SINGLE TOOTH Posted June 13, 2007 Share Posted June 13, 2007 My 5200 4-port RF switch blew out several years ago. I was using the correct power supply. I was wondering if anyone knows what pin 6 of the IC goes to. If anyone can tell me what Pin 6 goes to, please tell me!!! When the RF switch blew out, it fried the board immediently around the pin, And I cant tell what is supposed to connect there. I would at least attempt to restore this thing. I have adventure II comming soon, and I would like my 5200 back. I went to Radio Ball Sack to do the 5200 power mod, but they did not have the diode the project required. If I order it online, they make you order at least $10 worth of stuff, and I am running low on cash.d I need this thing running one way or another. Here is a pic of the fried modulator. Anyone know what would cause this? Quote Link to comment Share on other sites More sharing options...
Evidious Posted June 14, 2007 Share Posted June 14, 2007 Pins 4,5,6 are soldered together.I would honestly try not to fix it.I have the power mod and I no longer need my RF-Switch.If you want I can send it to and if you want I can send you the diode if you want to try the power mod.I would check the power supply just to make sure that it is woking correctly. -Good Luck Quote Link to comment Share on other sites More sharing options...
SINGLE TOOTH Posted June 14, 2007 Author Share Posted June 14, 2007 Pins 4,5,6 are soldered together.I would honestly try not to fix it.I have the power mod and I no longer need my RF-Switch.If you want I can send it to and if you want I can send you the diode if you want to try the power mod.I would check the power supply just to make sure that it is woking correctly.-Good Luck That would be cool. I would Appreciate that alot. I have checked the power supply with a multimeter, and the power supply checked out o.k. Quote Link to comment Share on other sites More sharing options...
