HSC2 Contest 11 Bandits!
Goochman
HSC Season 2
Contest Ends:
Noon 6/3/05 EDT
Bandits
Score
Cosmic Tunnels
Score
Twin Galaxies Scores
emkay
211265
krupkaj
125600
Score
Player
madbutscher
189610
goochman
109700
58,540
Stephen Knox
_Fandal_
133085
_Fandal_
100700
krupkaj
129440
vdub_bobby
21600
doctorclu
24870
devwebcl
51700
goochman
24465
krupkaj
32300
vdub_bobby
13415
goochman
23000
Xebecs Demise
12090
vdub_bobby
21100
rj
0
doctorclu
15900
R.I.K. of Kaisersoft
0
Shawn Jefferson
0
devwebcl
0
doctorclu
0
deathtrappomegranate
0
devwebcl
0
advfan
0
chriss
0
bjk7382
0
Bunsen
0
Shannon
0
Shawn Jefferson
0
Shawn Jefferson
0
bjk7382
0
Use autofire and shield and you'll be happy!
No! Autofire kills the timing that you need for the shots. With Autofire you gain unwanted gaps and the enemies a.k.a. Bandits can fly though.
yes, autofire is not the best in this game.
my last score is 129440. I think I cannot beat emkay...
edit: I forgot the screenshot
Edited by krupkaj
I started playing this with Atari800win Plus 4.0 and it seems to be running very fast! Almost impossible to dodge those smart bombs. Should I be running this PAL or at a slower speed? Maybe it's easier with a joystick?
For anyone else that tries this game, be sure to:
"Load with OS-B. Disable "SIO patch for fast disk access".
Also make sure that you put the memory size on 48k only.
You should get an exclamation mark in the bottom right hand corner of screen. It will look like it has frozen at a blue screen, just wait for quite a while because it takes a bit of time to load.
http://www.atarimania.com/detail_soft.php?...&VERSION_ID=492
Edited by Xebec's Demise
865814[/snapback]
Not shure...
I played a "fast game" at 60Hz getting nearly 70000.
Hm... like in some other games, it seems, that use the 60Hz are making the gameplay faster/harder, but more precisely.
What makes me more wondering is, that a game like "Bandits", that uses a full software-sprite-engine, is running faster on 60Hz (even if less CPU cycles are left for a frame) than on 50Hz.
Pull down on the joystick and the shield will appear - careful since the blue bars on the bottom represent the amount of power left (they regenerate slowly) - Push up to turn shield off (it takes 1 bar before it will turn off).
Fun game :)
I got 50K once
