+Mitch Posted November 20, 2006 Share Posted November 20, 2006 Here's a hint if you want to beat it the easy way. The first level is always the same when you turn it on, if you hit reset it is randomized. With a map of the first level it is much easier to beat. If you use a converted Jinks board your first level should be the same as this. Mitch Actually, I think it depends on what sort of RAM chip you've got. If I were to guess, the first board is pulled by grabbing states of RAM on power-up. IIRC, my first scene was way different. But, it was still beatable. This might be a fun thing to experiment with, if anyone has some different RAM chips from different manufacturers. -John Hmm, I thought you were using a 32k RAM chip. I tried several 8k RAM chips and always got the same map, don't know if they were the same manufacturer or not. Mitch Quote Link to comment Share on other sites More sharing options...
