Urchlay Posted June 27, 2007 Share Posted June 27, 2007 Freddie boards? Is this what the earliest 800XL's had? The Freddie 800XLs came later... from what I understand, the Freddie chip replaces a few of the separate memory-related ICs (address decoders and such). Also, and someone correct me if I'm wrong, the Freddie 800XLs I've read were only made in PAL, not NTSC. Take that with a grain of salt: I might be mis-remembering it, can't even remember where I read that. Quote Link to comment Share on other sites More sharing options...
+kheller2 Posted June 27, 2007 Share Posted June 27, 2007 (edited) Yeah, I heard that too. Some were SECAM. However, Best Electonics Rev 10 catalog shows a "prototype" 128K Freddie NTSC 800XL board. I'm guessing, but don't know, that converting a PAL board to NTSC shouldn't be that hard. So, if anybody out there has a Freddie 800XL and wants to ship it stateside for me to own... let me know http://www.atarimax.com/jindroush.atari.or...ps/freddiei.gif Edited June 27, 2007 by kheller2 Quote Link to comment Share on other sites More sharing options...
Urchlay Posted June 27, 2007 Share Posted June 27, 2007 I'm guessing, but don't know, that converting a PAL board to NTSC shouldn't be that hard. So, if anybody out there has a Freddie 800XL and wants to ship it stateside for me to own... let me know If I had a PAL Atari, I'd leave it PAL... you can use its composite or s-video output with a TV capture card in your PC (all the ones I've ever seen have support for both PAL and NTSC). Not sure if you could use PAL with the RF/CATV input on a US TV capture card, but who uses RF on the Atari anyway, when there's a monitor jack available? A capture card doesn't always give the prettiest display, but it's a lot cheaper/easier than importing a PAL TV (and I've never seen a multi-standard TV here, either). Another possibility: replace the GTIA with an NTSC one, but leave the PAL ANTIC in place. AFAIK, this will give you an NTSC-like signal (as far as the color encoding goes) at 50Hz, which older TVs might sync to if you twiddle the V-hold (I have a TV like this, made in 1976. It can play PAL 2600 games, though with the wrong colors). Quote Link to comment Share on other sites More sharing options...
