Sign/unsign division?
Heaven/TQA
some of you might have seen the sinistar-like... thread in the homebrew forum...
i am just implementing my movements for the enemies into 6502 but i run into trouble as i haven't used signed fixed point maths (if ever needed...)
look what i am doing
* vex=(px-ex)/8
* vey=(py-ey)/8
* ex=ex+vex
* ey=ey+vey
calc ldx #3
lda px
sec
sbc ex
bmi calc_minus
clc
lsr @
lsr @
lsr @
sta vex
clc
adc ex
sta ex
rts
calc_minus clc
asl @
asl @
asl @
sta vex
clc
adc ex
sta ex
rts
what i am doing wrong as it does not work?
f.e. px-ex = 100-160 = -60 = $c4
now as its minus i will do *2 = $ff88 * 2 = $ff10 *2 = $fe20
so looking just at the low-byte = $20
but should it not be -60 div 8 = -7.5 = -7 = $f9????
what i am doing wrong?
What are you using "asl" for if this is supposed to be a divide-by-eight?
I would suggest something like the following:
idiv8: ; Divide the number in the accumulator by eight (signed)
 cmp #128
 bcc div8cc ; Value in Acc less than 128
 adc #$02 ; Carry is set, so we're adding 3
 bcs div8ccnr
 lsr
 lsr
 lsr
 ora #$E0
 rts
div8cc:
 adc #4
div8ccnr:
 lsr
 lsr
 lsr
 rts
Perhaps not quite optimal, but it should yield symmetrically-rounded results.
Huhu!
-1 = 255 = 11111111
-2 = 254 = 11111110
-4 = 252 = 11111100
Ähm, das IST links, Manuel. ;)
894889[/snapback]
Öhm... schlaft ihr heute alle, oder was? :P
Um von -4 auf -2 zu kommen, muss man nach rechts schieben (SEC + ROR um genau zu sein) und das Ganze nennt sich dann Division durch 2.
Grüße,
Manuel
Ach soooo.
Ich hatte übersehen, dass du seit Neuestem von unten nach oben liest. ;)
100 - 160 = -60 = $c4 (bzw. $ffc4)
Teilen durch 8: 3 x lsr (und dabei jeweils das Vorzeichen-Bit in's MSB kopieren) = $f8 (bzw. $fff8) = -8
; 8 bit math
 lda px
 sec
 sbc ex
 cmp #$80
 ror
 cmp #$80
 ror
 cmp #$80
 ror
Edited by Thomas Jentzsch
; 8 bit math
 lda px
 sec
 sbc ex
 cmp #$80
 ror
 cmp #$80
 ror
 cmp #$80
 ror
894941[/snapback]
Can I get a translation, please? :) This looks interesting...
EDIT: Actually, I think I got it - the cmp #$80 ror sequence divides a number of either sign by 2 and preserves the sign: -100 -> -50 or 64 -> 32. Right? And tricksy, it is...
Edited by vdub_bobby
895281[/snapback]
http://translate.google.com/translate?u=ht...Flanguage_tools
Ach du lieber!
895293[/snapback]
Ummm...thanks, I guess. :ponder:
:D
Best translation was this:
Ach soooo.
To this:
Oh soooo.
I had surveyed that you since newest one from down upward reads.
That's a rounding problem.
I'm just saying is all. :D It's a slick routine, it just won't take a negative number to zero.
here is the atari800 code in xasm format:
* Enemy Engine - Test
pmbase	equ $8000
p0  equ $8400
 org $4000
init	ldx #3
init0	lda 53770
 sta ex,x
 lda 53770
 sta ey,x
 lda #0
 sta 53256,x
 lda #15
 sta 704,x
 dex
 bpl init0
 lda #>pmbase
 sta 54279
 lda #3
 sta 53277
 ldx #0
 txa
init1	sta p0,x
 sta p0+256,x
 sta p0+512,x
 sta p0+758,x
 inx
 bne init1
 lda #62
 sta 559
 lda #8
 sta 704
 lda py
 sta oldpy
 lda ey
 sta oldey
main_loop jsr wait_vbl
 jsr calc
 jsr get_stick
 jsr set_pm
 inc count
 bpl main_loop
 lda #0
 sta count
 lda 53770	;random
 sta ex
 lda 53770
 sta ey
 jmp main_loop
wait_vbl	lda #1
 sta 540
wait0	lda 540
 bne wait0
 rts
set_pm	lda #0
 ldx oldpy
 ldy #7
clear0	sta p0,x
 inx
 dey
 bpl clear0
 ldx oldey
 ldy #7
clear1	sta p0+256,x
 inx
 dey
 bpl clear1
 lda py
 sta oldpy
 lda ey
 sta oldey
 ldy #7
 ldx py
 lda px
 sta 53248	;hposp0
set0	lda shape0,y
 sta p0,x
 inx
 dey
 bpl set0
 ldy #7
 ldx ey
 lda ex
 sta 53249	;hposp1
set1	lda shape1,y
 sta p0+256,x
 inx
 dey
 bpl set1
 rts
;* Joystick routine
get_stick  lda 632	;stick0
          tay
get_stick1 and #$f8     ;right?
          beq stick_r
          tya
get_stick2 and #244     ;left?
          beq stick_l
get_stick0 tya
get_stick3 and #241      ;up?
          beq stick_u
          tya
get_stick4 and #242      ;down?
          beq stick_d
joy_end    rts
stick_r	inc px
 rts
stick_l dec px
 rts
stick_u dec py
 rts
stick_d	inc py
 rts
* vex=(px-ex)/16
* vey=(py-ey)/16
* ex=ex+vex
* ey=ey+vey
calc	lda px
 sec
 sbc ex
 cmp #$80
 ror @
 cmp #$80
 ror @
 cmp #$80
 ror @
 cmp #$80
 ror @
 clc
 adc ex
 sta ex
 lda py
 sec
 sbc ey
 cmp #$80
 ror @
 cmp #$80
 ror @
 cmp #$80
 ror @
 clc
 adc ey
 sta ey
 rts
shape0	dta %00000000
 dta %01111110
 dta %01111110
 dta %01111110
 dta %01111110
 dta %01111110
 dta %01111110
 dta %00000000
shape1                 dta %00000000
 dta %10000001
 dta %01000010
 dta %00100100
 dta %00011000
 dta %00011000
 dta %00000000
 dta %00000000
vex  dta 0,0,0,0
vey  dta 0,0,0,0
ex  	dta 0,0,0,0
ey  dta 0,0,0,0
px  dta 100
py  dta 100
oldpy	dta 0
oldey	dta 0
count	dta 0
 run init
should be understandable...
thomas... your 8bit version seems too fast when moving objects around...the player seems not to have a chance to escape (check it on yourself in a 2600 prototype).
so i guess we need 4.4 or 8.8 fixed point maths...what do you think? and if so...how would you handle that in your code? (i just woke up so my 6502 knowledge is not booted yet... ;))
Huh? How can the code be too fast? :?
If 4.4 doesn't do the job, try something like 3.5 or 2.6. Or switch to 8.8 which is pretty easy to implement.
re: fast...
try to put the code into a 2600 kernel and you know what i mean...
i am doing a random repositioning of the player every 16 VBLs. every slower repositioning leads to that the enemy is catching the player in miliseconds...
of course i could do a slower moving of the enemy, f.e. every 25th second or 12... (2nd/3rd frame) but this looks strange and not very professional...
so i guess i have to go with 4.4 as next try.
Sorry, but I am completely lost. What do you mean? Which kernel? Which enemies? How are they moving :? :? :? (I must have missed something :ponder: )
BTW: What are VBLs? vertical blanks = frames?
thomas, i mean you are a wizard and should be able to code a simple 2600 demo with the formulars i have described.
one random position where an enemy sprite is moving to. you can do it simply on 2600 as well... then you are realising that the enemy is moving very very fast towards the desired position... ;)
in german:
was ich meinte, da dir 2600 so am herzen liegt, solltest du doch sehr schnell eine mini-demo auf 2600 basis machen können, um dieses tracking der feinde anhand eines player-sprites zu testen... (oder kannste auch auf 800??? ;)) das meinte ich, das enemy sprite fliegt zuuu schnell auf den spieler zu, zwar korrekt aber definitiv zu schnell... und das liegt meiner meinung nach an der fehlenden genauigkeit und den rundungen. daher meine idee der fixed point math. eine verlangsamung durch d.h. bewegen alle 2. oder 3. VBI/frame sieht kacke aus...
It looks to me like you are taking the difference between the enemy position and the player position, dividing that by 8, and adding it to the enemy position. Depending on how often you run the routine, that will be impossibly fast - using some kind of fractional position (8.8 fixed would probably be easiest) is probably a necessity.
Ok, now I understand.
I suggest to use 8.8 maths for position and speed. 4 bytes for x and y each. If the maximum speed is smaller than 0.5 pixel/frame, then you only need 3 bytes each.
Then for the movement you could simply do:
  lda xSpeedLo
 clc
 adc xPosLo
 sta xPosLo
 lda xSpeedHi
 adc xPosHi
 sta xPosHi
