Frogger, first playable demo
Schmutzpuppe
These files don't seem to work in MESS anymore.  No images are recognized in either the BIN or ZIP files, and when you rename FROGGER.BIN to FROGGER.A78, it just crashes the emulation.  What am I doing wrong?
JR
910189[/snapback]
It should run with mess.
Maybe you should download a newer mess version?
I think the last update only had the bin not the A78 file. MESS requires the A78 version.
Mitch
910695[/snapback]
You are right.
I forgot that I only posted the bin :roll:
I'm not getting any sound :( Game plays great though.
910728[/snapback]
The attached version is with A78 header and works with sound.
frogger.zip
  • 1 month later...
Oh my God.. dude this actually beats out the GENESIS version. I've got to say this has to be what is some of the absolute BEST programming I've seen on the 7800. Seeing you got the graphics AND sound done virtually perfect to the arcade I'd have to say you've truly tapped the 7800's potential of making an exact port of an arcade game. *hehs and would like to see people re-do Ms. Pac-Man, DK, DK Jr. and even make a couple fo the other Pac-Man games using both the TIA sound AND Pokey sound*
Tritto...
Err, I mean with me, that makes three. :sad:
[edit]
I finally downloaded the ProSystem emulator and got it to work! As I see it, this is as close as you get to the arcade version that you will get without playing an arcade unit. Unfortunately, I don't hear the music all the way through, but I'm not sure if that is because the ProSystem emulator does not implement a Poky chip or if the game doesn't have all the music.
At any rate, and I keep saying this... but, I really need to get myself a 7800 console, if only for the great homebrew releases!
Edited by mojofltr
Thanks guys.
You keep up the motivation :)
I am still working on it.
The latest release has only the "startup" music.
  • 2 weeks later...
Lotsa great improvements! Are you going to include a .bin version for CC2 owners?
941908[/snapback]
Try this one.
Mitch
942022[/snapback]
Just tried that .bin - doesn't seem to work. Or the settings need to be changed now.
FROG78 7800_48K 78QUICK Worked with the last version.
942069[/snapback]
It's only 32K not 48K. :)
Mitch
Mitch
942083[/snapback]
Yeah, should have noticed that :)
I changed it and now it plays, but oddly seems to have no sound.
942106[/snapback]
It now uses Pokey sound, I guess I should have mentioned it when I posted before. :)
Mitch
Mitch
942166[/snapback]
Okay, I changed it to Pokey. Beautiful! This is easily the best classic home version of Frogger I've ever seen :)
I do notice an entire screen flicker every 5-6 seconds or so though.
Is Frogger currently PAL only? The last couple of versions I've received have had distortions on my 7800.
942047[/snapback]
Which version was the last one that worked for you?
And what kind of distortions you see/hear?
I really need to buy an NTSC Device...
942178[/snapback]
Did you had the same problem with older versions and do you have PAL or NTSC?
Anyone else have this problem?
942178[/snapback]
942213[/snapback]
Yes, I have the flicker problem as well. NTSC though I have a PAL 7800 also.
Mitch
942178[/snapback]
942213[/snapback]
Mitch
942408[/snapback]
That's bad.
So it's seems to be a general NTSC issue, it runs fine on my PAL device.
The problem is that I don't have to chance to reproduce it :sad:
Edited by Schmutzpuppe
