Baconbitz Posted June 1, 2007 Share Posted June 1, 2007 I recently picked up a 5200 at a yardsale and it has two wires in the back and that is is. I don't know what I'm missing and where I can get it. I also was wondering how much it is worth. Quote Link to comment Share on other sites More sharing options...
jboypacman Posted June 1, 2007 Share Posted June 1, 2007 I would check the FAQ in the 5200 section here on the website to see what you need if anything as fars as extra parts go. Its going to depend on what model you have 2-port or 4-port so good luck. Quote Link to comment Share on other sites More sharing options...
SINGLE TOOTH Posted June 1, 2007 Share Posted June 1, 2007 I recently picked up a 5200 at a yardsale and it has two wires in the back and that is is. I don't know what I'm missing and where I can get it. I also was wondering how much it is worth. The 5200 is worth it's size in gold. I don't really know how much they are worth, but you probly got a good deal. How much did u pay? How many Joystick ports do you have in the front of the unit? 2 or 4? What do you mean by having 2 wires coming out the back? There should only be one wire coming out (the RF cable.) Unless that wire is stripped down. Are they bare wires, or do they have connectors on them? The Power cord plugs into the 5200 if it is a 2 port system, or it plugs into the RF Modulator if it is a 4-port system. Quote Link to comment Share on other sites More sharing options...
Baconbitz Posted June 2, 2007 Author Share Posted June 2, 2007 I would check the FAQ in the 5200 section here on the website to see what you need if anything as fars as extra parts go. Its going to depend on what model you have 2-port or 4-port so good luck. 4 ports. Quote Link to comment Share on other sites More sharing options...
Baconbitz Posted June 2, 2007 Author Share Posted June 2, 2007 I recently picked up a 5200 at a yardsale and it has two wires in the back and that is is. I don't know what I'm missing and where I can get it. I also was wondering how much it is worth. The 5200 is worth it's size in gold. I don't really know how much they are worth, but you probly got a good deal. How much did u pay? How many Joystick ports do you have in the front of the unit? 2 or 4? What do you mean by having 2 wires coming out the back? There should only be one wire coming out (the RF cable.) Unless that wire is stripped down. Are they bare wires, or do they have connectors on them? The Power cord plugs into the 5200 if it is a 2 port system, or it plugs into the RF Modulator if it is a 4-port system. Its the 4 port and I payed 5 bucks for it. Its missing peices. Quote Link to comment Share on other sites More sharing options...
ApolloBoy Posted June 2, 2007 Share Posted June 2, 2007 I recently picked up a 5200 at a yardsale and it has two wires in the back and that is is. I don't know what I'm missing and where I can get it. I also was wondering how much it is worth. The 5200 is worth it's size in gold. I don't really know how much they are worth, but you probly got a good deal. How much did u pay? How many Joystick ports do you have in the front of the unit? 2 or 4? What do you mean by having 2 wires coming out the back? There should only be one wire coming out (the RF cable.) Unless that wire is stripped down. Are they bare wires, or do they have connectors on them? The Power cord plugs into the 5200 if it is a 2 port system, or it plugs into the RF Modulator if it is a 4-port system. Its the 4 port and I payed 5 bucks for it. Its missing peices. Missing pieces? As in missing actual parts, or do you just mean the console itself with no hookups or controllers? Quote Link to comment Share on other sites More sharing options...
SINGLE TOOTH Posted June 2, 2007 Share Posted June 2, 2007 I recently picked up a 5200 at a yardsale and it has two wires in the back and that is is. I don't know what I'm missing and where I can get it. I also was wondering how much it is worth. The 5200 is worth it's size in gold. I don't really know how much they are worth, but you probly got a good deal. How much did u pay? How many Joystick ports do you have in the front of the unit? 2 or 4? What do you mean by having 2 wires coming out the back? There should only be one wire coming out (the RF cable.) Unless that wire is stripped down. Are they bare wires, or do they have connectors on them? The Power cord plugs into the 5200 if it is a 2 port system, or it plugs into the RF Modulator if it is a 4-port system. Its the 4 port and I payed 5 bucks for it. Its missing peices. If it is a 4-Port, there should only be one wire that is connected to the unit and cant be removed. (Without taking the case apart). So you have the 4-port system, and that is all you got? No controllers, power adapters...I still dont konw what you mean when you say there is 2 wires comming out of it...Im trying to understand so i can help you out. Quote Link to comment Share on other sites More sharing options...
Baconbitz Posted June 2, 2007 Author Share Posted June 2, 2007 I recently picked up a 5200 at a yardsale and it has two wires in the back and that is is. I don't know what I'm missing and where I can get it. I also was wondering how much it is worth. The 5200 is worth it's size in gold. I don't really know how much they are worth, but you probly got a good deal. How much did u pay? How many Joystick ports do you have in the front of the unit? 2 or 4? What do you mean by having 2 wires coming out the back? There should only be one wire coming out (the RF cable.) Unless that wire is stripped down. Are they bare wires, or do they have connectors on them? The Power cord plugs into the 5200 if it is a 2 port system, or it plugs into the RF Modulator if it is a 4-port system. Its the 4 port and I payed 5 bucks for it. Its missing peices. If it is a 4-Port, there should only be one wire that is connected to the unit and cant be removed. (Without taking the case apart). So you have the 4-port system, and that is all you got? No controllers, power adapters...I still dont konw what you mean when you say there is 2 wires comming out of it...Im trying to understand so i can help you out. My mistake it's 1 port. Quote Link to comment Share on other sites More sharing options...
MIKE5200 Posted June 2, 2007 Share Posted June 2, 2007 I recently picked up a 5200 at a yardsale and it has two wires in the back and that is is. I don't know what I'm missing and where I can get it. I also was wondering how much it is worth. The 5200 is worth it's size in gold. I don't really know how much they are worth, but you probly got a good deal. How much did u pay? How many Joystick ports do you have in the front of the unit? 2 or 4? What do you mean by having 2 wires coming out the back? There should only be one wire coming out (the RF cable.) Unless that wire is stripped down. Are they bare wires, or do they have connectors on them? The Power cord plugs into the 5200 if it is a 2 port system, or it plugs into the RF Modulator if it is a 4-port system. Its the 4 port and I payed 5 bucks for it. Its missing peices. If it is a 4-Port, there should only be one wire that is connected to the unit and cant be removed. (Without taking the case apart). So you have the 4-port system, and that is all you got? No controllers, power adapters...I still dont konw what you mean when you say there is 2 wires comming out of it...Im trying to understand so i can help you out. My mistake it's 1 port. Sorry dude they only came out with 2-port or 4-port. Look at the front again. Quote Link to comment Share on other sites More sharing options...
HammR25 Posted June 3, 2007 Share Posted June 3, 2007 2-port 4-port Quote Link to comment Share on other sites More sharing options...
Baconbitz Posted June 3, 2007 Author Share Posted June 3, 2007 I recently picked up a 5200 at a yardsale and it has two wires in the back and that is is. I don't know what I'm missing and where I can get it. I also was wondering how much it is worth. The 5200 is worth it's size in gold. I don't really know how much they are worth, but you probly got a good deal. How much did u pay? How many Joystick ports do you have in the front of the unit? 2 or 4? What do you mean by having 2 wires coming out the back? There should only be one wire coming out (the RF cable.) Unless that wire is stripped down. Are they bare wires, or do they have connectors on them? The Power cord plugs into the 5200 if it is a 2 port system, or it plugs into the RF Modulator if it is a 4-port system. Its the 4 port and I payed 5 bucks for it. Its missing peices. If it is a 4-Port, there should only be one wire that is connected to the unit and cant be removed. (Without taking the case apart). So you have the 4-port system, and that is all you got? No controllers, power adapters...I still dont konw what you mean when you say there is 2 wires comming out of it...Im trying to understand so i can help you out. My mistake it's 1 port. Sorry dude they only came out with 2-port or 4-port. Look at the front again. 1 port. I meant 1 wire. Quote Link to comment Share on other sites More sharing options...
ApolloBoy Posted June 3, 2007 Share Posted June 3, 2007 OK, but how many controller ports are there? Are there 2 or 4 on the front of it? Quote Link to comment Share on other sites More sharing options...
SINGLE TOOTH Posted June 3, 2007 Share Posted June 3, 2007 Hm... If I didn't know any better, I would say this guy is giving us the business. Quote Link to comment Share on other sites More sharing options...
Baconbitz Posted June 3, 2007 Author Share Posted June 3, 2007 Hm... If I didn't know any better, I would say this guy is giving us the business. http://i29.photobucket.com/albums/c281/dan...Atari5200_1.jpg, http://i29.photobucket.com/albums/c281/dan...Atari5200_2.jpg Thats proof that I'm not giving you the business. I was really tired when I wrote that. Quote Link to comment Share on other sites More sharing options...
MIKE5200 Posted June 4, 2007 Share Posted June 4, 2007 Hm... If I didn't know any better, I would say this guy is giving us the business. http://i29.photobucket.com/albums/c281/dan...Atari5200_1.jpg, http://i29.photobucket.com/albums/c281/dan...Atari5200_2.jpg Thats proof that I'm not giving you the business. I was really tired when I wrote that. Maybe were going the wrong way...Here look at your front of your 5200. There's should be number of ports. Tell us what you see? Quote Link to comment Share on other sites More sharing options...
SINGLE TOOTH Posted June 4, 2007 Share Posted June 4, 2007 Either way, you're missing parts. Quote Link to comment Share on other sites More sharing options...
Atari5200 Posted June 4, 2007 Share Posted June 4, 2007 so he needs the AC adapter and the RF box, boy that was easy. Quote Link to comment Share on other sites More sharing options...
Baconbitz Posted June 4, 2007 Author Share Posted June 4, 2007 (edited) so he needs the AC adapter and the RF box, boy that was easy. Plus the controllers. (Where can I get them?) Also how much with all the peices is it worth? Edited June 4, 2007 by Baconbitz Quote Link to comment Share on other sites More sharing options...
MIKE5200 Posted June 4, 2007 Share Posted June 4, 2007 so he needs the AC adapter and the RF box, boy that was easy. Plus the controllers. (Where can I get them?) Also how much with all the peices is it worth? You know, all you need to do is some searches. but here's one http://www.best-electronics-ca.com/cx52.htm Quote Link to comment Share on other sites More sharing options...
SINGLE TOOTH Posted June 5, 2007 Share Posted June 5, 2007 so he needs the AC adapter and the RF box, boy that was easy. Plus the controllers. (Where can I get them?) Also how much with all the peices is it worth? its worth $5 to me like it is... Are you going to get the parts and then sell it? 5200 stuff is usually pretty expensive. I don't think you would get out what you would have to put in. Quote Link to comment Share on other sites More sharing options...
Atari5200 Posted June 5, 2007 Share Posted June 5, 2007 no, he probably wouldn't make any profit on the system as is without any games. I bought my 5200 off of ebay complete with about 12 games and I only paid $26 after shipping costs. The switch box, ac adapter, and good working controller is probably going to cost him about $35-40$ alone, that being that a rebuilt controller on ebay are around $29 themselves. Quote Link to comment Share on other sites More sharing options...
SINGLE TOOTH Posted June 5, 2007 Share Posted June 5, 2007 no, he probably wouldn't make any profit on the system as is without any games. I bought my 5200 off of ebay complete with about 12 games and I only paid $26 after shipping costs. The switch box, ac adapter, and good working controller is probably going to cost him about $35-40$ alone, that being that a rebuilt controller on ebay are around $29 themselves. That was a nice buy. Quote Link to comment Share on other sites More sharing options...
Atari5200 Posted June 5, 2007 Share Posted June 5, 2007 it's amazing what you can get if you don't care if an auction doesn't have a picture or not. I've got some really good crap really cheap because the items without pictures usually always bid lower than those with pictures. Quote Link to comment Share on other sites More sharing options...
