SINGLE TOOTH Posted June 2, 2007 Share Posted June 2, 2007 I heard from different sources different stories. One is that you can't play pitfall on a 2-port, and the other is you can't play pitfall on a 4-port.... SO WHICH VERSION IS TRUE?!?! I have both versions of 5200s but my rf switch for the 4-port fried. Also, why cant you play pitfall on the one system??? Is it a hardware problem, or a software issue? Someone once said it was a bios issue. If it is, I was considering throwing the 4-port bios into the 2-port system. Quote Link to comment Share on other sites More sharing options...
Atarimania75 Posted June 2, 2007 Share Posted June 2, 2007 (edited) I am not sure but i think there were 2 different versions of Pitfall released for the 5200. One for the 2 port and one for the 4 port system......I think another title that has this issue is K-Razy Shoot Out! Edited June 2, 2007 by Atarimania75 Quote Link to comment Share on other sites More sharing options...
jwierer Posted June 2, 2007 Share Posted June 2, 2007 I heard from different sources different stories. One is that you can't play pitfall on a 2-port, and the other is you can't play pitfall on a 4-port....SO WHICH VERSION IS TRUE?!?! I have both versions of 5200s but my rf switch for the 4-port fried. Also, why cant you play pitfall on the one system??? Is it a hardware problem, or a software issue? Someone once said it was a bios issue. If it is, I was considering throwing the 4-port bios into the 2-port system. See this older thread (http://www.atariage.com/forums/index.php?showtopic=121). This has come up a number of times on the board. -Jeff Quote Link to comment Share on other sites More sharing options...
opeygon Posted June 2, 2007 Share Posted June 2, 2007 I heard from different sources different stories. One is that you can't play pitfall on a 2-port, and the other is you can't play pitfall on a 4-port.... Hmm, wonder why the market video game market crashed backed then... Quote Link to comment Share on other sites More sharing options...
SINGLE TOOTH Posted June 2, 2007 Author Share Posted June 2, 2007 I heard from different sources different stories. One is that you can't play pitfall on a 2-port, and the other is you can't play pitfall on a 4-port....SO WHICH VERSION IS TRUE?!?! I have both versions of 5200s but my rf switch for the 4-port fried. Also, why cant you play pitfall on the one system??? Is it a hardware problem, or a software issue? Someone once said it was a bios issue. If it is, I was considering throwing the 4-port bios into the 2-port system. See this older thread (http://www.atariage.com/forums/index.php?showtopic=121). This has come up a number of times on the board. -Jeff Sorry, didnt see that in the search. Quote Link to comment Share on other sites More sharing options...
