Dragnerok X Posted December 12, 2006 Share Posted December 12, 2006 (edited) So I've got some movement code like this... 33 if a = 1 && b = 15 then x = x + 1 34 if a = 2 && b = 15 then x = x + 2 : y = y - 1 35 if a = 3 && b = 15 then x = x + 1 : y = y - 1 36 if a = 4 && b = 15 then x = x + 1 : y = y - 2 37 if a = 5 && b = 15 then y = y - 1 38 if a = 6 && b = 15 then x = x - 1 : y = y - 2 39 if a = 7 && b = 15 then x = x - 1 : y = y - 1 40 if a = 8 && b = 15 then x = x - 2 : y = y - 1 41 if a = 9 && b = 15 then x = x - 1 42 if a = 10 && b = 15 then x = x - 2 : y = y + 1 43 if a = 11 && b = 15 then x = x - 1 : y = y + 1 44 if a = 12 && b = 15 then x = x - 1 : y = y + 2 45 if a = 13 && b = 15 then y = y + 1 46 if a = 14 && b = 15 then x = x + 1 : y = y + 2 47 if a = 15 && b = 15 then x = x + 1 : y = y + 1 48 if a = 16 && b = 15 then x = x + 2 : y = y + 1 ...if I run it with b = 15, it runs too blockily, but without it, it runs way too fast? What do you use to allow slow, smooth, movement? Here's the source. Combat_DX.bas Thanks! Edited December 12, 2006 by Dragnerok X Quote Link to comment Share on other sites More sharing options...
+atari2600land Posted December 12, 2006 Share Posted December 12, 2006 What I'd do is change line 4 to read "if b=16 then b=0" and then change lines 6 & 7 to read 6 if joy0left && b = 2 then a = a + 1 7 if joy0right && b = 2 then a = a - 1 if that's too fast, try inserting b=3 or b=4 instead of b=2. Quote Link to comment Share on other sites More sharing options...
