madbutscher Posted June 2, 2005 Share Posted June 2, 2005 Hard work, but it's done: 189610 best regards <!-- kRadD / F2 --> former known as mad butscher / F2 Quote Link to comment Share on other sites More sharing options...
Xebec's Demise Posted June 3, 2005 Share Posted June 3, 2005 (edited) That 12090 score was mine, not Vdubs. (without shields) Edited June 3, 2005 by Xebec's Demise Quote Link to comment Share on other sites More sharing options...
Xebec's Demise Posted June 3, 2005 Share Posted June 3, 2005 Hard work, but it's done: 189610 best regards <!-- kRadD / F2 --> former known as mad butscher / F2 866637[/snapback] Unbelievable! Quote Link to comment Share on other sites More sharing options...
emkay Posted June 3, 2005 Share Posted June 3, 2005 ... and if someone beats this score, is an earned number one 211265 Quote Link to comment Share on other sites More sharing options...
Xebec's Demise Posted June 3, 2005 Share Posted June 3, 2005 What the heck! Ok, I am definately doing something wrong. Any tips for those barely breaking into the 5 digits? Are you using a joystick? Quote Link to comment Share on other sites More sharing options...
Goochman Posted June 3, 2005 Author Share Posted June 3, 2005 This contest is closed! Quote Link to comment Share on other sites More sharing options...
emkay Posted June 4, 2005 Share Posted June 4, 2005 What the heck! Ok, I am definately doing something wrong. Any tips for those barely breaking into the 5 digits? Are you using a joystick? 867243[/snapback] A bit late, but here some tips (still a bit shocked because goochman hasn't put my final score in ): Have a look at the movement of the bandits. Presume the direction they will move next and move in that direction before they do. Don't get too far away from the enemies. They will shoot in a high degree, crossing your line with shots for a wide range, so you cannot move around it and you have to waste shield. Shield can be pre-pressed to have it longer active. For the usage of the shield you have to presume, if it's needed or not. And the most important thing: Still hitting the Bandits And, no, I'm using not a joystick. The latency is to high. With the keyboard it's a bit better, but there is still some delay that doesn't happen on the real thing. Quote Link to comment Share on other sites More sharing options...
Goochman Posted June 4, 2005 Author Share Posted June 4, 2005 Final scores posted - thanks Emkay Quote Link to comment Share on other sites More sharing options...
Goochman Posted June 17, 2005 Author Share Posted June 17, 2005 Updated with doctorclus score - sorry about the omission! Quote Link to comment Share on other sites More sharing options...
