carmel_andrews Posted May 21, 2007 Share Posted May 21, 2007 is there a pc program that will batch convert pc formatted atari exe and com files to xex (i'm guessing the headers are the same) or is it a case of converting them by hand by renaming the extensions, namely exe/com to xex (over 2000 of the blighters) Also, is there a pc program that will convert pc formatted atari 'bin' files (not cartridge format) to either exe or com or xex or atr (i have about 40 files i downloaded eon's ago and they only work using the 'load executable' option on atari800win+ and i want to 'drag and drop' them like you can do for exe/com/xex/atr etc files) Also, is there a 'definative' list of all Atari atr/exe/com/xex etc files on the internet and what configs they best work with on atari800win+ i.e what o/s' s are the files comatible with, are they still copy protected (i.e. won't work with sio patch on) and whether basic should be enabled/disabled etc Quote Link to comment Share on other sites More sharing options...
Rybags Posted May 21, 2007 Share Posted May 21, 2007 File extensions on the Atari don't matter in most cases. A valid EXE or XEX file just has $FF,$FF as it's first two bytes. XEX, COM, EXE are essentially the same internally - and Atari DOSes (at least the simplistic root-only ones) don't store any extra file attributes in the directory entry. So, for that one - easiest way in XP would be to just fire up a CMD window and REN *.EXE *.XEX REN *.COM *.XEX Most commercial games were just bootables, so XEX versions are no-doubt pirated and won't have copy protection. As for config info - all you really have is XL compatible or not, how much RAM it needs, and whether it needs BASIC. Quote Link to comment Share on other sites More sharing options...
