MayDay Posted March 16, 2005 Share Posted March 16, 2005 Hello friends... I have had DASM working for five days now, and have "finished" coding my first playfield using Andrew's tutorials/code. I'm still playing with the colors and shape of the center circle, but that's just cleanup. I would like someone to take a look at the code and tell me what I need to do differently. I'm sure there is an easier way (and more efficient) of drawing the playfield than listing it out line by line (for instance writing a loop) because I don't seem to find the same thing in other code I look at. At first I was trying it with 24 (the number of vertical pixels available in the playfield?) but ended up needing to draw out each of the 192 scanlines for it to work right. Still I'm pretty happy for having been coding for all of four days now (I finished this last night, just now getting around to posting). Also, as I (mistakingly) posted in the homebrew forum, I want to try and program a dodgeball game. There are several games I would be interested in seeing the code for, yet am unable to find code for any sports games at all (ie- basketball, volleyball, football). Is this available anywhere? I also don't suppose it's possible to take binaries and turn them into assemblies at all? I would really like to have a 3 on 3 game where the sprites move independent of one another and you can switch between them as you choose (ala Super Tecmo Bowl wide receivers). I am however willing to settle for 2 on 2 with the players locked together if that isn't possible. I have also played with some code from the sprites tutorials, but can't seem to get any of it to compile correctly. My biggest problem is that I'm quickly running out of information to absorb, as there are only 24 tutorials and I still need to know about stuff like collisions, restricting sprites to half the court, etc. I'm hoping I have the potential for a high midichlorian count... any Jedi seeking a padawan (located in KC, MO) to train? By the way, much kudos to Andrew Davie- I'm sure it's helped many people have the capacity to begin coding, even if just for hacking. -JD Quote Link to comment Share on other sites More sharing options...
MayDay Posted March 16, 2005 Author Share Posted March 16, 2005 Okay, it didn't include the attachment for some reason... trying again. -JD Apparently, .s files are not supported...though I didn't get that message the first time. I don't have WinZip ready, so I'lll just post the actual code below. ; Dodgeball Playfield Code ; 3/14/05 processor 6502 include "vcs.h" include "macro.h" SEG ORG $F000 Reset ; Clear RAM, TIA registers and Set Stack Pointer to #$FF SEI CLD LDX #$FF TXS LDA #0 Clear_Mem STA 0,X DEX BNE Clear_Mem LDA #$A4 ; Load Color STA COLUBK ; Set Background Color LDA #$1F ; Load Color STA COLUPF ; Set Playfield Color LDA #%00000001 ; Mirrored Playfield STA CTRLPF Start_Frame ; Start VSYNC LDA #2 STA VSYNC STA WSYNC STA WSYNC STA WSYNC ; 3 Scanlines of VSYNC LDA #0 STA VSYNC ; End VSYNC ; 37 Scanlines of Vertical Blank LDX 37 Vertical_Blank STA WSYNC DEX BNE Vertical_Blank LDA #0 STA VBLANK ; Enable TIA Output LDX #192 ; 192 Scanlines to Display Draw_Picture LDA Screen_PF0-1,X STA PF0 LDA Screen_PF1-1,X STA PF1 LDA Screen_PF2-1,X STA PF2 STA WSYNC DEX BNE Draw_Picture LDA #%01000010 ; Disable VIA Output STA VBLANK ; 30 overscan lines LDX #30 Overscan STA WSYNC DEX BNE Overscan JMP Start_Frame ; Build Next Frame ; Mirrored Playfields generated = PF0, PF1, PF2 Screen_PF0 .byte #%11111111 .byte #%11111111 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%11111111 .byte #%11111111 Screen_PF1 .byte #%11111111 .byte #%11111111 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%11111111 .byte #%11111111 Screen_PF2 .byte #%11111111 ;1 .byte #%11111111 ;2 .byte #%10000000 ;3 .byte #%10000000 ;4 .byte #%10000000 ;5 .byte #%10000000 ;6 .byte #%10000000 ;7 .byte #%10000000 ;8 .byte #%10000000 ;9 .byte #%10000000 ;10 .byte #%10000000 ;11 .byte #%10000000 ;12 .byte #%10000000 ;13 .byte #%10000000 ;14 .byte #%10000000 ;15 .byte #%10000000 ;16 .byte #%10000000 ;17 .byte #%10000000 ;18 .byte #%10000000 ;19 .byte #%10000000 ;20 .byte #%10000000 ;21 .byte #%10000000 ;22 .byte #%10000000 ;23 .byte #%10000000 ;24 .byte #%10000000 ;25 .byte #%10000000 ;26 .byte #%10000000 ;27 .byte #%10000000 ;28 .byte #%10000000 ;29 .byte #%10000000 ;30 .byte #%10000000 ;31 .byte #%10000000 ;32 .byte #%10000000 ;33 .byte #%10000000 ;34 .byte #%10000000 ;35 .byte #%10000000 ;36 .byte #%10000000 ;37 .byte #%10000000 ;38 .byte #%10000000 ;39 .byte #%10000000 ;40 .byte #%10000000 ;41 .byte #%10000000 ;42 .byte #%10000000 ;43 .byte #%10000000 ;44 .byte #%10000000 ;45 .byte #%10000000 ;46 .byte #%10000000 ;47 .byte #%10000000 ;48 .byte #%10000000 ;49 .byte #%10000000 ;50 .byte #%10000000 ;51 .byte #%10000000 ;52 .byte #%10000000 ;53 .byte #%10000000 ;54 .byte #%10000000 ;55 .byte #%10000000 ;56 .byte #%10000000 ;57 .byte #%10000000 ;58 .byte #%10000000 ;59 .byte #%10000000 ;60 .byte #%10000000 ;61 .byte #%10000000 ;62 .byte #%10000000 ;63 .byte #%10000000 ;64 .byte #%10000000 ;65 .byte #%10000000 ;66 .byte #%10000000 ;67 .byte #%10000000 ;68 .byte #%10000000 ;69 .byte #%10000000 ;70 .byte #%11000000 ;71 .byte #%11000000 ;72 .byte #%11000000 ;73 .byte #%11000000 ;74 .byte #%10110000 ;75 .byte #%10110000 ;76 .byte #%10110000 ;77 .byte #%10110000 ;78 .byte #%10001000 ;79 .byte #%10001000 ;80 .byte #%10001000 ;81 .byte #%10001000 ;82 .byte #%10000100 ;83 .byte #%10000100 ;84 .byte #%10000100 ;85 .byte #%10000100 ;86 .byte #%10000100 ;87 .byte #%10000100 ;88 .byte #%10000100 ;89 .byte #%10000100 ;90 .byte #%10000010 ;91 .byte #%10000010 ;92 .byte #%10000010 ;93 .byte #%10000010 ;94 .byte #%10000010 ;95 .byte #%10000010 ;96 .byte #%10000010 ;97 .byte #%10000010 ;98 .byte #%10000010 ;99 .byte #%10000010 ;100 .byte #%10000010 ;101 .byte #%10000010 ;102 .byte #%10000100 ;103 .byte #%10000100 ;104 .byte #%10000100 ;105 .byte #%10000100 ;106 .byte #%10000100 ;107 .byte #%10000100 ;108 .byte #%10001000 ;109 .byte #%10001000 ;110 .byte #%10001000 ;111 .byte #%10001000 ;112 .byte #%10110000 ;113 .byte #%10110000 ;114 .byte #%10110000 ;115 .byte #%10110000 ;116 .byte #%11000000 ;117 .byte #%11000000 ;118 .byte #%11000000 ;119 .byte #%11000000 ;120 .byte #%10000000 ;121 .byte #%10000000 ;122 .byte #%10000000 ;123 .byte #%10000000 ;124 .byte #%10000000 ;125 .byte #%10000000 ;126 .byte #%10000000 ;127 .byte #%10000000 ;128 .byte #%10000000 ;129 .byte #%10000000 ;130 .byte #%10000000 ;131 .byte #%10000000 ;132 .byte #%10000000 ;133 .byte #%10000000 ;134 .byte #%10000000 ;135 .byte #%10000000 ;136 .byte #%10000000 ;137 .byte #%10000000 ;138 .byte #%10000000 ;139 .byte #%10000000 ;140 .byte #%10000000 ;141 .byte #%10000000 ;142 .byte #%10000000 ;143 .byte #%10000000 ;144 .byte #%10000000 ;145 .byte #%10000000 ;146 .byte #%10000000 ;147 .byte #%10000000 ;148 .byte #%10000000 ;149 .byte #%10000000 ;150 .byte #%10000000 ;151 .byte #%10000000 ;152 .byte #%10000000 ;153 .byte #%10000000 ;154 .byte #%10000000 ;155 .byte #%10000000 ;156 .byte #%10000000 ;157 .byte #%10000000 ;158 .byte #%10000000 ;159 .byte #%10000000 ;160 .byte #%10000000 ;161 .byte #%10000000 ;162 .byte #%10000000 ;163 .byte #%10000000 ;164 .byte #%10000000 ;165 .byte #%10000000 ;166 .byte #%10000000 ;167 .byte #%10000000 ;168 .byte #%10000000 ;169 .byte #%10000000 ;170 .byte #%10000000 ;171 .byte #%10000000 ;172 .byte #%10000000 ;173 .byte #%10000000 ;174 .byte #%10000000 ;175 .byte #%10000000 ;176 .byte #%10000000 ;177 .byte #%10000000 ;178 .byte #%10000000 ;179 .byte #%10000000 ;180 .byte #%10000000 ;181 .byte #%10000000 ;182 .byte #%10000000 ;183 .byte #%10000000 ;184 .byte #%10000000 ;185 .byte #%10000000 ;186 .byte #%10000000 ;187 .byte #%10000000 ;188 .byte #%10000000 ;189 .byte #%10000000 ;190 .byte #%11111111 ;191 .byte #%11111111 ;192 ORG $FFFA ; Interrupt Vectors .word Reset ; NMI .word Reset ; RESET .word Reset ; IRQ END Quote Link to comment Share on other sites More sharing options...
Robert M Posted March 16, 2005 Share Posted March 16, 2005 Hello, Glad to see new people trying their hand at programming thte VCS. Please use Winzip in the future. That big listing of PF data is painful to scroll through on the forum. Here is the main visible display loop from your code above: LDX #192; 192 Scanlines to Display Draw_Picture LDA Screen_PF0-1,X STA PF0 LDA Screen_PF1-1,X STA PF1 LDA Screen_PF2-1,X STA PF2 STA WSYNC DEX BNE Draw_Picture If you want to reduce that size of your PF data tables, then you can employ many methods. The key to many of them is to use one index register to count the total scanlines (X in your code) and the other index register to point at the next byte of PF data. If the PF data should be recycled for say 8 scanlines producing PF pixels 8 scanlines high and cutting your tables by 8, then you simply need to update Y only once every 8 lines. like this: LDX #192; 192 Scanlines to Display LDY #0 ; PF Graphics index. Draw_Picture LDA Screen_PF0-1,Y STA PF0 LDA Screen_PF1-1,Y STA PF1 LDA Screen_PF2-1,Y STA PF2 STA WSYNC DEX BEQ exit TXA ; Copy the line count to A AND #8-1 ; Since 8 is a power of 2 we can test the lower 3 bits of BNE .skip1 ; the line count. If they are all 0's, then the line count is INY ; a mulitple of 8 and we need to increment the PF index in Y .skip1 JMP Draw_Picture You need to learn how to use the timer TIM64T and INTIM to count scanlines, and you will find it easier to write a display loop if you do not try to use all 192 lines. Its hard to make a graceful transition from vertical blanking directly to a loop that draws the screen. If you leave the first visible scanline blank, then you can move the STA WSYNC to the top of your display loop, and then the sequence of code in the loop from top to bottom matches the scanning of the raster on the TV from left to right for one scanline. I think you will find that arrangement easier to manage and solve display problems. As for displaying 6 sprites on the screen, the Venture game that I disassembled to hack into Wolfenstein has an engine that can display 6 sprites and the ball with veritcal placement restrictions and flickering at 30 Hz. The mostly commented source is located here: http://www.qotile.net/minidig/ There is alot of other good info and source code examples at the minidig. Cheers! Quote Link to comment Share on other sites More sharing options...
vdub_bobby Posted March 16, 2005 Share Posted March 16, 2005 I second what Robert said, and will add that Kirk Israel's tutorial is very well written and pretty helpful for some of the stuff you mentioned (sprites, etc.). It also has very thoroughly commented code for working, complete programs that is helpful in setting up your own programs to, for example, have stable main loops. Tutorial here: http://www.alienbill.com/2600/101/ And don't forget the Stella mailing list archives. http://www.biglist.com/lists/stella/archives/ Oh, and another way to cut down on PF data which I find simpler (but that's just cuz I'm a little slow) is this: ldx #24 LoopOuter ldy #8 LoopInner sta WSYNC lda Screen_PF0-1,X sta PF0 lda Screen_PF1-1,X sta PF1 lda Screen_PF2-1,X sta PF2 dey bne LoopInner dex bne LoopOuter That will also draw 192 scanlines of PF in 8-line chunks. Of course, the best way, if you are doing this, is to only draw the PF when it changes, since TIA will keep drawing the same thing on every line if you don't tell it different. Something like... ldx #24 LoopOuter sta WSYNC lda Screen_PF0-1,X sta PF0 lda Screen_PF1-1,X sta PF1 lda Screen_PF2-1,X sta PF2 ldy #7 LoopInner sta WSYNC dey bne LoopInner dex bne LoopOuter Ok, I'm done now Quote Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted March 16, 2005 Share Posted March 16, 2005 Oh, and another way to cut down on PF data which I find simpler (but that's just cuz I'm a little slow) is this: Yup, that's simplier. But once you want to draw sprites it is better to have Y as a scanline counter. For blocksizes which are not a power of 2, something like this does the job ldy #191 .loop: ... dey tya ; I wish cpy abs,x would exist cmp BlockSizeTbl,x bne .loop dex bpl .loop ... BlockSizeTbl: .byte 0, 27, 50, 60, 147, 180 Quote Link to comment Share on other sites More sharing options...
