Thomas Jentzsch Posted June 29, 2005 Share Posted June 29, 2005 Quote Link to comment Share on other sites More sharing options...
Nukey Shay Posted July 1, 2005 Author Share Posted July 1, 2005 Nukey, are you STILL sticking to your story that kernal programming is just too tough for you to take on in a "from scratch" title? Don't get me wrong, as far as I can tell you are the KING of Hacks, and if that's just your thang, cool. But man, you have programming cajones that make some "published" homebrewers (myself included) look pale and weak. I mean, I can barely understand other people's well commented source, never mind a raw dissasembly. 882656[/snapback] It's no story...I can barely hobble together an intermission kernal with heavy use of borrowing But weeding through already-working code is not so difficult. The game already works...so all I need to do is make sure that the cycle times match in critical areas for added code. Assemble - doesn't work - try something else. Multiply that by a few hundred times Been hacking games for 2 decades, so I'm kind of used to it by now. Latest assembly: The original game kept 2 sets of indirect GFX pointers in ram...1 set of 12 bytes for the digits (with some reused to display the falling missiles and explosion), and 1 set of 12 bytes for the cities. The digit pointers are updated just before the kernal needs them, so it was pretty easy to reuse all of them to display the cities as well (so all the program needs to do is transfer the low bytes for each city pointer to the score pointers...and that saves half of the ram (6 bytes) that was devoted to them). I also moved all GFX to a single page, so that the high bytes in the pointer table never needs to be altered. Ram addresses $AF to $B4 are now free to use. I also converted the game to include an 8k version, since I was virtually out of free romspace (only 16 bytes free in the 4k version). The 8k version has nearly 2k of free space in each bank...enough to handle multiple kernals and whatever to try to solve this bomber problem. I only needed 2 redundant routines to do this, but with careful bankswitching, those routines could probably be eliminated (not a real big deal, since neither one used very much space). MCasm.zip 1 Quote Link to comment Share on other sites More sharing options...
mos6507 Posted September 13, 2005 Share Posted September 13, 2005 Now somebody can do up a special trackball controller with all three missile base buttons on it for the 2600. 880894[/snapback] It would be doable using a booster-trip approach. Quote Link to comment Share on other sites More sharing options...
Atariboy2600 Posted October 31, 2005 Share Posted October 31, 2005 Here's a LINK of a Missile Command Arcade Edition label for any one like to use^_^ Quote Link to comment Share on other sites More sharing options...
Danno Posted October 31, 2005 Share Posted October 31, 2005 Why not make the fire controls on the right stick be "left - fire - right" that way people could use the three button 2600 Track & Field controller right out of the box without modification? Combine that with REAL Trackball control like TJ's Missle Command hack and this would be the ultimate finished hack. You could then make the color/bw switch the pause as it should be for the 7800.... Quote Link to comment Share on other sites More sharing options...
Nukey Shay Posted October 31, 2005 Author Share Posted October 31, 2005 I didn't really worry about different types of controllers...so I just coded a bit to check the status of controller 2. To alter it to use left-fire-right instead would require a couple more instructions to merge the INPT5 fire button status into the value loaded from SWCHA (using LSR's and an AND instruction)...and booster grip/trackball ideas are completely out of my area (since I have no idea about how each of those work). But the controller routines are commented in the assembly if anyone wants to take a stab at either But I'm confused about what you mean by the pause feature Since the left stick button is unused in any case, I thought it made a good candidate to activate the pause? The color/bw switch is already in use as a NTSC/PAL switch in this hack (so that the same binary works regardless of hardware). Quote Link to comment Share on other sites More sharing options...
+Wonder007 Posted November 3, 2005 Share Posted November 3, 2005 Is this going to be in cart form? If so, I am interested in a copy! Quote Link to comment Share on other sites More sharing options...
Lord Helmet Posted November 3, 2005 Share Posted November 3, 2005 Since it's an Atari property, it probably won't get a public release in cart form... Quote Link to comment Share on other sites More sharing options...
Nukey Shay Posted November 5, 2005 Author Share Posted November 5, 2005 I just hack 'em, I don't burn 'em 1 Quote Link to comment Share on other sites More sharing options...
Nukey Shay Posted November 19, 2005 Author Share Posted November 19, 2005 By request: Track & Field controller support added by default (this was easier than I expected). You can use down OR fire for the center silo. It only cost a few bytes of romspace. MCarcade.zip 1 Quote Link to comment Share on other sites More sharing options...
supercat Posted November 19, 2005 Share Posted November 19, 2005 Since it's an Atari property, it probably won't get a public release in cart form...959375[/snapback] Unless Atari does another 2600-based flashback and can be convinced to include it. Quote Link to comment Share on other sites More sharing options...
Nukey Shay Posted July 14, 2006 Author Share Posted July 14, 2006 Latest version: I made the missiles a bit larger so they show up better...and also corrected the hilltop gfx (I even included an "atmosphere" for the city area). The cursor is now an X-crosshair (unlike the arcade's +-crosshair...but better than a dash!)...tho it's still a bit buggy. Out of free space (as long as I stick to 4k). MCarcade.zip Quote Link to comment Share on other sites More sharing options...
Atariboy2600 Posted July 15, 2006 Share Posted July 15, 2006 I don't have a Starplex Controller yet, but I have a Track and Field Controller. Would it be possible to implement another controller scheme mapping the left button to the left cannon, the right button to the right cannon, when both are pushed simultaneously they fire the middle cannon? If anyone like to use the TRACK & FIELD controller then heres somthing I made. Its a overlay of Missile Command Control Panel from the arcade CPO just print it and glue it on a hard poster paper then cut it and place it over your TRACK & FIELD controller. 1 Quote Link to comment Share on other sites More sharing options...
Atariboy2600 Posted July 15, 2006 Share Posted July 15, 2006 Latest version: I made the missiles a bit larger so they show up better...and also corrected the hilltop gfx (I even included an "atmosphere" for the city area). The cursor is now an X-crosshair (unlike the arcade's +-crosshair...but better than a dash!)...tho it's still a bit buggy. Out of free space (as long as I stick to 4k). Here's my what if mockup of my homemade Missile Command overlay on the Track & Field controller if anyone can print this BMP I have here for anyone to us it for the game. 2600_missile_command_overlay_BMP.zip Quote Link to comment Share on other sites More sharing options...
SalemFrost7800 Posted July 16, 2006 Share Posted July 16, 2006 Nukey you are amazing, have you thought about making a Donkey Kong arcade version with the elevators? Quote Link to comment Share on other sites More sharing options...
Nukey Shay Posted July 24, 2006 Author Share Posted July 24, 2006 I've upped the binary to 8k to work in additional screens (the "Missile Command" boot screen and "The End" game screen). I've also added bombers and satellites...though they don't have any offensive capability. Their presence is enough to distract the player tho...especially considering that the game is already more lethal than it's arcade counterpart - due to the fact that all cities can be targeted in a single wave (the arcade game limits this to 3 cities per wave). Running the game using Stella appears to have a couple of glitches...the crosshair is misaligned and the ground area is non-existant (the latter being present in the original game as well). Anyone confirm? MCarcade.zip Quote Link to comment Share on other sites More sharing options...
neotokeo2001 Posted July 24, 2006 Share Posted July 24, 2006 Once again this is no mere hack. This IS Missle Command!! The Title and Ending screens are a nice touch. The addition of the Bomber and Satellite are a huge bonus(It doesn't matter if they don't shoot). Great Job Nukey! Quote Link to comment Share on other sites More sharing options...
Rom Hunter Posted July 25, 2006 Share Posted July 25, 2006 Nukey, It doesn't work properly on Z26 either. Quote Link to comment Share on other sites More sharing options...
Nukey Shay Posted July 27, 2006 Author Share Posted July 27, 2006 Could you be more specific? There are a couple of minor bugs in the program (these are detailed in the comments of the assembly)...but the program still runs. If it didn't, it wouldn't be posted...since I'm using the latest version of z26 to test it Current version adds the end-of-wave score tally screen (showing counted missiles/cities), 1-player game high score function (displayed as player 2's score), and "paused" text (game sounds also cleared when pause is selected). It currently resides in just over 6k of space...so a Supercharger version could be made if a bit more optimizing is done. MCarcade.zip 1 Quote Link to comment Share on other sites More sharing options...
Atariboy2600 Posted July 28, 2006 Share Posted July 28, 2006 Could you be more specific? There are a couple of minor bugs in the program (these are detailed in the comments of the assembly)...but the program still runs. If it didn't, it wouldn't be posted...since I'm using the latest version of z26 to test it Current version adds the end-of-wave score tally screen (showing counted missiles/cities), 1-player game high score function (displayed as player 2's score), and "paused" text (game sounds also cleared when pause is selected). It currently resides in just over 6k of space...so a Supercharger version could be made if a bit more optimizing is done. I havein had any working emulator on linux so I cant play any 2600 games or any emulators for over a year, is there any screenshots of this game? Quote Link to comment Share on other sites More sharing options...
Rom Hunter Posted July 28, 2006 Share Posted July 28, 2006 Pressing fire pauses the game now. Is that right? I use the latest Z26 with Stelladaptor. Quote Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted July 28, 2006 Share Posted July 28, 2006 I havein had any working emulator on linux so I cant play any 2600 games or any emulators for over a year, is there any screenshots of this game? Both, z26 and Stella support Linux. Downloading and installing them is just a matter of 5 minutes. Quote Link to comment Share on other sites More sharing options...
Atariboy2600 Posted July 28, 2006 Share Posted July 28, 2006 I havein had any working emulator on linux so I cant play any 2600 games or any emulators for over a year, is there any screenshots of this game? Both, z26 and Stella support Linux. Downloading and installing them is just a matter of 5 minutes. Thats just in I dont know ANYTHINg about linux at all my roomate try to install but he said that the OS on the linux I have dont have all the files it needed to run any of them Quote Link to comment Share on other sites More sharing options...
Nukey Shay Posted July 28, 2006 Author Share Posted July 28, 2006 Pressing fire pauses the game now. Is that right? Yes...the left fire button is supposed to pause the game, because I changed the firing control to use the RIGHT joystick instead (that way, you get 3 fire buttons - one for each missile cache). That was the whole point to hacking it If you have a button controller like the Track and Field one, you can plug that into the second port. Left and right handle the corresponding edge caches, while down (or fire) handles the center one. The left controller fire button was no longer used, so I altered it to handle pause instead (the B/W switch is already being used to handle NTSC/PAL switching). Quote Link to comment Share on other sites More sharing options...
Rom Hunter Posted July 29, 2006 Share Posted July 29, 2006 Pressing fire pauses the game now. Is that right? Yes...the left fire button is supposed to pause the game, because I changed the firing control to use the RIGHT joystick instead (that way, you get 3 fire buttons - one for each missile cache). That was the whole point to hacking it If you have a button controller like the Track and Field one, you can plug that into the second port. Left and right handle the corresponding edge caches, while down (or fire) handles the center one. The left controller fire button was no longer used, so I altered it to handle pause instead (the B/W switch is already being used to handle NTSC/PAL switching). Got it. Missile Command Arcade ofcourse. Thanks, Nukey. Great Hack. Quote Link to comment Share on other sites More sharing options...
