attendo Posted July 29, 2005 Share Posted July 29, 2005 Batari is it possible to remove the code from the generated .asm (or kernel) for the score counter because Im not using it in the game im making and I gues by removing it it will save some cycles. Now I just am giving the score the same color as the background to make it invisible What code do I need to remove and how much cycles would It save? greets. Quote Link to comment Share on other sites More sharing options...
Tom Posted July 29, 2005 Share Posted July 29, 2005 Just curious if you think that all I need to include is the input file to lex in the source, or if the generated lex.yy.c file should be in there too for those who don't have lex? I.e. what's the "normal" thing to do? 899431[/snapback] The normal thing would be to distribute the grammar file, but not the generated code. Nothing that can be generated needs to be distributed (or even more silly, put under version control. I've seen people do that before...) Quote Link to comment Share on other sites More sharing options...
+batari Posted July 29, 2005 Author Share Posted July 29, 2005 Batari is it possible to remove the code from the generated .asm (or kernel) for the score counter because Im not using it in the game im making and I gues by removing it it will save some cycles. Now I just am giving the score the same color as the background to make it invisible What code do I need to remove and how much cycles would It save? greets. 900878[/snapback] You would remove everything from the comment ";6 digit score routine", down to, but not including "lda temp2" You would then need to change the lda #43 just below to something larger to compensate for the removed scanlines. I'm not sure what it should be offhand, maybe lda #56 would suffice. This should give an additional 750 cycles for your bB code. I think the above should work, but I haven't tested it. Quote Link to comment Share on other sites More sharing options...
attendo Posted July 29, 2005 Share Posted July 29, 2005 (edited) @batari Excellent it works ive attached the modified 2600basic.asm for others who dont need to use the score and spare some cycles. At first my game started to flicker (3 copied sprites(with NUSIZ1) + 1 sprite + pfpixels, etc.) but now its ok. 2600basic_asm_noscore.zip Edited July 29, 2005 by attendo Quote Link to comment Share on other sites More sharing options...
+batari Posted July 29, 2005 Author Share Posted July 29, 2005 batari, Please consider renaming the files for alpha 0.3 to 8.3 format...since it -is- a DOS program, it should be usable in pure DOS (without having to hex-edit the EXE ) 900413[/snapback] I called it a DOS program because it must be run at the Windows Command Prompt. 8+3 is SO limiting and outdated, I don't think I should change the expanding set of files to conform to this. I think a better solution is to quit calling it a DOS program but instead call it a Win32 command-line program. Quote Link to comment Share on other sites More sharing options...
Luigi301 Posted July 29, 2005 Share Posted July 29, 2005 Is 0.3 going to have ball and/or paddle support? I'm pretty far along in making a Breakout-style game and you can't have Breakout without a ball or paddle. Quote Link to comment Share on other sites More sharing options...
JLsoft Posted July 30, 2005 Share Posted July 30, 2005 (edited) I called it a DOS program because it must be run at the Windows Command Prompt. 8+3 is SO limiting and outdated, I don't think I should change the expanding set of files to conform to this. I think a better solution is to quit calling it a DOS program but instead call it a Win32 command-line program. ...it is an actual DOS program at the moment though, and runs just fine under pure DOS (except for the part about trying to call the variable redef file, which has a long filename) [EDIT] Annnnnd, never mind...I was thinking that it was packed along with the DOS port of DASM, but it's the Win32 console version...ignore! Edited July 31, 2005 by JLsoft Quote Link to comment Share on other sites More sharing options...
Luigi301 Posted July 31, 2005 Share Posted July 31, 2005 Is there a command to check whether a playfield pixel is on or not? Quote Link to comment Share on other sites More sharing options...
+batari Posted August 1, 2005 Author Share Posted August 1, 2005 Is there a command to check whether a playfield pixel is on or not? 901966[/snapback] No, but there will be soon... Quote Link to comment Share on other sites More sharing options...
kisrael Posted August 1, 2005 Share Posted August 1, 2005 that would be great...I have a few ideas where not having the screen memory be "write only" would be very useful, I'd have to keep track of less stuff using other variables... Quote Link to comment Share on other sites More sharing options...
JLsoft Posted August 1, 2005 Share Posted August 1, 2005 Is there a command to check whether a playfield pixel is on or not? 901966[/snapback] Attached is a (cycle-wasting, cringe-worthy) way I wrote up earlier to check for the playfield status...you can probably make it much better and use it in the meantime until an actual command is added PFTEST.TXT Quote Link to comment Share on other sites More sharing options...
Luigi301 Posted August 1, 2005 Share Posted August 1, 2005 I'm wasting enough scanlines as it is If you want to get into a scanline wasting war... rem row 1-1 - all bit reads except 6 and 7 are inverted if a(7) then pfhline 0 4 2 on if a(6) then pfhline 3 4 5 on if !a(5) then pfhline 6 4 8 on if !a(4) then pfhline 9 4 11 on if !a(3) then pfhline 12 4 14 on if !a(2) then pfhline 15 4 17 on if !a(1) then pfhline 18 4 20 on if !a(0) then pfhline 21 4 23 on rem row 1-2 - only 7-5 are used, 4-0 are ignored if !a(5) then pfhline 24 4 26 on if a(6) then pfhline 27 4 29 on if a(7) then pfhline 30 4 31 on Quote Link to comment Share on other sites More sharing options...
+Random Terrain Posted August 4, 2005 Share Posted August 4, 2005 Labels and Numbers While trying to finish the first version of my personal help file, I noticed that it might be nice to know if a label must start with a letter of the alphabet. I think at least one BASIC I used said that a label must not start with a number. Numbers could be mixed in anywhere after the first character though. Is Batari BASIC the same in that area? Quote Link to comment Share on other sites More sharing options...
+batari Posted August 4, 2005 Author Share Posted August 4, 2005 Labels and Numbers While trying to finish the first version of my personal help file, I noticed that it might be nice to know if a label must start with a letter of the alphabet. I think at least one BASIC I used said that a label must not start with a number. Numbers could be mixed in anywhere after the first character though. Is Batari BASIC the same in that area? 904284[/snapback] There is no such limitation for labels in bB. A label can have any combination of letters or numbers, even as the first character. You can use underscores too. The only limitations I can think of is that a label must not match a known keyword or any labels internal to bB (like start, kernel, etc.) For example, you can't name a label "next" or "pfpixel" A variable alias (i.e. with the dim statement), however, does need to start with a letter. Quote Link to comment Share on other sites More sharing options...
+Random Terrain Posted August 4, 2005 Share Posted August 4, 2005 There is no such limitation for labels in bB. A label can have any combination of letters or numbers, even as the first character. You can use underscores too. The only limitations I can think of is that a label must not match a known keyword or any labels internal to bB (like start, kernel, etc.) For example, you can't name a label "next" or "pfpixel" A variable alias (i.e. with the dim statement), however, does need to start with a letter. 904289[/snapback] Thanks. That will make things even more clear. Quote Link to comment Share on other sites More sharing options...
+Random Terrain Posted August 6, 2005 Share Posted August 6, 2005 Indenting To make sure I understand correctly, are labels, line numbers and end the only things that are not indented? Quote Link to comment Share on other sites More sharing options...
+batari Posted August 6, 2005 Author Share Posted August 6, 2005 Indenting To make sure I understand correctly, are labels, line numbers and end the only things that are not indented? 905519[/snapback] I think so. Though eventually I may remove the requirement for "end" so it can be intended or not. Quote Link to comment Share on other sites More sharing options...
+Random Terrain Posted August 6, 2005 Share Posted August 6, 2005 Indenting To make sure I understand correctly, are labels, line numbers and end the only things that are not indented? 905519[/snapback] I think so. Though eventually I may remove the requirement for "end" so it can be intended or not. 905538[/snapback] Thanks. That will be easy to remember. Quote Link to comment Share on other sites More sharing options...
attendo Posted August 8, 2005 Share Posted August 8, 2005 Perhaps its an ID to create a command to be placed in the beginning of the code which selects a kernel (like rem smartbranching on) For example: "rem kernel <default>" To select the default kernel "rem kernel <hi_res>" To select the hi_res_2600basic.asm & hi_res_2600basicfooter.asm Or something like that, this makes switching, using, trying out different kernels easier. Quote Link to comment Share on other sites More sharing options...
kisrael Posted August 8, 2005 Share Posted August 8, 2005 I'd like to mention I'm not a big fan of sneaking in smartbranching via a comment; if it impacts the code, it deserves to be its own command, same (even more so) for kernals. Quote Link to comment Share on other sites More sharing options...
attendo Posted August 8, 2005 Share Posted August 8, 2005 (edited) Well without the rem statement then that makes: "kernel <default>" "kernel <hi_res>" etc. Edited August 8, 2005 by attendo Quote Link to comment Share on other sites More sharing options...
potatohead Posted August 9, 2005 Share Posted August 9, 2005 I'd like to mention I'm not a big fan of sneaking in smartbranching via a comment; if it impacts the code, it deserves to be its own command, same (even more so) for kernals. 906942[/snapback] I'll second that. How about a general keyword for this kind of thing, followed by a list of arguments? config kernel <x> smartbranching on memorymodel 4k end That sort of fits with some other things in the language, cutting down on the number of different structures one has to know at least... Quote Link to comment Share on other sites More sharing options...
+batari Posted August 9, 2005 Author Share Posted August 9, 2005 I'd like to mention I'm not a big fan of sneaking in smartbranching via a comment; if it impacts the code, it deserves to be its own command, same (even more so) for kernals. 906942[/snapback] I'll second that. How about a general keyword for this kind of thing, followed by a list of arguments? config kernel <x> smartbranching on memorymodel 4k end That sort of fits with some other things in the language, cutting down on the number of different structures one has to know at least... 907319[/snapback] I can see the logic in not using smartbranching in a rem, but I'm still thinking of the best way to do things. Includes and some other compiler directives (like dim) do not affect the bB-to-asm compilation. smartbranching does affect the bB-to-asm, as will a future directive (a few revisions away) to specify optimization for speed or space, or to build an 8k bankswitched ROM (a few more revisions away). I like the idea of dim and include on their own rather than in a config block, and the others above could be passed as command-line arguments or allowed to be defined as special settings. Maybe a "set" command could be used to define things, kind of like setting an envorinment variable: set smartbranching off/on set romsize 2k/4k/8k set optimization size/speed If it's done this way, you can actually turn these on and off on the fly. For instance, if you want some code optimized for speed and some for space, you could change the optimization several times. Quote Link to comment Share on other sites More sharing options...
potatohead Posted August 9, 2005 Share Posted August 9, 2005 (edited) I'd like to mention I'm not a big fan of sneaking in smartbranching via a comment; if it impacts the code, it deserves to be its own command, same (even more so) for kernals. 906942[/snapback] I'll second that. How about a general keyword for this kind of thing, followed by a list of arguments? config kernel <x> smartbranching on memorymodel 4k end That sort of fits with some other things in the language, cutting down on the number of different structures one has to know at least... 907319[/snapback] I can see the logic in not using smartbranching in a rem, but I'm still thinking of the best way to do things. Includes and some other compiler directives (like dim) do not affect the bB-to-asm compilation. smartbranching does affect the bB-to-asm, as will a future directive (a few revisions away) to specify optimization for speed or space, or to build an 8k bankswitched ROM (a few more revisions away). I like the idea of dim and include on their own rather than in a config block, and the others above could be passed as command-line arguments or allowed to be defined as special settings. Maybe a "set" command could be used to define things, kind of like setting an envorinment variable: set smartbranching off/on set romsize 2k/4k/8k set optimization size/speed If it's done this way, you can actually turn these on and off on the fly. For instance, if you want some code optimized for speed and some for space, you could change the optimization several times. 907401[/snapback] I'm liking the set operator for all of these options. Being able to do things on the fly makes perfect sense where the 2600 is concerned. Games with different screens could use different kernels, for example. In this way bb might really make managing all of that quite easy actually. For what it's worth, both syntax ideas allow for these things, but your use of the set operator is less overall parsing and typing / formatting for the developer. Better overall, IMHO. Come to think of it, the overall concept of an environment is making a lot of sense actually. Set is familiar and easy. Why not? However it works, I would love to see everything necessary be part of the program source code file. Nice and self-documenting and easily packaged, etc... Edited August 9, 2005 by potatohead Quote Link to comment Share on other sites More sharing options...
danwinslow Posted August 9, 2005 Share Posted August 9, 2005 I'd vote for the set method too. Quote Link to comment Share on other sites More sharing options...
