+atari2600land Posted September 23, 2006 Share Posted September 23, 2006 Upset that Grover's Music Maker was never released, I decided to make my own little program in Batari BASIC. This is different than Grover's. This is more like a piano. See, there's this little guy that runs across 8 different keys, and when you press fire, he makes the key play, and once you depress fire, the note stops playing. At least, that's how I want it to go anyway. Here's what I have so far: 2 set kernel_options pfcolors 100 for a=0 to 10 : pfhline 0 a 31 off : next 105 for b=0 to 7 : pfhline 0 b 4 on : next 110 COLUBK=128 120 player0: %00110110 %00100100 %00111100 %01111110 %10111101 %00100100 %00111100 end 122 pfcolors: 14 14 14 14 14 14 14 14 0 0 0 end 125 x=45 : c=0 : d=0 137 if c=1 && d=0 then AUDV0=6 : AUDC0=12 : AUDF0=9 if c=1 && d=1 then AUDV0=6 : AUDC0=12 : AUDF0=11 if c=1 && d=2 then AUDV0=6 : AUDC0=12 : AUDF0=13 138 player0x=x : player0y=y : COLUPF=14 : COLUP0=32 142 if d=0 then goto 144 144 drawscreen : y=8 : d=0 if c=0 && joy0fire then c=1 : goto 137 goto 137 With this, once you press fire, the note keeps on playing whether you keep pressing fire or not. The question is: where do I put "if c=1 && joy0fire then c=0"? And if c=0 that means AUDV0=0, too. d=0 means do, d=1 means ti, d=2 means la, etc. Quote Link to comment Share on other sites More sharing options...
+atari2600land Posted September 23, 2006 Author Share Posted September 23, 2006 I've decided to just start all over again from scratch and not even try to make any sort of code (past what I've just posted) until I can get this question answered: How can I get player0 to go from key to key? I've tried dozens of ways and nothing seems to work. I figure y=8 is on the first key (line), and go by incriments of 8 down until key 8 (which would be 64). This is way harder than I thought it would be. musicmaker.bas Quote Link to comment Share on other sites More sharing options...
SeaGtGruff Posted September 23, 2006 Share Posted September 23, 2006 I've decided to just start all over again from scratch and not even try to make any sort of code (past what I've just posted) until I can get this question answered: How can I get player0 to go from key to key? I've tried dozens of ways and nothing seems to work. I figure y=8 is on the first key (line), and go by incriments of 8 down until key 8 (which would be 64). This is way harder than I thought it would be. That should have worked (it did for me), but it would also depend on where you incremented or decremented y in the loop. However, I moved the keys down 1 row, and used player1 to add the black keys, then added 2 data arrays to control the x and y position of player0, so player0 can jump from the white keys to the black keys. You can add another data array for the tones. I also made player0 brighter to help it show up better. MR musicmaker2.bas Quote Link to comment Share on other sites More sharing options...
+atari2600land Posted September 23, 2006 Author Share Posted September 23, 2006 (edited) Without seeing SeaGtGruff's wonderful example (which I may have to use), I came up with this crude little thing. It doesn't work perfect, but what projects of mine do? Notice the faint electronic "ehhhhhhh" sound when you play a note. Is there any way to get rid of that? P.S. Note that these are just temporary sounds. musicmaker.bas Edited September 23, 2006 by atari2600land Quote Link to comment Share on other sites More sharing options...
+atari2600land Posted September 24, 2006 Author Share Posted September 24, 2006 Here's a more complete (yet still not finished version). Hey, I must be Satan cuz this is my 666th post! musicmaker3.bas.bin musicmaker3.bas Quote Link to comment Share on other sites More sharing options...
gambler172 Posted September 24, 2006 Share Posted September 24, 2006 Hi nice idea your music maker.I like it Maybe you could use the Keyboard controllers to use it. greetings gambler172 Quote Link to comment Share on other sites More sharing options...
