Help! Broken Joystick
Please help. During a vigorous Outlaw session, my friend snapped the joystick lever clear off. It turns out that it screws in, and I was able to disassemble the thing and get the threads that remained inside out.
Now my problem is finding a replacement 'stick'. I don't need the whole joystick proper, just the screw in part. Any advice? Thanks in advance.
Jeepers, that's pretty dang vigorous...
The cheapest fix would be to tell your friend to buy you another CX-## joystick off of Ebay.
Edited by ls650
Do you mean a CX-10 or a CX-40?  The CX-10 is the original 1977 controller, and from what I understand it's pretty hard to find.  The CX-40 was the later model and can still be commonly found at a good price.
997510[/snapback]
yep, thats what i meant. then again, if he can make his friend buy him the 77's....by all means. :D
They tend to come loose when I use them. I'm thinking of taking the opportunity to make different handles, like some that are shorter with a 1" knob on top. I still have one of my orig 1978 sticks that I did this to back in 1980-ish and it works great.
You may want to take it to a hardware store and see what (if any) threads fit it.
I must be tough on Flashback sticks, 'cause I snapped the stick off of one (leaving the threaded part broken off in the base) and another one works, but sounds like a maracca, because the little plastic tabs around the edge of the plastic part that presses the contacts inside have broken.
May be just as easy t get another FB2. you get two new sticks for prices comparable to or better than you might find for used sticks on Ebay, and a new console to boot.
