Student Driver Posted November 26, 2005 Share Posted November 26, 2005 Got a 3DO the other week (after years of wanting one) for free... an FZ-1, a single controller, a copy of Demolition Man, and a copy of The 3DO Game Guide. On testing, Demolition Man doesn't seem to work. I believe the system's fine and the game might be at fault due to the following: - The system seems to power up normally with no disc in the drive, eventually going to the asteroid-filled demo scene. Therefore, I believe the system's powering up normally, with no glitches. - The system plays music CDs (a little less impressive than a VLM, but hey), therefore the laser, CD mechanism, etc., seem to be working okay. - The system spends a while attempting to read the Demolition Man CD, with the laser mechanism making a seeking sound reminiscent of an out-of-alignment laserdisc player, ejecting the disc after a minute or so. The game isn't scratched up, but I unfortunately have no other 3DO in which to test the thing... are the above conditions sufficient for me to infer that the FZ-1 is working (and thus go on a shopping spree for games on eBay), or do FZ-1 systems routinely break down part-way, booting up and playing music CDs, but not able to play 3DO titles? Quote Link to comment Share on other sites More sharing options...
oesii Posted November 26, 2005 Share Posted November 26, 2005 I would guess that the FZ-1 which is usually solid is working and that you have a defective disk. Do you have a CD burner? There's tons of 3DO games on the newsgroups and on the web that you can burn onto a CD-R and play with no mods necessary. But most 3DO games are dirt cheap anyways you could always spend less than $5 on one and try it out. Quote Link to comment Share on other sites More sharing options...
glitch Posted November 27, 2005 Share Posted November 27, 2005 The CDR idea isn't a bad one, it may save you from buying games for a faulty system. One note though is that the FZ-1 can be a bit touchy w/ some CDRs for some reason. My FZ-1 will only play about 50% of the CDR discs my FZ-10 will play so you may want to try a couple before giving up. Quote Link to comment Share on other sites More sharing options...
Student Driver Posted November 29, 2005 Author Share Posted November 29, 2005 I don't have easy access to a CD burner, but have friends who might... on the touchiness of CD-Rs, might using CD-RWs work better? I've often heard that CD-RWs often work in, say, DVD or CD players, where standard CD-Rs won't work. Quote Link to comment Share on other sites More sharing options...
glitch Posted November 30, 2005 Share Posted November 30, 2005 Not sure since I've never tried it. Since it's a thicker media it may work better. I've had better luck w/ the slower rated CD-Rs than the faster rated ones. 4x CD-Rs seem to work very well. I believe it may be due to the fact that it's an older laser lens and requires more reflection than a lot of discs now have. I've had similar problems w/ PCs w/ very old CD Rom drives. If you send me a PM I can probably send you a couple that work in my FZ-1. Quote Link to comment Share on other sites More sharing options...
Atariman Posted January 4, 2008 Share Posted January 4, 2008 Sorry to dig up an old thread, but my 3DO is having the same issue that Student Driver is describing. It isn't an FZ-1 (it's an FZ-10) and hasn't had issues with game discs in the past. It wouldn't play the one I popped in there awhile ago and when I tried the one that I had left in there the last time I played it, it wouldn't play, either. It does play music CDs like a champ, though. All I have noticed is that when it is trying to read a game disc, it makes a noise that sounds like a rattle. It picks right up that it is a game disc, but once it gets to the 3DO boot screen, it just hangs there while making this "rattle" noise. Any other ideas? Quote Link to comment Share on other sites More sharing options...
