Josh Posted August 9, 2006 Share Posted August 9, 2006 (edited) This Morning when i turned on my apple IIe the fan started making weird noises and then it sounded like the fan just completely came off! what do i do? Edit: i looked inside and the fans cracked in half Edited August 9, 2006 by Josh Quote Link to comment Share on other sites More sharing options...
+FujiSkunk Posted August 9, 2006 Share Posted August 9, 2006 This Morning when i turned on my apple IIe the fan started making weird noises and then it sounded like the fan just completely came off! what do i do? Edit: i looked inside and the fans cracked in half A stock Apple IIe doesn't have a fan (if I'm remembering correctly). Unless you have a non-stock power supply and/or a lot of add-on cards, it will probably run just fine without the fan. Quote Link to comment Share on other sites More sharing options...
Prodos8 Posted August 9, 2006 Share Posted August 9, 2006 Yes, they don't come with fans. Maybe you've got an external fine (like a System Saver) attached or someone has added a fan to it somehow?? Anyway, It'll run fine without a fan, unless you've got a buttload of expansion cards installed. Quote Link to comment Share on other sites More sharing options...
shadow460 Posted August 9, 2006 Share Posted August 9, 2006 Make sure you disconnet the power lines to the fan, though. I'd also remove the broken pieces from your computer. Quote Link to comment Share on other sites More sharing options...
Josh Posted August 9, 2006 Author Share Posted August 9, 2006 Yeah i have a buttload of cards (Every slot filled) Quote Link to comment Share on other sites More sharing options...
