riffraff Posted May 2, 2007 Share Posted May 2, 2007 Some of you were asking about my spare Waterworld box and I finally unearthed it. It's mounted to a white comic-cardboard backing. The box is in good shape but it cannot be assembled nor is the back of the box visible. If you want to see it, I put it up on ebay with a .99 starting bid. It's only suitable for framing/displayed on a wall at this point. Swordquest Waterworld Box on ebay Quote Link to comment Share on other sites More sharing options...
Atarimania75 Posted May 2, 2007 Share Posted May 2, 2007 Some of you were asking about my spare Waterworld box and I finally unearthed it. It's mounted to a white comic-cardboard backing. The box is in good shape but it cannot be assembled nor is the back of the box visible. If you want to see it, I put it up on ebay with a .99 starting bid. It's only suitable for framing/displayed on a wall at this point. Swordquest Waterworld Box on ebay Very interesting! Quote Link to comment Share on other sites More sharing options...
revsdr Posted May 2, 2007 Share Posted May 2, 2007 is it glued to it ? Quote Link to comment Share on other sites More sharing options...
Atarimania75 Posted May 2, 2007 Share Posted May 2, 2007 is it glued to it ? Dude, u did read the description right? Quote Link to comment Share on other sites More sharing options...
revsdr Posted May 2, 2007 Share Posted May 2, 2007 dude is it yours? i didnt think so... it says mounted...not hot glued, super glued or double sided tape... Quote Link to comment Share on other sites More sharing options...
Atarimania75 Posted May 2, 2007 Share Posted May 2, 2007 dude is it yours?i didnt think so... it says mounted...not hot glued, super glued or double sided tape... LMAO ok so what would u mount a box made of cardboard to a cardboard poster with? Chewing gum? Quote Link to comment Share on other sites More sharing options...
revsdr Posted May 2, 2007 Share Posted May 2, 2007 if you had enough brains to speak less than you do you might find out that MOST glues can be heated and removed,but if its something like super glue, i dont think it can be. Quote Link to comment Share on other sites More sharing options...
revsdr Posted May 2, 2007 Share Posted May 2, 2007 and im through with the subject..... great item and i will try to win it. Quote Link to comment Share on other sites More sharing options...
Atarimania75 Posted May 2, 2007 Share Posted May 2, 2007 if you had enough brains to speak less than you do you might find out that MOST glues can be heated and removed,but if its something like super glue, i dont think it can be. Your question was is it glued! I did not say it couldn't be heated and removed!!! Read the posts! Quote Link to comment Share on other sites More sharing options...
riffraff Posted May 2, 2007 Author Share Posted May 2, 2007 It's actually a good question. I tried a little bit to remove the box but every inch of it was totally stuck to the comic-cardboard. I'm not sure why it's stuck like it is. It was stored in a comic bag in a dry place all these years. It's crooked against the cardboard so you would want to trim the excess backing away before framing. I didn't want to mess with it in case I spazzed out and cut into the box by mistake. Quote Link to comment Share on other sites More sharing options...
riffraff Posted May 2, 2007 Author Share Posted May 2, 2007 Well an inconvienient truth as to why it's stuck like this is could possibly be ... water damage (waterworld damage?). The box seems in perfect shape without any staining or other problems. The front of the box is not "stuck" to the back of the box (can open it up at the ends and look inside). I don't know if this kind of seal made by water damage (if that's indeed what caused this seal) is fixable using any of the techniques mentioned, but I think it may be just destined to be a nice piece of artwork at this point. Quote Link to comment Share on other sites More sharing options...
CPUWIZ Posted May 2, 2007 Share Posted May 2, 2007 Well an inconvienient truth as to why it's stuck like this is could possibly be ... water damage (waterworld damage?). The box seems in perfect shape without any staining or other problems. The front of the box is not "stuck" to the back of the box (can open it up at the ends and look inside). I don't know if this kind of seal made by water damage (if that's indeed what caused this seal) is fixable using any of the techniques mentioned, but I think it may be just destined to be a nice piece of artwork at this point. I bet you could get it off with hot steam. Quote Link to comment Share on other sites More sharing options...
riffraff Posted May 2, 2007 Author Share Posted May 2, 2007 Hmm I may try that if you think the chances are good I wouldn't damage it. What would you suggest? Get a tea pot or is there a special tool for something like that? Or I could just leave that up to the winner. Quote Link to comment Share on other sites More sharing options...
CPUWIZ Posted May 2, 2007 Share Posted May 2, 2007 Teapot might work. Quote Link to comment Share on other sites More sharing options...
A.J. Franzman Posted May 2, 2007 Share Posted May 2, 2007 Tea kettle would work better. Quote Link to comment Share on other sites More sharing options...
pangasinan Posted May 2, 2007 Share Posted May 2, 2007 Angle grinder might work Quote Link to comment Share on other sites More sharing options...
Atarimania75 Posted May 2, 2007 Share Posted May 2, 2007 Why not a flame thrower that would heat it up nice and quick! Quote Link to comment Share on other sites More sharing options...
holygrailvideogames.com Posted May 2, 2007 Share Posted May 2, 2007 Why did you mount it in the first place? This is one box that would have been worth a lot more had you not done that. Quote Link to comment Share on other sites More sharing options...
Michael_ Posted May 2, 2007 Share Posted May 2, 2007 Why did you mount it in the first place? This is one box that would have been worth a lot more had you not done that. I don´t think it was done on purpose. Why the talk of water damage then? I also get the feeling that it was already stuck to the cardboard when he bought it 11 years ago, but I could be mistaken. Quote Link to comment Share on other sites More sharing options...
krypton85 Posted May 2, 2007 Share Posted May 2, 2007 and im through with the subject..... great item and i will try to win it. so we can see it on ebay a week after this auction ends for more money and outrageous shipping... Quote Link to comment Share on other sites More sharing options...
revsdr Posted May 2, 2007 Share Posted May 2, 2007 dont worry about what i do lil man.. just try to keep up with those coke bottle hater vision glasses you wearin Quote Link to comment Share on other sites More sharing options...
revsdr Posted May 2, 2007 Share Posted May 2, 2007 and keep printing those labels.. Quote Link to comment Share on other sites More sharing options...
kamenes Posted May 2, 2007 Share Posted May 2, 2007 Why is it that every time I read one of Rev's posts, I can't help but imagine him looking like this... I can't imagine I'm too far off the mark. Quote Link to comment Share on other sites More sharing options...
revsdr Posted May 2, 2007 Share Posted May 2, 2007 lmao.... why you posting pics of your mom Quote Link to comment Share on other sites More sharing options...
ItsAtariTime Posted May 2, 2007 Share Posted May 2, 2007 Why is it that every time I read one of Rev's posts, I can't help but imagine him looking like this... I can't imagine I'm too far off the mark. Even this guy is pissed off being compared to Rev.... roflmao :lol: :rolling: :rolling: Quote Link to comment Share on other sites More sharing options...
