vdub_bobby Posted February 4, 2005 Share Posted February 4, 2005 I'm programming for the 2600 and I need a routine to find out if two sprites collided and I need to use bounding boxes (is that the correct term); I can't use the hardware collision detection registers. So, here's my routine: CheckBoundaries ;--Temp variables should be set up as follows: ; Temp=X1, Temp+1=X2, Temp+2=X3, Temp+3=X4 ; will set carry if X1 or X2 are between X3 and X4 ; or if X3 or X4 are between X1 and X2 ; will clear carry else. lda Temp cmp Temp+2 bmi Check2a cmp Temp+3 bmi InsideBoundingBox Check2a lda Temp+1 cmp Temp+2 bmi Check3a cmp Temp+3 bmi InsideBoundingBox Check3a lda Temp+2 cmp Temp bmi Check4a cmp Temp+1 bmi InsideBoundingBox Check4a lda Temp+3 cmp Temp bmi NotInsideBoundingBox cmp Temp+1 bpl NotInsideBoundingBox InsideBoundingBox sec rts NotInsideBoundingBox clc rts Is there a better way? Quote Link to comment Share on other sites More sharing options...
+batari Posted February 5, 2005 Share Posted February 5, 2005 It all depends. What do x1-x4 represent, are there two boxes checking against one another, are they always the same size, is one always bigger than the other or can they both be any size? Quote Link to comment Share on other sites More sharing options...
vdub_bobby Posted February 5, 2005 Author Share Posted February 5, 2005 It all depends. What do x1-x4 represent, are there two boxes checking against one another, are they always the same size, is one always bigger than the other or can they both be any size? Two sprites, 1 & 2. Left edge of bounding box for sprite 1 is x1 Right edge of bounding box for sprite 1 is x2 Left edge of bounding box for sprite 2 is x3 Right edge of bounding box for sprite 2 is x4 They are not always the same size; either can be bigger. I set up the temp variables with the X coordinates and call this subroutine, then if I have a match, I set up the temp vars with the Y coordinates and call it again. Thanks; any help is appreciated Quote Link to comment Share on other sites More sharing options...
+batari Posted February 5, 2005 Share Posted February 5, 2005 OK,in that case, I think you can save a little bit but not too much. You're currently checking x1<=x3<=x2, x1<=x4<=x2, x3<=x1<=x4, and x3<=x2<=x4. The first two checks would suffice for all situations except box 1 being completely contained within box 2. But to handle this case, only one additional check is needed. I'm pretty sure that you can pick any three checks out of the four and this will do the job. Or can anyone see a reason why this wouldn't work?[/code] Quote Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted February 5, 2005 Share Posted February 5, 2005 Instead of storing both edges, just store the right edge and the width (maybe as a constant). Then you can do something like lda right2 sec sbc right1 adc #width1+1 rts ; c=1: right2 is inside Repeat for right2-width2 Quote Link to comment Share on other sites More sharing options...
vdub_bobby Posted February 5, 2005 Author Share Posted February 5, 2005 Instead of storing both edges, just store the right edge and the width (maybe as a constant). Then you can do something like lda right2 sec sbc right1 adc #width1+1 rts ; c=1: right2 is inside Repeat for right2-width2 I kinda figured there was some simpler solution that involved subtracting one from the other (I kept thinking that something similar to the SkipDraw routine should do it), but my brain wouldn't think of it on a Friday afternoon. Thanks. And thanks, Batari: I didn't realize that in the case where one is completely contained inside the other one, only three checks are needed, not four. You guys are fabulous Quote Link to comment Share on other sites More sharing options...
vdub_bobby Posted February 9, 2005 Author Share Posted February 9, 2005 Instead of storing both edges, just store the right edge and the width (maybe as a constant). Then you can do something like lda right2 sec sbc right1 adc #width1+1 rts ; c=1: right2 is inside Repeat for right2-width2 This works except for the case when both sprites have equal X positions or Y positions: situation: X1=X2 instr carry accum lda X1 X1 sec set sbc X2 set 0 adc W2 clear W1 But if they are overlapping in the Y-axis that should register as a collision. Unless I'm screwing something up here. Quote Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted February 9, 2005 Share Posted February 9, 2005 How about clc ... adc #width+2 ? Quote Link to comment Share on other sites More sharing options...
vdub_bobby Posted February 9, 2005 Author Share Posted February 9, 2005 How about clc ... adc #width+2 ? I dunno. Similarly, I tried messing around with adding 1 to right1 before the collision routine. But I was getting some weird results (in certain cases they collided before they should have and in certain cases they collided after they should have) and I don't know if they are resolvable. I'll keep staring at it Actually....hmmmmm... Quote Link to comment Share on other sites More sharing options...
vdub_bobby Posted February 9, 2005 Author Share Posted February 9, 2005 [...] I was getting some weird results (in certain cases they collided before they should have and in certain cases they collided after they should have) and I don't know if they are resolvable. I'll keep staring at it And here's a solution, of sorts... lda Left1 sec sbc #1 sbc Left2 adc Width1 bcc CheckOtherSide rts CheckOtherSide sec sbc Width1 sbc Width2 bcs NoCollision sec rts NoCollision clc rts I'm pretty sure that works for all cases. However, this has a few problems: First of all, to make the widths inclusive, both of them need to be incremented by one. Second, that is 23 bytes...my cmp version is 24 bytes. The difference doesn't seem worth the trouble. Here's the cmp version. lda Left1 cmp Left2 bmi CheckOtherSide cmp Right2 bmi Collision CheckOtherSide lda Left2 cmp Left1 bmi NoCollision cmp Right1 bpl NoCollision Collision sec rts NoCollision clc rts For all of the code above, the variables Left1 & Left2 are the left edges of the bounding box, Width1 & Width2 are the widths of the bounding boxes, and Right1 & Right2 are the right edges of the bounding boxes. Any comments/ideas? Quote Link to comment Share on other sites More sharing options...
Heaven/TQA Posted October 28, 2007 Share Posted October 28, 2007 ehm... am i little bit stupid or why is there no check against the y-dimension? i mean a sprite could be overlapping in x-direction but not in y? Quote Link to comment Share on other sites More sharing options...
Heaven/TQA Posted October 28, 2007 Share Posted October 28, 2007 seems i overread the sentence "call the routine twice for x,y"... Quote Link to comment Share on other sites More sharing options...
