GimpMaster Posted February 17, 2007 Share Posted February 17, 2007 Hey guys, I'm not sure if this is the right forums to post here, but I just got my Atari 800XL working again. It turns out the power supply went bad and was sending a sine wave from 0->10 Volt instead of just keeping it at a nice regulated 5V. However I think this might have damaged it since now in the bottom left hand corner of the screen I have a big purple area. Have you guys seen this before? Any suggestions on what I might do? Thanks. Quote Link to comment Share on other sites More sharing options...
Gunstar Posted February 17, 2007 Share Posted February 17, 2007 (edited) That wouldn't be the 800XL's video, but your TV/monitor which somehow has discolored there from a stray magnetic field, which the cause of could be several different reasons, but it's not the 800XL. It's just conicidence that your TV/monitor developed this problem as you just fixed your 800XL. Do you have any speakers or the 800XL power pack close to that area of the TV/monitor? Possibly the TV/monitor's internal speaker is getting old and weak and has a warped magnetic field, or just something magnetic was set or passed over that area. In any case, the TV/monitor needs to be degaussed and/or the magnetic interference removed. In any case, it's your TV/monitor that has developed the problem and not your 800XL. Plug your 800XL into a different TV or monitor and you will see it's not the 800XL. From your simple description and my personal experience with old TV/monitors with similar problems that's my educated assumption. Edited February 17, 2007 by Gunstar Quote Link to comment Share on other sites More sharing options...
GimpMaster Posted February 17, 2007 Author Share Posted February 17, 2007 Very good. I had a DC power supply sitting next to my tv. Inside must be a big magnet or something that is really showing itself on the blue colors. I adjusted the TV and moved it physically away from my power supply and all is good. Thanks again. Quote Link to comment Share on other sites More sharing options...
Gunstar Posted February 17, 2007 Share Posted February 17, 2007 No problem. But it's not a big magnet in your power pack, all electronic devices generate a magnatic field, especially power supplies. They will disrupt the magnets that drive the CRT picture tube's cathode ray gun. Quote Link to comment Share on other sites More sharing options...
