Cybergoth Posted September 4, 2005 Share Posted September 4, 2005 Hi there! manuel, coming from atari 800 with 4 players instead of 2600 2... i am playing around with this kind of sprite engine for couple of years... is your approach suitable for 4 hardware sprites as well or is it optimised for 2600 only? Hm... rather *compromised* than optimized Well, generally it should work with 4 hardware sprites as well. A lot better actually, as you wouldn't run into the "3 sprites worst case" scenario we've been discussing for the 2600 right now. I'd let it run for 4 iterations of the Bubble Sort each frame. With more RAM you can optmize the sorting by using index values. This'll immensly speed it up. After the 4 iterations you then need to swap all data only once according to the resulting indexes. (Maybe the 800 has even enough horsepower to handle quick repositionings via indexing, so you might even get away completely without swapping any data.) Another thing that may change on the 800 is the "magic" value in the line SBC #$03 This value adjusts the compare because the VCS needs 2 lines to reposition and because I ignore the carry in the subtractions (2+1). Greetings, Manuel Quote Link to comment Share on other sites More sharing options...
Heaven/TQA Posted September 4, 2005 Share Posted September 4, 2005 i'll play around with my code... here is the actual sorting version: ;"Dragon Breed" sorting routine ; www.student.oulu.fi/~loorni/covert/rants/sprite.htm ;sprite sorter sprite_sort lda #1 ;by default all sprites visible ldx #max_sprites-1 sort00 sta sortsprvisible,x- sta line,x bpl sort00 ldx #0 sortloop ldy sortorder+1,x lda spry,y ldy sortorder,x cmp spry,y bcs sortskip stx sortreload+1 sortswap lda sortorder+1,x sta sortorder,x sta temp2 tya sta sortorder+1,x ; lda temp2 ;really necessary? ; sty sortorder+1,x not available on atari just c64 cpx #0 beq sortreload dex ldy sortorder+1,x lda spry,y ldy sortorder,x cmp spry,y bcc sortswap sortreload ldx #0 sortskip inx cpx #max_sprites-1 bcc sortloop ;now copy sprite variables to the sorted table ;sprites must be rejected who want to be on the same scanline ;copy the 1st 4 virtual sprites as they are accepted anyway to the ;4 hardware sprites ldx #0 ldy sortorder lda spry,y sta sortspry lda sprx,y sta sortsprx lda sprc,y sta sortsprc inx ldy sortorder,x lda spry,y sta sortspry,x lda sprx,y sta sortsprx,x lda sprc,y sta sortsprc,x inx ldy sortorder,x lda spry,y sta sortspry,x lda sprx,y sta sortsprx,x lda sprc,y sta sortsprc,x inx ldy sortorder,x lda spry,y sta sortspry,x lda sprx,y sta sortsprx,x lda sprc,y sta sortsprc,x inx sort3 ldy sortorder,x lda spry,y sta sortspry,x sub spry-4,y ;actual position - 8 pixel (y-size of sprite) cmp #8 bcs sort4 ;reject if less than 8 scanlines ypos=0=invisible lda #0 ;move off the screen sta sortsprvisible,x sta line,x sort4 lda sprx,y sort6 sta sortsprx,x lda sprc,y sta sortsprc,x inx cpx #max_sprites bcc sort3 rts Quote Link to comment Share on other sites More sharing options...
Heaven/TQA Posted September 4, 2005 Share Posted September 4, 2005 and as most of you are not familiar with atari800win or 800 anyway here is a screenshot: the white rasterlines are indivators where a so called DLI (Display List Interrupt) is set. so at this screen position we are doing a complete repositioning of the 4 hardware sprites... the players are filled with chars "A"... to make them visible... these DLIs are set dynamicly each VBL based on the sorted y-sprite list... the only issue which is not implemented yet into my engine is the fact that rejected sprites (5th,6th,... sprite on the same scanline or overlapping) are really rejected so not visible at all until they can be displayed without any overlapping... so no inteligent flicker algorithm working yet... and that's my search for the holy grail... Quote Link to comment Share on other sites More sharing options...
