RSS Bot Posted May 19, 2007 Share Posted May 19, 2007 As "punishment" for falling behind on my code, here is a zip containing binaries, screenshots, and source code for Version 0.11 of Action RPG as it stood prior to me adding in bankswitching. I'm aware of inefficient code and excessive - and not always correct - comments. So anyone using the code for their own nefarious purposes keep in mind there are likely more efficient methods and don't always listen to the comments. Except with respect to the nop. It does in fact look darn purdy. The Test Realm source is slightly more advanced than the regular rom, having the test realm's info added to it but also a slightly better recovery on collection detection for when you try to diagonally press against a wall while walking through a room exit. I'll still need to revisit that to get a real fix for the problem added. Got ideas for it so shouldn't be that difficult. And now I'm stepping out for a sub. Attached File(s) action_rpg_v011.zip ( 99.08K ) Number of downloads: 0 http://www.atariage.com/forums/index.php?a...;showentry=3353 Link to comment Share on other sites More sharing options...
