problem with lesson 21
Hi
I added a picture to the program in tutorial 21 and I got an error.
vars                     0080                            0080
                             0000 ????                       0000 ????
RIOT                     0280                            0280
TIA_REGISTERS_READ       0000                            0000
TIA_REGISTERS_WRITE      0000                            0000
INITIAL CODE SEGMENT         0000 ????                       0000 ????
12 references to unknown symbols.
17 events requiring another assembler pass.
- Expression in mnemonic not resolved.
- Label defined after it has been referenced (forward reference).
Unrecoverable error(s) in pass, aborting assembly!
Complete.
Here the code:
; '2600 for Newbies
; Session 21 - Sprites
; This kernel draws a simple box around the screen border
; Introduces sprites
                processor 6502
                include "vcs.h"
                include "macro.h"
SpriteHeight = 8
                SEG.U vars
                ORG $80
SpriteXPosition ds 1
PlayerX         ds 2             ; x coordinate
PS_temp  ds 1
Sprite  ds 2
SpriteEnd ds 1
                SEG code
                ORG $F000
Reset
    ; Clear RAM and all TIA registers
                ldx #0
                lda #0
Clear           sta 0,x
                inx
                bne Clear
                ldx #$FF
                txs
        ; Once-only initialisation...
                lda #$45
                sta COLUPF              ; set the playfield colour
                lda #$56
                sta COLUP0
                lda #$67
                sta COLUP1
                lda #%00000001
                sta CTRLPF              ; reflect playfield
                lda #80
                sta PlayerX+1
  lda #60
  sta SpriteEnd
  lda #<Sprite0Data
      sta Sprite
      lda #>Sprite0Data
      sta Sprite+1
StartOfFrame
    ; Start of vertical blank processing
            lda #0
            sta VBLANK
            lda #2
            sta VSYNC
                ; 3 scanlines of VSYNCH signal...
                sta WSYNC
                sta WSYNC
                sta WSYNC
            lda #0
            sta VSYNC
            sta WSYNC
        ; 37 scanlines of vertical blank...
        ldx #0
VerticalBlank  sta WSYNC
        inx
        cpx #37 ; Now waiting 37 lines
        bne VerticalBlank
DrawField
        ldx #0         ; this counts our scanline number
;line 1 - score player 0
     lda #$90
     ;lda #$00
     ;sta COLUBK              ; set the background colour
     lda #%11111111
     sta PF0
     sta PF1
     sta PF2
linescr
      sta WSYNC
      inx
      cpx #16
      bne linescr
;ligne 1
     lda #$2E
     lda #$00
     lda #%11111111
     sta PF0
     sta PF1
     sta PF2
line1
      sta WSYNC
      inx
      cpx #24
      bne line1
;line 2a
     lda #$2E
     lda #$42
     lda #%00011000
     sta PF0
     lda #%0
     sta PF1
     sta PF2
line2a
      sta WSYNC
      inx
      cpx #168
      bne line2a
;line 2l
      lda #$2E
      lda #$00
      lda #%11111111
      sta PF0
      sta PF1
      sta PF2
line2l
      sta WSYNC
      inx
      cpx #176
      bne line2l
:Last line
      lda #$90
      lda #%0
      sta PF0
      sta PF1
      sta PF2
LastLine
      sta WSYNC
      inx
      cpx #192
      bne LastLine
                    ; again, we don't bother writing PF0-PF2 every scanline - they never change!
                sta WSYNC
MiddleLines
                TXA; transfer scanline count to A
   SEC; well for this example I don't know the state
        SBC SpriteEnd; so that's 96 - 96 = 0
  adc #SpriteHeight ;remember the sprite is 8 lines high
  bcc .skipMBDraw3 ;out of range???
  tay
  lda (Sprite),y   ; use indirect loading here
  sta GRP0
                ;sec ; 2  can often be guaranteed, and omitted
           ;tya ; 2
                ;sbc SpriteEnd ;3
           ;adc #SpriteHeight ;2
         ;bcs .MBDraw3      ;2(3)
         ;nop               ;2
         ;nop               ;2
         ;sec               ;2
         ;bcs .skipMBDraw3  ;3
.MBDraw3
          ;tay
                ;lda (Sprite),Y    ;5
         ;sta GRP0          ;3
.skipMBDraw3
                sta WSYNC
                ;inx
                dey
  dex
  bne MiddleLines
                lda #0
                sta GRP0
                sta GRP1
                lda #%01000010
                sta VBLANK ;end of screen - enter blanking
    ; 30 scanlines of overscan...
                ldy #0
  sty PF0
  sty PF1
  sty PF2
Overscan        sta WSYNC
                iny
                cpy #23
                bne Overscan
                inc SpriteEnd
  ldx SpriteEnd
  cpx #192
  bcc LT192
  ldx #0
  stx SpriteEnd
LT192
  ; Now adjust the sprite position
  inc PlayerX
  ldx PlayerX
  cpx #150
  bcc LT160
  ldx #0
  stx PlayerX
LT160
  dec PlayerX+1
  ldx PlayerX+1
  bne GT0
  ldx #150
  stx PlayerX+1
GT0
                jsr PositionSprites
                jmp StartOfFrame
PositionSprites
        ; Set the horizontal position of the two sprites, based upon their coordinates
        ; This uses the tricky 2600 method of positioning (RESPx, HMPx, etc)
        ; Algorithm invented a looong time ago by persons unknown
        ; Re-invented Feb2001 by yours truly, then optimised according to code by Thomas Jenztsch
        sta WSYNC
        sta HMCLR                       ; clear any previous movement
        ldx #2                          ; sprite index
PosSP
        lda PlayerX-1,x
        tay
        lsr
        lsr
        lsr
        lsr
        sta PS_temp
        tya
        and #15
        clc
        adc PS_temp
        ldy PS_temp
        cmp #15
        bcc NH
        sbc #15
        iny
NH
                ; Use remainder for fine adjustment
        eor #7
        asl
        asl
        asl
        asl
        sta HMP0-1,x                      ; fine movement
        sta WSYNC
        jsr Ret
        bit 0                           ; 15 cycles = 3 loops :)
Jiggle  dey
        bpl Jiggle
        sta RESP0-1,x
        dex
        bne PosSP
        sta WSYNC
        sta HMOVE
        sta WSYNC
        rts
Ret
rts
Sprite0Data
.byte #%00000000
.byte #%10101010
.byte #%01010101
.byte #%10101010
.byte #%01010101
.byte #%10101010
.byte #%01010101
.byte #%00000000
            ORG $FFFA
InterruptVectors
            .word Reset           ; NMI
            .word Reset           ; RESET
            .word Reset           ; IRQ
      END
Thanks in advance
Edited by Serguei2
Hi there!
Well, the actual errors were not in the lines you posted from the report, but straight above that:
test.s (169): error: Unknown Mnemonic 'Last'.
test.s (335): error: Unknown Mnemonic '#%00000000'.
test.s (336): error: Unknown Mnemonic '#%10101010'.
test.s (337): error: Unknown Mnemonic '#%01010101'.
test.s (338): error: Unknown Mnemonic '#%10101010'.
test.s (339): error: Unknown Mnemonic '#%01010101'.
test.s (340): error: Unknown Mnemonic '#%10101010'.
test.s (341): error: Unknown Mnemonic '#%01010101'.
test.s (342): error: Unknown Mnemonic '#%00000000'.
Basically you used : to uncomment a line instead of ; here
:Last line
and need to tab your table here:
.byte #%00000000
.byte #%10101010
.byte #%01010101
.byte #%10101010
.byte #%01010101
.byte #%10101010
.byte #%01010101
.byte #%00000000
Greetings,
Manuel
