exobuzz Posted April 4, 2007 Share Posted April 4, 2007 Hi, Has anyone used the AtariMAX.com sio2pc+prosystem cable successfuly with linux ? It is supposed to be autosending (DSR/RING/CTS), but when doing an ioctl wait in linux for either it sits there forever I was testing it with sio2linux ( http://www.crowcastle.net/preston/atari/ ) which is a usermode program. I also tried atarisio ( http://www.horus.com/~hias/atari/ ) but this wouldn't work either. It wouldn't even build on new kernels so I created a patch - http://www.atarimax.com/flashcart/forum/viewtopic.php?t=572 this allows atarisio to be built on kernel 2.6.20 (Should work on older 2.6 kernels also) I would be interested in finding out if the atarisio works for others with my patch, and also any success with the sio2pc+prosystem cable on linux. Quote Link to comment Share on other sites More sharing options...
carmel_andrews Posted April 4, 2007 Share Posted April 4, 2007 is this device similar to the 2 in one or 3 in one pc-atari interfaces/cables that i saw mentioned on the www in the late 90's As a few websites did mention those very devices Quote Link to comment Share on other sites More sharing options...
exobuzz Posted April 4, 2007 Author Share Posted April 4, 2007 the interface I bought is http://www.atarimax.com/sio2pc/ Quote Link to comment Share on other sites More sharing options...
exobuzz Posted April 4, 2007 Author Share Posted April 4, 2007 compatibility problems mostly solved. Please see http://www.atarimax.com/flashcart/forum/vi...php?p=2426#2426 Quote Link to comment Share on other sites More sharing options...
Urchlay Posted April 4, 2007 Share Posted April 4, 2007 I use Linux with the same SIO2PC device you have... For some reason, Hias doesn't link to his development versions of atarisio from his main page. Here they are: http://www.horus.com/~hias/atari/atarisio/ I'm using the 061113 snapshot, which is the first one whose kernel module will work correctly on x86_64 (though I'm using an old kernel on my AMD64, version 2.6.15. No idea whether it'll build or work on 2.6.20). I didn't have to patch this version of atarisio at all (it already clears RTS on its own). I never got sio2linux working 100% reliably... I got the device to work by clearing RTS, same as you did (though I didn't figure it out myself: Steve told me to try it). It mostly worked, but would mysteriously fail sometimes. Once I got atarisio working, I didn't really try too hard to fix sio2linux. Quote Link to comment Share on other sites More sharing options...
