Disassembling 8k+ 2600 games...
vdub_bobby
Yeah...Distella :)
The problem is in bankswitching. It confuses the disassembler. So the binary rom must be split into 4k pieces (using a file splitter like HJsplit), and each part disassembled seperately. But then the automatic code detection won't work, so each newly-disassembled half must be opened up and studied in order to create .cfg files (sample below) that will help the disassembly process (so you can feed Distella the proper base address of that portion and list where code starts/ends). This is instructed by using -c in the command line...as in:
distella -pafscmspac1.cfg mspacman.001 > mspac1.asm
distella -pafscmspac2.cfg mspacman.002 > mspac2.asm
Once disassembled, the 2 halves can be pasted together into 1 assmembly by using the ORG/RORG combo...
ORG $1000
RORG $D000
...for the start of the first section, and...
ORG $2000
RORG $F000
...for the start of the second.
mspaccfg.zip
Thanks, folks, for the help. :)
ORG $1000
RORG $D000
ORG $2000
RORG $F000
Speaking of bank-switching...has anyone ever written a little tutorial on bank switching? I have tried searching the Stella archives a couple of times, but couldn't find much.
I think someone somewhere (T Jentzsch?) referred someone who was asking about bank-switching to A Davie's released source of Fu Kung (http://www.biglist.com/lists/stella/archives/200301/msg00466.html).
So I had a look, and it looks something like this:
            SEG
           ORG $2000
           RORG $f000
           include "bank03.asm"
           SEG
           ORG $2800
           RORG $f000
           include "bank04.asm"
           SEG
           ORG $3000
           RORG $f000
           include "bank05.asm"
Everything is RORGed to $F000...but in your example, you RORGed to $D000...?
If I can't find a tutorial or a FAQ or a howto I'll eventually just jump in and figure it out through trial and error, but it would be nice to have a guide :)
Does one exist?
The 2600 only uses 13 bits for it's address line...so to the bus, $D000 "looks" the same as $F000 (so do $B000, $9000, etc.). That 13th bit is always set. The only reason that they are different is because that is the addresses that were originally used when it was assembled (take a look at the vectors and JMP/JSR instructions in the code). Use the wrong base address when disassembling, and the tagging will fail.
Does one exist?
I wouldn't really call it a tutorial, but if you haven't already read it, http://www.qotile.net/minidig/docs/sizes.txt explains things pretty nicely. It doesn't tell how to set up the org/rorg stuff in DASM, but Nukey has outlined that well enough...
The ORGs and RORGs must differ, otherwise Dasm would assume that an additional 4k of space (or more, depending on what the base addresses are) exists between the banks. So the ORGs just specify that the banks are only 4k apart (opposed to 8k in that example).
I gather that Arcadia bankswitching, for example would be divided into 3 portions...2k running from $x000 to $x7FF and two 2k sections running from $x800 to $xFFF. The first 2k is always present, with 2 additional 2k sections that are swapped. So that when merging the two assemblies,
ORG $1000
RORG $x000
ORG $1800
RORG $x800
ORG $2000
RORG $x800
...would be used (where x=the hex digit used in the vectors)?
  • 2 weeks later...
Hi there!
Which game are we actually talking about? You know, chances are good that you're probably just wasting your time on a job that has already been done :)
Greetings,
Manuel
Well, I was thinking of having a look at the Elevator Action prototype.
So, before I dive in too deep, has someone done this already?
Why? :?
Sorry; should have been more clear.
First, is that source you posted the source for Elevator Action? Comparing yours to Nukey's, they don't look the same (not the same at locations $F000 or $D000 for starters...).
Also, can the source you posted be compiled and run? It compiled right, but won't run in z26 or stella...does it need special parameters? A Ewoks Adventure game sounds like fun!
