potatohead Posted September 27, 2006 Share Posted September 27, 2006 Hey all, I've been busy lately... Been toying with Bb some recently. Lots of changes. A quick answer to 2600land's movement question prompted me to post this now before it slips again. It would be really handy to be able to push one var onto the stack, then pull it again. Of course this can be done with a temp, but I think less overall code would be used with a push [var], pull [var] instruction set. It's also very intuitive. a = x + 30 [some logic] push a a = a / 2 player1xpos = a + 30 : player0xpos = a + 60 pull a [more logic] Assume the stack is one level deep. (Which is all that is needed) Whatever is in the stack would be put into whatever var is named. push a a = a + 20 pull t : pull v Is this a savings over the usual temp approach? I kind of like it because it's more assembly like, IMHO. (Which is what bB is supposed to be about right?) I don't expect a response to this anytime soon. Just wanted to post it here for Batari when he once again sees fit to hack on bB. Maybe it's crap, maybe it's a good idea, but it's not forgotten this time! Quote Link to comment Share on other sites More sharing options...
+batari Posted September 27, 2006 Share Posted September 27, 2006 It would be really handy to be able to push one var onto the stack, then pull it again. Of course this can be done with a temp, but I think less overall code would be used with a push [var], pull [var] instruction set. It's also very intuitive. a = x + 30 [some logic] push a a = a / 2 player1xpos = a + 30 : player0xpos = a + 60 pull a [more logic] bB supports complex equations now so the temp var approach isn't strictly necessary. For example, you could just do this: player1xpos = a/2+30 That's not to say a stack wouldn't be useful for something. It would be very easy to implement, so it's probably worth adding if someone will find it useful. Quote Link to comment Share on other sites More sharing options...
