Wntermute Posted July 31, 2001 Share Posted July 31, 2001 Jum52/MacOS 0.5.4 is out at http://ww.bannister.org/software . It runs on MacOS 8.6 and 9.x with the Carbon library and natively on MacOS X. It also requires Richard Bannister's Blitter Plugin (available from the same page). From the Jum52 page: "Jum52/MacOS is an Atari 5200 emulator for MacOS. Jum52 supports reasonable compatibility with Atari 5200 titles. At the present collision detection is a bit hit and miss (no pun intended) but otherwise the emulator is solid enough. Full sound emulation is included. Additional video modes can be added to this emulator via the Blitter Library plugin. Jum52 was initially developed for MS-DOS by James Higgs. The source code is not available. Note that this application is Carbonized. If you are not running under MacOS X, you must have CarbonLib (v1.2 or later) installed in your System Folder for this application to run correctly." Quote Link to comment Share on other sites More sharing options...
