Portfolio Card-Drive HPC 301 conversion
Beetle
Hi
i got this for cheap on eBay:
The main part:
Main part opened, shield removed:
Got rid of some components:
Clearing up some space:
A piece of epoxy glued under the original board:
SIO-ports added:
CF2IDE adaptor mounted:
Paintjob done and the SIO2IDE 3.3a Interface mounted:
The completed CF-carddrive for Atari 8-bit computers:
So, what do you think?
Greets,
Beetle
Thats a good thought in principle, but i don't own a Portfolio, and the ISA Card to which the HPC301 was connected to, only has drivers for DOS/Windows 3.1x. It simly doesn't work on actual computers/OS. My PC doesn't even have an ISA Slot...
Yes, the interface is home made. Instructions on the SIO2IDE interface you can find here: http://atariarea.krap.pl/sio2ide/
Greets,
Beetle
Edited by Beetle
Very cool. I like it. You could use the 300 baud XE modem case as well. You might also be able to use the 1200 baud xe/st modem for a SIO2IDE harddrive although it might be low.
Allan
Yeah, the XM301 is a lot more common and nearly useless for any other purpose. I have 4 laying around. You would have to make a hole for the CF card though.
Allan
Yea, I did just that a couple of weeks ago.
took a xm301 case, cut a slot for the CF card with a dremmel tool and some small files, installed a 5v regulator for the CF adapter, and ran a ribbon cable to a MAX Flash / MyIDE Cart. The thing runs off a 9V "wall Wart" power adapter. It looks way cool next to my 130XE
  • 2 years later...
Nice. Very nice!
I would have just left the cardbus slot and used an CF2cardbus adaptor. These are just straight through wires anyway. This way you could save removing that part of the board and just wire directly up to the DB port.
  • 11 years later...
On 6/2/2006 at 5:34 AM, pseudografx said:
A very nice idea, though personally I would be sorry for sacrificing the original innards. Perhaps it would be better to save the original board and just replace it with a new one so that you could always restore the unit for its original use?
Boy howdy.  I'd sure like that HPC-301, card and all.  If the fellow still has it, I'll give it a good home.
  • 2 weeks later...
