gambler172 Posted November 19, 2006 Share Posted November 19, 2006 (edited) Hi Guys i hacked a little bit around with Xevious.If anyone thinks,that Xevious is too easy,play "Xevious Insane".I also changed the graphics a little bit.I hope,that i can change the game graphics a little more.Here is the first effort for testing. Hope you enjoy it. greetings gambler172 Xevious_insane.bin Edited August 26, 2007 by gambler172 Quote Link to comment Share on other sites More sharing options...
gambler172 Posted November 20, 2006 Author Share Posted November 20, 2006 Hi no comments????? greetings gambler172 Quote Link to comment Share on other sites More sharing options...
Bakasama Posted November 20, 2006 Share Posted November 20, 2006 well, if there was a version for MESS I would be able to comment on it. Quote Link to comment Share on other sites More sharing options...
diggs130 Posted November 20, 2006 Share Posted November 20, 2006 well, if there was a version for MESS I would be able to comment on it. same here! Quote Link to comment Share on other sites More sharing options...
HammR25 Posted November 21, 2006 Share Posted November 21, 2006 I can't get it to work with my CC2. Don't know what i"m doing wrong. I used the same menu line as regular Xevious. and also tried: 7800: Xevious Insane XEVINS78 7800_32K 78BIOS but that got the exact same result. some noise and the screen is all messed up. Quote Link to comment Share on other sites More sharing options...
+Mitch Posted November 21, 2006 Share Posted November 21, 2006 Try this one. Mitch Xevious_insane.zip Quote Link to comment Share on other sites More sharing options...
+Allan Posted November 21, 2006 Share Posted November 21, 2006 I just tried it on the real thing. Looks cool but unfortunetly there is a screen flicker on the sides. Anyway of fixing that. Plays great otherwise. Nice job. (thanks for fixing the bin Mitch.) Allan Quote Link to comment Share on other sites More sharing options...
gambler172 Posted November 26, 2006 Author Share Posted November 26, 2006 Hi Guys here is the new verion of "XEVIOUS INSANE" I changed the following. - added ufos - changed the players graphic - added spider robot - some minor graphic changes at some enemies Hope you enjoy it. greetings gambler172 Xevious_insane.bin Quote Link to comment Share on other sites More sharing options...
+Allan Posted November 26, 2006 Share Posted November 26, 2006 Hi Guys here is the new verion of "XEVIOUS INSANE" I changed the following. - added ufos - changed the players graphic - added spider robot - some minor graphic changes at some enemies Hope you enjoy it. greetings gambler172 I just tried it on my CC2. All I get is lines across the screen. The last version worked so I'm guessing you broke something. Allan Quote Link to comment Share on other sites More sharing options...
gambler172 Posted November 26, 2006 Author Share Posted November 26, 2006 Hi Guys here is the new verion of "XEVIOUS INSANE" I changed the following. - added ufos - changed the players graphic - added spider robot - some minor graphic changes at some enemies Hope you enjoy it. greetings gambler172 I just tried it on my CC2. All I get is lines across the screen. The last version worked so I'm guessing you broke something. Allan Hi Allan all i can say,that it works great with my CC2.Maybe Mitch can help.I do not know,why it does not work with your CC2. greetings Walter Quote Link to comment Share on other sites More sharing options...
+Allan Posted November 26, 2006 Share Posted November 26, 2006 Hi Guys here is the new verion of "XEVIOUS INSANE" I changed the following. - added ufos - changed the players graphic - added spider robot - some minor graphic changes at some enemies Hope you enjoy it. greetings gambler172 I just tried it on my CC2. All I get is lines across the screen. The last version worked so I'm guessing you broke something. Allan Hi Allan all i can say,that it works great with my CC2.Maybe Mitch can help.I do not know,why it does not work with your CC2. greetings Walter What are you using as your CC2 settings? Allan Quote Link to comment Share on other sites More sharing options...
gambler172 Posted November 26, 2006 Author Share Posted November 26, 2006 Hi Guys here is the new verion of "XEVIOUS INSANE" I changed the following. - added ufos - changed the players graphic - added spider robot - some minor graphic changes at some enemies Hope you enjoy it. greetings gambler172 I just tried it on my CC2. All I get is lines across the screen. The last version worked so I'm guessing you broke something. Allan Hi Allan all i can say,that it works great with my CC2.Maybe Mitch can help.I do not know,why it does not work with your CC2. greetings Walter What are you using as your CC2 settings? Allan Hi Allan i use a Pal system and use the same settings,that i use for xevious(NTSC). We in germany have no problems to use NTSC carts on a Pal system. I am able to play this bin.That is all,i can say. greetings Walter Quote Link to comment Share on other sites More sharing options...
+Allan Posted November 26, 2006 Share Posted November 26, 2006 Hi Guys here is the new verion of "XEVIOUS INSANE" I changed the following. - added ufos - changed the players graphic - added spider robot - some minor graphic changes at some enemies Hope you enjoy it. greetings gambler172 I just tried it on my CC2. All I get is lines across the screen. The last version worked so I'm guessing you broke something. Allan Hi Allan all i can say,that it works great with my CC2.Maybe Mitch can help.I do not know,why it does not work with your CC2. greetings Walter What are you using as your CC2 settings? Allan Hi Allan i use a Pal system and use the same settings,that i use for xevious(NTSC). We in germany have no problems to use NTSC carts on a Pal system. I am able to play this bin.That is all,i can say. greetings Walter So this is what you use? Xevious - 7800 XEV78 HSC_32K HSC Xevious Insane - 7800 XEVIN78 HSC_32K HSC Maybe Mitch can try it when he gets a chance. Allan Quote Link to comment Share on other sites More sharing options...
Shawn Posted November 26, 2006 Share Posted November 26, 2006 Walter, This is 100 times better than normal Xevious. Can;t wait to see what else you do to this game. Looks like my normal Xevious cart is gonna be a donor cart now!! Shawn Quote Link to comment Share on other sites More sharing options...
Bakasama Posted November 26, 2006 Share Posted November 26, 2006 I've played the MESS version of this and I got to say waves of flying enemies made my thumb tired. I was wondering what kind of changes are you going to make to this hack. Quote Link to comment Share on other sites More sharing options...
+Mitch Posted November 27, 2006 Share Posted November 27, 2006 Try this one. The reason it doesn't work on an NTSC 7800 is because it doesn't have a valid authentication signature. About the game; I also get the flickering on the screen borders at the top portion of the screen. I also occasional have a problem with the shooting sound getting stuck on for a second or so. By the way, is this a hack of the PAL version of Xevious or the NTSC version? Mitch Xevious_insane.zip Quote Link to comment Share on other sites More sharing options...
gambler172 Posted November 28, 2006 Author Share Posted November 28, 2006 Try this one. The reason it doesn't work on an NTSC 7800 is because it doesn't have a valid authentication signature. About the game; I also get the flickering on the screen borders at the top portion of the screen. I also occasional have a problem with the shooting sound getting stuck on for a second or so. By the way, is this a hack of the PAL version of Xevious or the NTSC version? Mitch Hi Mitch this is a hack of the NTSC version.But for testing,i use my 7800 PAL system. The game itself is NTSC.And when putting it to my CC2,i have no problems. I have no problems with sound,when playing. greetings Walter Quote Link to comment Share on other sites More sharing options...
gambler172 Posted December 3, 2006 Author Share Posted December 3, 2006 Hi Guys here is a new Update of Xevious Insane. -added metal scorpions -added new fighter -some small graphic changes greetings gambler172 Xevious_insane.bin Quote Link to comment Share on other sites More sharing options...
gambler172 Posted December 10, 2006 Author Share Posted December 10, 2006 Hi Guys and a new update is available now. -Added some Tanks in the background -Changed Titlescreen a little bit -Added a new Alien -Changed Players ship a little bit Hope you like it. More .....next weekend greetings gambler172 Quote Link to comment Share on other sites More sharing options...
gambler172 Posted December 10, 2006 Author Share Posted December 10, 2006 (edited) Hi Guys and a new update is available now. -Added some Tanks in the background -Changed Titlescreen a little bit -Added a new Alien -Changed Players ship a little bit Hope you like it. More .....next weekend greetings gambler172 Xevious_insane.bin Edited December 10, 2006 by gambler172 Quote Link to comment Share on other sites More sharing options...
gambler172 Posted December 17, 2006 Author Share Posted December 17, 2006 Hi here is a new update of Xevious Insane I added T-Fighters from Star Wars and changed the other enemies a little bit.I also changed the players ship a little bit.Does anyone have an idea for a better Players ship sprite,which i could implement in the game. Any other ideas and sugestions are welcome too. greetings gambler172 Xevious_insane.bin Quote Link to comment Share on other sites More sharing options...
diggs130 Posted December 18, 2006 Share Posted December 18, 2006 I like were this is going and would love to give it more playtime if it was playable in mess... look forward to the completed project~ Quote Link to comment Share on other sites More sharing options...
gambler172 Posted December 18, 2006 Author Share Posted December 18, 2006 I like were this is going and would love to give it more playtime if it was playable in mess... look forward to the completed project~ Hi Douglas maybe Mitch can help.This version works fine on a CC2. greetings Walter Quote Link to comment Share on other sites More sharing options...
Bakasama Posted December 18, 2006 Share Posted December 18, 2006 I like were this is going and would love to give it more playtime if it was playable in mess... Yeah it does suck, it worse for Mac users since we have no choice and stuck with MESS. Quote Link to comment Share on other sites More sharing options...
+Mitch Posted December 21, 2006 Share Posted December 21, 2006 Here's a signed copy of the latest version as well as an A78 copy. Walter, I'm still seeing the screen flickering and having the occasional sound freeze issue but I've noticed it only happens when there are a large amount of objects near the top of the screen. Mitch Xevious_insane.zip Quote Link to comment Share on other sites More sharing options...
