #1         ;2  [16]
       sta CTRLPF     ;3  [19]
       lda #$1C       ;2  [21]
       sta COLUP0     ;3  [24]
       lda #$66       ;2  [26]
       sta COLUP1     ;3  [29]
       lda #%00000101 ;2  [31]
       sta NUSIZ0     ;3  [34]
       LDY #0         ;2  [36]
       STY HeightP0   ;3  [39]
       STY HeightP1   ;3  [42]
       LDX #191       ;2  [44]
       STA WSYNC
LoopScanLines
       LDA #0         ;2
       STA GRP0       ;3  [5]
       STA GRP1       ;3  [8]
;test player 0
       CPX YPosP0     ;3  [11]
       BNE EndP0      ;2+ [13][14];if not at Y position, then jump to end
                                          ;else
       LDY #8         ;2  [15] ;load Y with Player 0 height
       STY HeightP0   ;3  [18]
EndP0
;do we draw player 0?
       LDY HeightP0   ;2  [20 if bne wasnot taken]
                      ;   [16 if bne was taken]
       BEQ EndDrawP0  ;2+ [22][18]  ;if heightP0 is zero we are done drawing
       LDA Player_0-1,Y;4+ [26][22]  ;else draw Player 0
       STA GRP0       ;3  [29][25]
       DEC HeightP0   ;5  [34][30]
EndDrawP0
;test player 1
       CPX YPosP1     ;3  [37][33]
       BNE EndP1      ;2+ [39][35]
       LDY #8         ;2  [41][37]
       STY HeightP1   ;3  [44][40]
EndP1
;do we draw player 1?
       LDY HeightP1   ;2  [46][42]
       BEQ EndDrawP1  ;2+ [48][44]
       LDA Player_0-1,Y;4+ [52]
       STA GRP1       ;3  [55]
       DEC HeightP1   ;5  [60]
EndDrawP1
FinishP0 sta WSYNC     ;3  [63][51]
       DEX            ;2  ;jump here if we are not painting
       BNE LoopScanLines;2+
       LDA #2;#%01000010     ; Disable TIA Output
       STA VBLANK
;EndDrawScreen
OverScan
      ;now you have 30 scanlines of overscan
      ;(2280 machine cycles, 6840 color clocks
       LDX #30
O1
       STA WSYNC
       DEX
       BNE O1
;EndOverScan
;go back to the beginning:
;inifinate loop
       JMP StartOfFrame
;Graphics
Player_0
   .byte #%00001000
   .byte #%00010100
   .byte #%00100010
   .byte #%01000001
   .byte #%10000010
   .byte #%01000100
   .byte #%00101000
   .byte #%00010000
      ;this is the end. change origin to the end of the 4k rom
       org $FFFA
TheEnd
       .word Reset    ;NMI;used in 7800?
       .word Reset    ;RESET
       .word Reset    ;IRQ;used in 7800?
      ;end of file
       END
Jim
You are setting P0's size register (NUSIZ0), but not P1's. Also, the display is sending 263 scanlines (which will roll the television in NTSC and not display colors in PAL). Adding a write to NUSIZ1 and reducing the scanline counter to 190 corrected both (tho P1 now has a missing pixel) :P
Yikes! I remember in my playfield test, I set up NUSIZO because I wanted a larger sprite, then I forgot all about it! ::embarrassed:: I basically took my playfield source code and removed all the playfield and joystick code so I could start learning how to use RESPx and have 2 sprites. Thanks Nukey!
Jim
