Reversing the sign of a signed-integer whose sign is unknown
Is there a real slick way to get the absolute value of a signed 8-bit number, whose sign is unknown?
I came up with this:
	lda NumberSignUnknown
bpl NumberPositive
lda #0
sec
sbc NumberSignUnknown
bvc NumberPositive
;--if overflow set, then we ended up with +128 (i.e., -128)
sec
sbc #1	;make that +127
NumberPositive
;--now A holds abs(NumberSignUnknown)
(This code does a little extra also, it returns abs(-128) as 127.)
The application, in my case, is this:
I have two sprites, each with a velocity represented by a pair of signed integers: VX1, VX2, VY1, VY2. Positive velocity is up/right, Negative velocity is down/left.
So, when they bump, I need these two numbers:
X Velocity magnitude: abs(VX1) / 2 + abs(VX2) / 2
Y Velocity magnitude: abs(VY1) / 2 + abs(VY2) / 2
Anybody know any slick ways to do this?
With this one though abs(-128) will return -128 though
Thanks for the reminder! I had completely forgotten how you flip the sign of a two's complement number.
So, my new routine (returning abs(-128)=127) would be:
 bpl NumberPositive
 eor #255
 clc
 adc #1
 bpl NumberPositive
 sec
 sbc #1
NumberPositive
My old routine was 14 bytes long; this one is....also 14 bytes long. :(
Any ideas?
 bpl NumberPositive
 eor #255
 clc
 adc #1
 bpl NumberPositive
 sec
 sbc #1
NumberPositive
Nope, the last three instructions are superfluous.
 bpl NumberPositive
 eor #255
 clc
 adc #1
NumberPositive
or
 bpl NumberPositive
 sec
 sbc #1
 eor #255
NumberPositive
So, if you know the state of the carry flag, you can save one more byte. :)
If I start with -128, flip all the bits and add one then I will get +128. Which is -128. Right?
 bpl NumberPositive
 eor #255
 clc
 adc #1
NumberPositive
or
 bpl NumberPositive
 sec
 sbc #1
 eor #255
NumberPositive
Unfortunately, I don't know the state of the carry. :(
How about that one?
 bpl NumberPositive
 asl
 sbc #2
 ror
 eor #255
NumberPositive:
Don't ask! :D
Holy smokes! I'm impressed...
I ran that through on paper and it didn't work - if I started with 1, it returned -128 - but then I realized that it did work for negative numbers, and that positive numbers wouldn't be manipulated at all.
Just crazy enough to work!
At this point, I don't care if somebody can beat 10 bytes, that routine is too incomprehensible; I HAVE to use it :)
Did you check that code for -128? It still returns -128 for that number... which makes the routine rather interesting way of wasting cycles ;)
I'm wondering if it wouldn't be easier to just assure that the velocity never exceeds 127?
Yeah, I did check it...:) Guess not well enough.
Its not clear to me why you are concerned that -128 -> $80 transforms into 128 -> $80. The fact is that 128 and -128 are representes by the same combination of bits. The meaning of those bits 128 or -128 is completely up to you as the programmer. Since you want all negative values to be made positive, isn't it correct then for -128 to become 128?
Regards,
Regards,
Well, it is because I am using signed integers to represent velocity, so if I just left it as +128 to do my calculations, at some point I would have to transform that to +127 before I use it as velocity, or the velocity would be in the wrong direction.
Here's what I am doing:
Two sprites bump into each other, each with an X and Y velocity (signed integers): call them VX1, VY1, VX2, VY2
I want to take half the magnitude of the X velocities: VXsum = abs(VX1) / 2 + abs(VX2) / 2
and then, for the sprite who is leftmost, give him negative VXsum and give the other sprite positive VXsum.
Then I do something similar for the Y velocities.
So...if VX1 = -128 and VX2 = -128 (both sprites going full speed to the left, and suffering a glancing collision), then what I want VXsum to be is 127 - the largest positive signed integer. If my abs() function returns abs(-128)=127, then I'm fine. If it returns +128, then I get: $40 + $40 = $80 = -128
So if I then applied that velocity willy-nilly, then my two sprites would end up with velocity in the wrong direction! So I would need to check when I sum the velocities to see if the addition overflowed and, if so, reset to the maximum positive velocity. Which I could do, but it just seemed cleaner to turn -128 into 127 at the beginning which eliminates that problem completely!
But if there is a better way, I'm willing to be persuaded :)
Now that I think about it...it probably would be easier, and more efficient, to just add these statements immediately after the addition of the half-velocities:
	bvc NoOverflow
lda #$7F
NoOverflow
Unless Thomas can come up with an abs() routine that is less than 4 bytes :D
Thanks, Robert, for making me use my brain ;)
Hm, I don't think that will work. You need the sign for your calculation.
E.g. when sprite 1 goes into the same direction as sprite 2, just a bit faster. When they collide, by using your formular, one of them would suddenly reverse direction.
I think it works alright :)
But don't take my word for it! You can see it in action in my fishies game in the two-player mode: when the players are the same size, and they collide, they bounce off each other.
The routine isn't real accurate, from a Newtonian physics point of view, but I think it looks ok.
  • 3 months later...
