Martin72 Posted May 9, 2007 Share Posted May 9, 2007 I have some XEX and EXE files (games). With the Atari800WinPlus i can play this games, but i like to play this games with my Atari 800XL. How can i convert this files to .ATR format so i can use APE to play the games with my Atari computer? Or is there a possibility to load the XEX/EXE direct with APE (with SIO2PC cable)to the Atari? Quote Link to comment Share on other sites More sharing options...
jaybird3rd Posted May 9, 2007 Share Posted May 9, 2007 You can use a feature of APE called "PC Mirror," which lists all the files in a given directory on the PC in a menu screen on the Atari. You would mount the PC Mirror in the first simulated Atari drive, point it to whatever directory your XEX/EXE files are in, boot the Atari, and select the file you want from the list. Quote Link to comment Share on other sites More sharing options...
Beetle Posted May 10, 2007 Share Posted May 10, 2007 Owner of SIO2SD interfaces have it easier: they can boot atari executables direct from SD cards... You can also look for the program "makeATR", which lets you open/create ATR files and then extract files out or add files into it. Greetings Beetle Quote Link to comment Share on other sites More sharing options...
Martin72 Posted May 10, 2007 Author Share Posted May 10, 2007 Thank you for the information, i will try PC mirror of APE and look for 'makeATR'. I found another tool: arc64. It is not easy to use but it works! Quote Link to comment Share on other sites More sharing options...
mimo Posted May 10, 2007 Share Posted May 10, 2007 have you checked out Mathy's website? loads of cool apps there Quote Link to comment Share on other sites More sharing options...
pepax Posted May 10, 2007 Share Posted May 10, 2007 Or you can use R5. Quote Link to comment Share on other sites More sharing options...
