The Latest Crazy NinjaCade Project
I was planning on Lexan, but it was cost prohibitive enough to avoid. I'm using simple acrylic sheets at 72" by 36", cut into 6" strips. They are mounted on the brackets with velcro to allow easy pull-down for cleaning and provide a little extra moon-like bounce as pressure is applied across the plastic.
Yeah you don't need shelving to be bulletproof.
  • 3 weeks later...
Right, so what this is all turning out to be is a support system for a Lego Space Monorail to run around the ceiling of the NinjaCade (well, part of the 'Cade at least). The monorail itself runs back and forth in a horseshoe around about 25% of the place. There is also an additional area for expansion/moon bases. I took a quick shot of the main "monorail station":
More to come.
Also, if you happen to have any Space themed Legos from the 80s (or early 90s), let me know. I'd be thrilled to add more vehicles, space guys, or spare parts.
