If you mean Sheddy's tool here ya go :     It's currently version 3.3. Unzip it all to a folder.   The HPOS removal tool is in the generator folder. You drag your chosen RC XEX file to it in Windows (it's called try to fix HPOS artefacts.bat). It initiates a command line program which  - where possible - removes any HPOS errors. Once done hit space bar to close the command line window. You can then take the output.xex it creates in the same folder and rename it.
    • Thanks
    • Like
