+doctorclu Posted December 29, 2006 Share Posted December 29, 2006 Ok, here is one with a bit more sound... http://www.youtube.com/watch?v=4FPpxlS3xmA Quote Link to comment Share on other sites More sharing options...
+remowilliams Posted December 29, 2006 Share Posted December 29, 2006 (edited) If you're using Jugs you may need to use the 'kickstart' application with it or whatever it is called. Cool, I'll try that. Sound would make it even more fun What is the latest/best version of the BJL loader to use? There seems to be a whole lot of different versions. Edited December 29, 2006 by remowilliams Quote Link to comment Share on other sites More sharing options...
+doctorclu Posted December 29, 2006 Share Posted December 29, 2006 Loading by BJL is very easy. No need to put in a start address etc. In the command line to load just type: BJL_load -n -8 surround.bin. You should get the standard nyuk nyuk nyuk etc at the 3D Stooges logo alone plus the game sounds etc. In game you should get all sorts of sounds from a siren sound to the enemies firing shots and the sounds during the cubes destruction. If you're using Jugs you may need to use the 'kickstart' application with it or whatever it is called. So how long does it take to load by BJL? Quote Link to comment Share on other sites More sharing options...
+remowilliams Posted December 29, 2006 Share Posted December 29, 2006 OK, I tried the 'kickstart method' and there is still no sound from the demo. I loaded it like so: jugs -com=com1 -baud=38400 -addr=4000 -file=SURROUND.BIN jugs -com=com1 -baud=38400 -addr=1000 -run=3 -file=Kickstrt.bin Quote Link to comment Share on other sites More sharing options...
JagChris Posted December 29, 2006 Author Share Posted December 29, 2006 I just use the version of BJL off of Belboz's website. It's the most stable and reliable. Quote Link to comment Share on other sites More sharing options...
Gorf Posted December 29, 2006 Share Posted December 29, 2006 I can see that! Well, as a tribute to the Frog, to show folks how this is loaded with JUGS, and to show people it is definately worth going through all the trouble to load this game, here is a comical movie I put together in tribute. Enjoy!! No 38,400 for you? Actually while we're on the subject (sort of) was there any version of the JUGS loader that can actually go beyond 38,400 like the cart settings can? How come no sound? You mean while playing the game? I get no sound either when playing the game, I figured it was because it was a demo, but I might as well ask now - am I supposed to be hearing sound during the game? There is sound on both updates....maybe Jugs has an issue with sound? Quote Link to comment Share on other sites More sharing options...
Gorf Posted December 30, 2006 Share Posted December 30, 2006 How come no sound? Hey what is is like loading this by BJL and other means? Loading by BJL is very easy. No need to put in a start address etc. In the command line to load just type: BJL_load -n -8 surround.bin. You should get the standard nyuk nyuk nyuk etc at the 3D Stooges logo alone plus the game sounds etc. In game you should get all sorts of sounds from a siren sound to the enemies firing shots and the sounds during the cubes destruction. If you're using Jugs you may need to use the 'kickstart' application with it or whatever it is called. Yeah I dont know...I do have a JUGS as of recently but I've not tried it...to Alpine spoiled. and...cube?....its a fortress Quote Link to comment Share on other sites More sharing options...
+remowilliams Posted December 30, 2006 Share Posted December 30, 2006 (edited) There is sound on both updates....maybe Jugs has an issue with sound? I think that is the case. I can get the first release to load consistently, and the second release only loaded once or twice. But neither have sound with JUGS (kickstart or not). As far as BJL- I have multiple ways to run BJL on the Jag itself, and have tried a couple different PC side BJL loaders but I'm guessing the cable I hacked together in ten minutes out of a Jag controller cable isn't cutting it. The only thing that loads properly is that frontier demo that swapd0 put out. and...cube?....its a fortress Indeed! Edited December 30, 2006 by remowilliams Quote Link to comment Share on other sites More sharing options...
Gorf Posted December 30, 2006 Share Posted December 30, 2006 Ok, here is one with a bit more sound... http://www.youtube.com/watch?v=4FPpxlS3xmA Yeah but there is still something terribly wrong...those are not the sounds by any means...hmmm...I will talk to doug and see why that might occur and if I can fix it for JUGS so the sound if correct, I will and upload another update. Quote Link to comment Share on other sites More sharing options...
JagMod Posted December 30, 2006 Share Posted December 30, 2006 Ok, here is one with a bit more sound... http://www.youtube.com/watch?v=4FPpxlS3xmA That's pretty funny Dr. Quote Link to comment Share on other sites More sharing options...
+doctorclu Posted December 30, 2006 Share Posted December 30, 2006 (edited) Ok, here is one with a bit more sound... http://www.youtube.com/watch?v=4FPpxlS3xmA That's pretty funny Dr. Thanks! JUGS is a great resource, but it can take a bit of time to load things. Hey I want to try BJL and I have Protector SE. Can someone let me know where the PC loading programs are, and the pin-out how-to to make the joystick cable I've been hearing about? Thanks! Once I get that going I would make a movie on how that works. Oh I have a TT-030 I can use for this project too. Edited December 30, 2006 by doctorclu Quote Link to comment Share on other sites More sharing options...
+remowilliams Posted December 30, 2006 Share Posted December 30, 2006 (edited) Yeah but there is still something terribly wrong...those are not the sounds by anymeans...hmmm...I will talk to doug and see why that might occur and if I can fix it for JUGS so the sound if correct, I will and upload another update. That would be cool if you could get it to work with JUGS. I only see one place on the web to order a BJL adapter, and the email bounces. Anyhow to sum up my experience so far (if this helps): Original Demo release: JUGS 19.2K Loads fine (with or without kickstart) Plays fine, no lockups. No sound. JUGS 38.4K Loads fine (with or without kickstart) Plays fine, no lockups. No sound. Second 'fix' release: JUGS 19.2K+38.4K Loads very infrequently (with or w/o kickstart). Usually hangs after load (black screen). When it does load it works fine, no lockups. No sound. Edited December 30, 2006 by remowilliams Quote Link to comment Share on other sites More sharing options...
+doctorclu Posted December 31, 2006 Share Posted December 31, 2006 That would be cool if you could get it to work with JUGS. I only see one place on the web to order a BJL adapter, and the email bounces. Anyhow to sum up my experience so far (if this helps): Are you talking about A8Maestro and More than Games? I'll let him know tomorrow in the Atari chat at telnet://www.atarinews.org (enter : bbs,bbs (name,password) >enter<, t,c (chat name) ) Yeh, looking that might be the way to go. Quote Link to comment Share on other sites More sharing options...
Gorf Posted December 31, 2006 Share Posted December 31, 2006 That would be cool if you could get it to work with JUGS. I only see one place on the web to order a BJL adapter, and the email bounces. Anyhow to sum up my experience so far (if this helps): Are you talking about A8Maestro and More than Games? I'll let him know tomorrow in the Atari chat at telnet://www.atarinews.org (enter : bbs,bbs (name,password) >enter<, t,c (chat name) ) Yeh, looking that might be the way to go. NO soldering needed and you dont need to mod the Jag. Quote Link to comment Share on other sites More sharing options...
CrazyChris Posted January 1, 2007 Share Posted January 1, 2007 I just use the version of BJL off of Belboz's website. It's the most stable and reliable. What is the address to that site? Thanks, Chris Quote Link to comment Share on other sites More sharing options...
Shawn Posted January 2, 2007 Share Posted January 2, 2007 If a "C" complier is made I would make a game for the Jag. Prob. a Pong or Breakout clone though cause I want to be sure it gets finsished. Quote Link to comment Share on other sites More sharing options...
+remowilliams Posted January 2, 2007 Share Posted January 2, 2007 What is the address to that site? http://www.hillsoftware.com/downloads/index.html If a "C" complier is made I would make a game for the Jag. Prob. a Pong or Breakout clone though cause I want to be sure it gets finsished. Well, go to Belboz's site above, get yourself the devkit, and BJL boot CD, make yourself a BJL adapter - and have at it Quote Link to comment Share on other sites More sharing options...
Fredifredo Posted January 2, 2007 Share Posted January 2, 2007 Thanks! JUGS is a great resource you forgot the word "expensive" JUGS is a great and expensive resource ... Yes ! for all people who have a JaguarCD BELBOZ BJL is the best ! Waiting JagCF Quote Link to comment Share on other sites More sharing options...
SebRmv Posted January 2, 2007 Share Posted January 2, 2007 If a "C" complier is made I would make a game for the Jag. Prob. a Pong or Breakout clone though cause I want to be sure it gets finsished. You have to visit http://removers.atari.org/softs/download.php?lang=en then! Seb Quote Link to comment Share on other sites More sharing options...
Michael_ Posted January 2, 2007 Share Posted January 2, 2007 Thanks! JUGS is a great resource you forgot the word "expensive" I think the word you´re looking for is FREE. Mine came FREE with my copy of BS:G. Quote Link to comment Share on other sites More sharing options...
JagChris Posted January 3, 2007 Author Share Posted January 3, 2007 What is the address to that site? http://www.hillsoftware.com/downloads/index.html If a "C" complier is made I would make a game for the Jag. Prob. a Pong or Breakout clone though cause I want to be sure it gets finsished. Well, go to Belboz's site above, get yourself the devkit, and BJL boot CD, make yourself a BJL adapter - and have at it Well, getting the devkit to work with BJL takes a small bit of doing, but it's really easy. Here, my contribution to the AA Atari Jaguar Programming forum: Jag development and BJL setting up. Quote Link to comment Share on other sites More sharing options...
Gorf Posted January 3, 2007 Share Posted January 3, 2007 Thanks! JUGS is a great resource you forgot the word "expensive" JUGS is a great and expensive resource ... Yes ! for all people who have a JaguarCD BELBOZ BJL is the best ! Waiting JagCF Why must you always take shots at the competition? Do you really think that will make anyone else anymore interested in the CF? We are talking about 7 years later and JUGS has been sucessfully uploading happy jag fans demos for their gaming pleasure. The CF sounds great, but where is it? Call it as you wish, but at the time, JUGS was a brilliant idea WITHOUT MODIFCATION TO THE JAG.and is still a great product and certainly useful to many wanting to enjoy the homebrews. It came FREE with another product along with MANY neat demos and the possiblity for those wanting to to code the Jaguar before the encryption keys were released. I call that brilliant foresite and certainly a fantastic service to all jag fans and those who could not or did not want to mod thier Jaguars. They were the first to offer this packaged with a fantastic space battle game to boot. I say BRAVO!!! Quote Link to comment Share on other sites More sharing options...
Gorf Posted January 3, 2007 Share Posted January 3, 2007 Thanks! JUGS is a great resource you forgot the word "expensive" I think the word you´re looking for is FREE. Mine came FREE with my copy of BS:G. funny you should mentoin that...so did mine.....in fact the whole package did! Quote Link to comment Share on other sites More sharing options...
+doctorclu Posted January 3, 2007 Share Posted January 3, 2007 (edited) Ok, to answer the questions about load times with BJL, or how to make a BJL cable, I was able to get the information from More Than Games to fill these gaps. Said the game loads in 14 seconds on BJL. Gave a link on how to make a cable http://www.a8maestro.com/sites/bjl/how-to-mod/mod.htm ...and offers a BJL cable adaptor in their catalog. Thanks Rick!! http://www.a8maestro.com/sites/mtgcat/prodgame/game-t1.htm Edited January 3, 2007 by doctorclu Quote Link to comment Share on other sites More sharing options...
Fredifredo Posted January 3, 2007 Share Posted January 3, 2007 JUGS was a brilliant idea WITHOUTMODIFCATION TO THE JAG With Belboz BJL CD too... The CF sounds great, but where is it? In the SCPCD factory... "waiting"#"available" Catnip Power ! Quote Link to comment Share on other sites More sharing options...
