+warerat Posted April 7, 2006 Share Posted April 7, 2006 (edited) Well I got a prototype slot 3 MyIDE board sort of working in my 800. The third slot on the 800 has two I/O selects, $D5XX and $D6XX, so this is connected to the $D5XX line. It is a two-chip variety MyIDE (replaced the 74F32 and 74F04 with a single 74F00) and it's mounted on an 8-bit baby protoboard. It's for the Commodore machines, but the VIC-20 slot has the right 44-pin connector for the 800. I wanted to have an internal IDE disk, and there's plenty of space on the card to hold everything. Good news is, the MyIDE FDISK recognizes an external drive. Bad news is, I don't think this PQI CF card is compatible, because I get "FATAL ERROR READING DRIVE". I'm trying to dig up some old spare IDE drives I had somewhere to see if it's working. I can read/write data at the register level, so something is working or at least halfway working. Anyone had any luck using this brand of CF cards? Edited April 7, 2006 by warerat Quote Link to comment Share on other sites More sharing options...
Almost Rice Posted April 7, 2006 Share Posted April 7, 2006 I have 2 different CF drives you can try. Quote Link to comment Share on other sites More sharing options...
MEtalGuy66 Posted April 10, 2006 Share Posted April 10, 2006 Thats a kewl looking prototyping card. I wish they made those for the XE PBI slot. Quote Link to comment Share on other sites More sharing options...
crash Posted April 10, 2006 Share Posted April 10, 2006 Are you using the 800's stock OS, or a patched version? Quote Link to comment Share on other sites More sharing options...
+warerat Posted April 10, 2006 Author Share Posted April 10, 2006 (edited) Thats a kewl looking prototyping card. I wish they made those for the XE PBI slot. They're 8-bit baby boards from www.c64reloaded.com. They fit pefectly into the 800. I'm going Dremel off one of the connectors off the side that has the same pitch as the cart slot. Then I'll have a gold edge connector with the holes I can use for the ECI. I bought a pair of these for $12 each shipped off eBay. Edited April 10, 2006 by warerat Quote Link to comment Share on other sites More sharing options...
+warerat Posted April 10, 2006 Author Share Posted April 10, 2006 Are you using the 800's stock OS, or a patched version? I'm using the patched XL OS. http://www.atariage.com/forums/index.php?showtopic=84836 I advised Almost Rice to use his Mosiac 32K board in the middle slot to free up the last slot, as I already made him an XL OS for his 800. Quote Link to comment Share on other sites More sharing options...
+warerat Posted April 10, 2006 Author Share Posted April 10, 2006 (edited) Good news is, the MyIDE FDISK recognizes an external drive. Bad news is, I don't think this PQI CF card is compatible, because I get "FATAL ERROR READING DRIVE". I'm trying to dig up some old spare IDE drives I had somewhere to see if it's working. I can read/write data at the register level, so something is working or at least halfway working. Anyone had any luck using this brand of CF cards? I figured out my problem, I had the data bus inverted (D0->D7, D1->D6, etc). It works great now. For those that are interested, if you want to build a MyIDE with only two chips ('LS245 & 'F00), wire the 74F00 to generate IOR_ and IOW_ as follows: 1 RW_ 2 (tie to pin 1) 3 DIR 4 (tie to pin 3) 5 PHI2 6 IOW_ 7 GND 8 N/C 9 N/C 10 N/C 11 IOR_ 12 PHI2 13 RW_ 14 +5V DIR goes to the 'LS245. Pin 6 goes to IDE pin 25, pin 11 goes to IDE pin 23. Common connections are pins 1,2,13 to RW_, 5,12 to PHI2, and 3,4 to DIR. Equivalent circuit, just less parts. Edited April 10, 2006 by warerat Quote Link to comment Share on other sites More sharing options...
a8isa1 Posted April 21, 2006 Share Posted April 21, 2006 Good news is, the MyIDE FDISK recognizes an external drive. Bad news is, I don't think this PQI CF card is compatible, because I get "FATAL ERROR READING DRIVE". I'm trying to dig up some old spare IDE drives I had somewhere to see if it's working. I can read/write data at the register level, so something is working or at least halfway working. Anyone had any luck using this brand of CF cards? I figured out my problem, I had the data bus inverted (D0->D7, D1->D6, etc). It works great now. For those that are interested, if you want to build a MyIDE with only two chips ('LS245 & 'F00), wire the 74F00 to generate IOR_ and IOW_ as follows: 1 RW_ 2 (tie to pin 1) 3 DIR 4 (tie to pin 3) 5 PHI2 6 IOW_ 7 GND 8 N/C 9 N/C 10 N/C 11 IOR_ 12 PHI2 13 RW_ 14 +5V DIR goes to the 'LS245. Pin 6 goes to IDE pin 25, pin 11 goes to IDE pin 23. Common connections are pins 1,2,13 to RW_, 5,12 to PHI2, and 3,4 to DIR. Equivalent circuit, just less parts. Some newbie questions if you don't mind... - Will this work for an 800XL? - Where do I find "DIR"? I don't see it on the 800/800XL schematics nor in the IDE specification. - I assume connections A0 thru A2 and D0 thru D7 must still be made. Is this correct? - Steve Sheppard Quote Link to comment Share on other sites More sharing options...
+warerat Posted April 21, 2006 Author Share Posted April 21, 2006 Good news is, the MyIDE FDISK recognizes an external drive. Bad news is, I don't think this PQI CF card is compatible, because I get "FATAL ERROR READING DRIVE". I'm trying to dig up some old spare IDE drives I had somewhere to see if it's working. I can read/write data at the register level, so something is working or at least halfway working. Anyone had any luck using this brand of CF cards? I figured out my problem, I had the data bus inverted (D0->D7, D1->D6, etc). It works great now. For those that are interested, if you want to build a MyIDE with only two chips ('LS245 & 'F00), wire the 74F00 to generate IOR_ and IOW_ as follows: 1 RW_ 2 (tie to pin 1) 3 DIR 4 (tie to pin 3) 5 PHI2 6 IOW_ 7 GND 8 N/C 9 N/C 10 N/C 11 IOR_ 12 PHI2 13 RW_ 14 +5V DIR goes to the 'LS245. Pin 6 goes to IDE pin 25, pin 11 goes to IDE pin 23. Common connections are pins 1,2,13 to RW_, 5,12 to PHI2, and 3,4 to DIR. Equivalent circuit, just less parts. Some newbie questions if you don't mind... - Will this work for an 800XL? - Where do I find "DIR"? I don't see it on the 800/800XL schematics nor in the IDE specification. - I assume connections A0 thru A2 and D0 thru D7 must still be made. Is this correct? - Steve Sheppard Sure, except that the connections to the bus are different. DIR is on the 'LS245. Look at: http://www.mr-atari.com/myide.htm for step-by-step. This is just the same thing but customized to interface with the 800 memory slot. Quote Link to comment Share on other sites More sharing options...
a8isa1 Posted April 21, 2006 Share Posted April 21, 2006 Thanks but I already tried that interface. I couldn't get it to work. I was hoping I might have better luck with your two chip variation. - Steve Sheppard Quote Link to comment Share on other sites More sharing options...
doctorclu Posted April 28, 2006 Share Posted April 28, 2006 Naturally I will LOVE to have this to accompany the CX802 stuff I just got. Got to have a matching set. Let's see, the XL ram board you deemed the CX802. We figured the 512K ram module would have been CX858. And based on our homework of the CX8XX numbers... http://www.atariage.com/forums/index.php?s...83354&hl=cx-858 X-800 Computer * CX-800-DS Developers System CX-801 10K Rom OS * CX-801P 10 Rom OS (Pal) CX-810 Floppy Drive CX-815 Dual Disk System * CX-816/817 Prototypes CX-820 Drum Printer I would call the MyIde board for the 800.. well it is a personality board, which generally fall into the CX801-CX809 range. But it is drive related, which falls into the CX-810-CX819 range. (Printers follow that). So I would suggest a good number for this, if you want to assign it a fun number would be either CX-809 (a card verging on drive interface), or CX811 (which would be a fun tribute to the CX-810 drive.) What can I say? I love the beige stuff, and I love to work all this in somehow. And if this works nearly as well as the CX802 or CX858 from Warerat, we definately need to bring it in properly. Quote Link to comment Share on other sites More sharing options...
Curt Vendel Posted March 31, 2007 Share Posted March 31, 2007 Well, if we maintain the logic of the numbering for Atari add-ons and peripherals: 801-809 would be for OS/Personality Cards 810-819 would be for disk storage 820-829 would be for printers 830-839 modems 840-849 is OPEN - no relevant peripherals occupy this range 850 Interface 851-859 Memory: 851 - 4K 852 - 8K 853 - 16K 854 - 32K 855 - 64K 856 - 128K 857 - 256K 858 - 512K 859 - 1MB 860-869 - CP/M, alternate CPU systems - Atari 1060 "Sweetpea" CP/M box and 1066 CP/M card for 1090 were designated in this range. 870-879 Potential for being Hard Drive range 880-889 Atari 1080 "Classnet" (More info to follow shortly on this) was a networking system developed by Atari, only deployed internally in the Classnet Lab. 890-899 Expansion System & card (Atari 1090 XL Expansion box used the xx90 designation So a HD box (SIO2IDE or SIO2SD) could be an Atari 840 or 1040, but having a number lower then the 1050 disk drive doesn't seem appropriate, so either a 870 or 1070 would seem appropriate. CUrt Naturally I will LOVE to have this to accompany the CX802 stuff I just got. Got to have a matching set. Let's see, the XL ram board you deemed the CX802. We figured the 512K ram module would have been CX858. And based on our homework of the CX8XX numbers... http://www.atariage.com/forums/index.php?s...4&hl=cx-858 X-800 Computer * CX-800-DS Developers System CX-801 10K Rom OS * CX-801P 10 Rom OS (Pal) CX-810 Floppy Drive CX-815 Dual Disk System * CX-816/817 Prototypes CX-820 Drum Printer I would call the MyIde board for the 800.. well it is a personality board, which generally fall into the CX801-CX809 range. But it is drive related, which falls into the CX-810-CX819 range. (Printers follow that). So I would suggest a good number for this, if you want to assign it a fun number would be either CX-809 (a card verging on drive interface), or CX811 (which would be a fun tribute to the CX-810 drive.) What can I say? I love the beige stuff, and I love to work all this in somehow. And if this works nearly as well as the CX802 or CX858 from Warerat, we definately need to bring it in properly. Quote Link to comment Share on other sites More sharing options...
Shawn Jefferson Posted March 31, 2007 Share Posted March 31, 2007 Cool! Does my software (see link below) work with this MyIDE board? I don't see why it wouldn't since the board should be detected as an external MyIDE interface, right? Quote Link to comment Share on other sites More sharing options...
