Well what can I say other than I got very creative today and whipped out this little jewel, designed to be installed internally.
There's a Newer Design Available at: https://ataribits.weebly.com/sdrive.html
Board Top
Board Bottom
The board design is meant to fit directly above the SIO jack, with the only caveat being the need to cut a small slot in the A8's plastic case above the SIO jack to access the Micro-SD slot
EDIT: If you w
I noticed that if I let the SDrive idle, that after approximately 2 minutes it was like it had powered itself down, and would need to 'wake-up' before disk access was possible. Now I use the term 'powered itself down' which isn't what actually happens (power is present the entire time, and not controlled by the SDrive). Another way of putting it, is that it seems to fall asleep and/or Time-Out.
Here's a video showing what I am talking about...
When the vi
