Kjmann Posted February 13, 2007 Share Posted February 13, 2007 (edited) Hopefully this is the final version. Let me know what you all think. Also Stay Tuned For the 1st two boss musix for Space harrier and the stage 5/bonus round. =) See this link for all my musics in the future http://www.atariage.com/forums/index.php?s...=102693&hl= Edited February 25, 2007 by kjmann Quote Link to comment Share on other sites More sharing options...
Kjmann Posted February 13, 2007 Author Share Posted February 13, 2007 (edited) This Is The Final Version!!!! finally found a mistake in the rhythm in the beginning of the song. So Here It Is Folks!!! I had Fun Doing This One. Edited February 25, 2007 by kjmann Quote Link to comment Share on other sites More sharing options...
pseudografx Posted February 13, 2007 Share Posted February 13, 2007 This Is The Final Version!!!! finally found a mistake in the rhythm in the beginning of the song. So Here It Is Folks!!! I had Fun Doing This One. This one sounds good! And it is probably the first time I hear hardsynth instruments that fit the music. Otherwise I won't overestimate their usability but in this song they just work well (even though the pitch is in some places not absolutely correct). Quote Link to comment Share on other sites More sharing options...
analmux Posted February 13, 2007 Share Posted February 13, 2007 This one sounds good! And it is probably the first time I hear hardsynth instruments that fit the music. Otherwise I won't overestimate their usability but in this song they just work well (even though the pitch is in some places not absolutely correct). hmmm, I think you should look at this from the other side. When you use hardsynth instruments in 15khz mode you will have to fit the music to the instruments, because it's a totally different approximation of 'making sound'. You can not always make 'traditional' Pokey tunes with the hardsynth setting (though '15khz-setting' is meant here. Hardsynth means just the opposite of 'softsynth'). Therefore some musicians should spend some time playing with these settings such that they can compose atari music with the hardsynth-type instruments. Quote Link to comment Share on other sites More sharing options...
Kjmann Posted February 13, 2007 Author Share Posted February 13, 2007 This one sounds good! And it is probably the first time I hear hardsynth instruments that fit the music. Otherwise I won't overestimate their usability but in this song they just work well (even though the pitch is in some places not absolutely correct). hmmm, I think you should look at this from the other side. When you use hardsynth instruments in 15khz mode you will have to fit the music to the instruments, because it's a totally different approximation of 'making sound'. You can not always make 'traditional' Pokey tunes with the hardsynth setting (though '15khz-setting' is meant here. Hardsynth means just the opposite of 'softsynth'). Therefore some musicians should spend some time playing with these settings such that they can compose atari music with the hardsynth-type instruments. Well, Accually I didn't use 15khz mode. this is standard. I just used a couple of filtered instruments and a 16bit bass table. although without the filtered instruments and 16bit bass i still had an issue with the pitch being exact. =) Quote Link to comment Share on other sites More sharing options...
analmux Posted February 13, 2007 Share Posted February 13, 2007 This one sounds good! And it is probably the first time I hear hardsynth instruments that fit the music. Otherwise I won't overestimate their usability but in this song they just work well (even though the pitch is in some places not absolutely correct). hmmm, I think you should look at this from the other side. When you use hardsynth instruments in 15khz mode you will have to fit the music to the instruments, because it's a totally different approximation of 'making sound'. You can not always make 'traditional' Pokey tunes with the hardsynth setting (though '15khz-setting' is meant here. Hardsynth means just the opposite of 'softsynth'). Therefore some musicians should spend some time playing with these settings such that they can compose atari music with the hardsynth-type instruments. Well, Accually I didn't use 15khz mode. this is standard. I just used a couple of filtered instruments and a 16bit bass table. although without the filtered instruments and 16bit bass i still had an issue with the pitch being exact. =) I know, I wasn't referring to your work yes, the 16bit bass table is still generator C (12) (RMT-generator '6') and I think the problem here is that this pitch-table differs a little from the standard generator A table. Quote Link to comment Share on other sites More sharing options...
