PacManPlus Posted May 11, 2005 Share Posted May 11, 2005 Hi! I hope someone can help me - can anyone tell me how to read the difficulty switches on the 7800 in 7800 mode? (Example code would be great!) I'm working on something where I need to read both switches. Thanks in advance! Bob Quote Link to comment Share on other sites More sharing options...
Bruce Tomlin Posted May 11, 2005 Share Posted May 11, 2005 It works exactly the same as on the 2600. Quote Link to comment Share on other sites More sharing options...
PacManPlus Posted May 11, 2005 Author Share Posted May 11, 2005 Thanks Bruce For some reason I thought it was different... I think I have a commented Adventure disassembly I can look through to see how they read them. Thanks again Quote Link to comment Share on other sites More sharing options...
Harry_Dodgson Posted May 12, 2005 Share Posted May 12, 2005 Hi! I hope someone can help me - can anyone tell me how to read the difficulty switches on the 7800 in 7800 mode? (Example code would be great!) I'm working on something where I need to read both switches. Thanks in advance! Bob 853217[/snapback] How about something like this? :-) BIT Swchb BVS p0expert BVC p0amateur BCS p1expert BCC p1amateur Quote Link to comment Share on other sites More sharing options...
vdub_bobby Posted May 12, 2005 Share Posted May 12, 2005 Hi! I hope someone can help me - can anyone tell me how to read the difficulty switches on the 7800 in 7800 mode? (Example code would be great!) I'm working on something where I need to read both switches. Thanks in advance! Bob 853217[/snapback] How about something like this? :-) BIT Swchb BVS p0expert BVC p0amateur BCS p1expert BCC p1amateur 853952[/snapback] :!: The 'bit' instruction puts bit 7 into the sign flag, not the carry flag! And also, in that code the last two lines will never be reached. Try this instead: bit SWCHB bmi P1Expert ;--else P1 novice bvs P0ExpertAndP1Novice ;--else P0 novice and P1 novice ;--code here jmp Done P0ExpertAndP1Novice ;--code here jmp Done P1Expert bvs P0ExpertAndP1Expert ;--else P0 novice and P1 expert ;--code here jmp Done P0ExpertAndP1Expert ;--code here Done Quote Link to comment Share on other sites More sharing options...
Ecernosoft Posted September 4, 2022 Share Posted September 4, 2022 @PacManPlus, you’ve come a long way from this post. Also, did you make baby pac man on 7800? If you did, I have a question! 2 Quote Link to comment Share on other sites More sharing options...
+SmittyB Posted September 4, 2022 Share Posted September 4, 2022 I don't think it was worth necrobumping a 17 year old thread to ask a question that could have been answered by first looking in the stickied homebrews and hacks thread which you posted in recently, and any separate question you might have should be in its own thread if it's significant enough to warrant it. 2 1 Quote Link to comment Share on other sites More sharing options...
+Muddyfunster Posted September 5, 2022 Share Posted September 5, 2022 2 hours ago, Ecernosoft said: @PacManPlus, you’ve come a long way from this post. Also, did you make baby pac man on 7800? If you did, I have a question! You have learned to use edit. Your next quest on the route to becoming an ASM Jedi is to unlock the Force Search ability. After you have mastered this, open your mind and reach out to the Sticky Thread. 1 3 Quote Link to comment Share on other sites More sharing options...
Traxx Posted September 5, 2022 Share Posted September 5, 2022 Forum Jedi Quote Link to comment Share on other sites More sharing options...
Cebus Capucinis Posted September 5, 2022 Share Posted September 5, 2022 Is this still available, DrAgoNsToMpEr? Oh, sorry, wrong necrobump. 1 Quote Link to comment Share on other sites More sharing options...
Ecernosoft Posted September 5, 2022 Share Posted September 5, 2022 1 hour ago, Muddyfunster said: You have learned to use edit. Your next quest on the route to becoming an ASM Jedi is to unlock the Force Search ability. After you have mastered this, open your mind and reach out to the Sticky Thread. Ok! @Muddyfunster, I get it!!! Sometimes you also need to follow your own rulles too, like this post. Stop following me around please. Ok? I use that search all the time. Not saying that you do that, you do make great games but don't be annoying to fellow people like me. I'm not trying to overpost or anything. I get it. Ok? Thank you for understanding. 3 1 Quote Link to comment Share on other sites More sharing options...
Trebor Posted September 5, 2022 Share Posted September 5, 2022 10 hours ago, Ecernosoft said: Stop following me around please. Ok? It may be challenging to not come across as following you around, especially when you're the latest poster on 40 out of 50 threads on a forum page. Often with multiple recent posts to those threads. Sometimes reiterating the same points made in other recent posts. 4 1 Quote Link to comment Share on other sites More sharing options...
+Muddyfunster Posted September 5, 2022 Share Posted September 5, 2022 @Ecernosoft My comments were intended as a light hearted nudge in the right direction based on how you are using the forum currently. 8 hours ago, Ecernosoft said: Sometimes you also need to follow your own rulles too I'm honestly not sure as to what rule I've broken? Maybe you can help me with that ? I don't make the rules or enforce them, all I have done is to try to politely remind you that you can "edit" and "search" for answers and that you can help yourself, rather than making a new thread every 30 seconds. I've tried to do this in a polite and friendly way, often with some humour to ensure you do not perceive it as an attack, as it is not intended that way. 8 hours ago, Ecernosoft said: Stop following me around please. Ok? That's very difficult. Let me explain a bit more. Counting the most recent 50 or 75 threads in the programming section here: Fully 46% of those threads are yours (35/75). in 50 out of the 75 most recent threads, the last comment on those threads is made by you (50/75 67%) in 38 out of the 50 most recent threads, the last comment on those threads is made by you (38/50 76%) If I was to "not follow you" in posting, then I would then be basically prevented from posting or using this particular forum in any meaningful way, as you have spammed all of the recent threads, including those I have contributed to, with pointless crap. Maybe I can reverse this to you and ask you to refrain from shitposting every thread, every 30 seconds, then I wouldn't be following when I make a post would I? 8 hours ago, Ecernosoft said: but don't be annoying to fellow people like me. I'm not trying to overpost or anything. I get it. You are overposting, whether you realise it or not. You make new threads constantly when they are not needed. You constantly hijak other people's threads to pimp your own ideas, you do not read threads before making proclamations or handing out advice, which is often incorrect or flawed, you do not read threads before asking questions that have already been answered, you ignore sticky threads and ask for information that's right in front of you. You use threads for conversations with another user, which would be better suited to a private messages. My intention isn't to annoy or upset you, I would just prefer (and I'm sure many share this view) that you would use the forum in a more responsible way. Please adjust how you use the forums. If you don't, then I suspect that eventually a moderator or admin will make that choice for you. 5 4 Quote Link to comment Share on other sites More sharing options...
Ecernosoft Posted September 5, 2022 Share Posted September 5, 2022 8 hours ago, Muddyfunster said: @Ecernosoft My comments were intended as a light hearted nudge in the right direction based on how you are using the forum currently. I'm honestly not sure as to what rule I've broken? Maybe you can help me with that ? I don't make the rules or enforce them, all I have done is to try to politely remind you that you can "edit" and "search" for answers and that you can help yourself, rather than making a new thread every 30 seconds. I've tried to do this in a polite and friendly way, often with some humour to ensure you do not perceive it as an attack, as it is not intended that way. That's very difficult. Let me explain a bit more. Counting the most recent 50 or 75 threads in the programming section here: Fully 46% of those threads are yours (35/75). in 50 out of the 75 most recent threads, the last comment on those threads is made by you (50/75 67%) in 38 out of the 50 most recent threads, the last comment on those threads is made by you (38/50 76%) If I was to "not follow you" in posting, then I would then be basically prevented from posting or using this particular forum in any meaningful way, as you have spammed all of the recent threads, including those I have contributed to, with pointless crap. Maybe I can reverse this to you and ask you to refrain from shitposting every thread, every 30 seconds, then I wouldn't be following when I make a post would I? You are overposting, whether you realise it or not. You make new threads constantly when they are not needed. You constantly hijak other people's threads to pimp your own ideas, you do not read threads before making proclamations or handing out advice, which is often incorrect or flawed, you do not read threads before asking questions that have already been answered, you ignore sticky threads and ask for information that's right in front of you. You use threads for conversations with another user, which would be better suited to a private messages. My intention isn't to annoy or upset you, I would just prefer (and I'm sure many share this view) that you would use the forum in a more responsible way. Please adjust how you use the forums. If you don't, then I suspect that eventually a moderator or admin will make that choice for you. Ok, I appologize. I'm sorry, yes I get it. I do realise I have overposted in the past and am trying to slow myself down. Please, I get it! I know I overposted a crap ton back then. I'm sorry @Muddyfunster. Please accept my apology. 2 Quote Link to comment Share on other sites More sharing options...
+Muddyfunster Posted September 5, 2022 Share Posted September 5, 2022 No worries. I appreciate your apology but it's not necessary, just slow down a bit with posting and new threads 2 Quote Link to comment Share on other sites More sharing options...
Ecernosoft Posted September 17, 2022 Share Posted September 17, 2022 On 9/5/2022 at 3:01 PM, Muddyfunster said: No worries. I appreciate your apology but it's not necessary, just slow down a bit with posting and new threads Ok.......... Quote Link to comment Share on other sites More sharing options...
