Brian R. Posted July 5, 2007 Share Posted July 5, 2007 Remember that two-port 5200 I found in the trash? Well, it cleaned up really nice. It works - to a point. I can't fix it and can't find a way to get it fixed. Does replacing the entire mobo with a new one for $35 make sense? It would be nice to have a working two-port, in case something ever happened to my four-port, or its switchbox. I'm guessing the two-port 5200 will use any RF cable. Since the four-port also carries power, I'm assuming that's a special or unique kind of cable - right? Are the power supplies interchangeable between the two and four ports? Is there any way to tell if something is wrong with a power supply? I'm hesitant about using the one I found in the trash with the two-port. I don't think any of it ever got wet - I saved it in time - just something about using it makes me nervous. Quote Link to comment Share on other sites More sharing options...
Atariman Posted July 5, 2007 Share Posted July 5, 2007 (edited) I'm assuming that you're getting the board from Best Electronics - is that what Bradley suggested? It seems odd that he would recommend replacing the entire board in the 5200 instead of just swapping out a few components. If that's the case, then I'm really not sure - I don't know what 5200s are going for nowadays. Either way, I'd hang onto it - and the old board if you DO replace it EDIT: and as far as I know the power supplies are interchangeable - I wouldn't be too worried about the one you found in the trash. It's probably fine. Edited July 5, 2007 by atariman Quote Link to comment Share on other sites More sharing options...
JB Posted July 5, 2007 Share Posted July 5, 2007 I'm guessing the two-port 5200 will use any RF cable. Since the four-port also carries power, I'm assuming that's a special or unique kind of cable - right? Both use a standard RCA cable, actually. I'd be inclined to bet that the 4-port more or less requires a thicker one like the one it ships with, though. Quote Link to comment Share on other sites More sharing options...
ApolloBoy Posted July 5, 2007 Share Posted July 5, 2007 I'm guessing the two-port 5200 will use any RF cable. Since the four-port also carries power, I'm assuming that's a special or unique kind of cable - right? Both use a standard RCA cable, actually. I'd be inclined to bet that the 4-port more or less requires a thicker one like the one it ships with, though. You'd be right, considering that power goes through the RF cord. Quote Link to comment Share on other sites More sharing options...
Brian R. Posted July 6, 2007 Author Share Posted July 6, 2007 I'm assuming that you're getting the board from Best Electronics - is that what Bradley suggested? It seems odd that he would recommend replacing the entire board in the 5200 instead of just swapping out a few components. If that's the case, then I'm really not sure - I don't know what 5200s are going for nowadays. Either way, I'd hang onto it - and the old board if you DO replace it EDIT: and as far as I know the power supplies are interchangeable - I wouldn't be too worried about the one you found in the trash. It's probably fine. Yeah, it's from Best. I can't determine what's wrong with it or do the work myself, and he said it wouldn't be worth shipping it to him for repair. I think I'll put the order in for it soon, once I decide if there's anything else I want. And yeah, I'd keep the old one. Quote Link to comment Share on other sites More sharing options...
Brian R. Posted July 6, 2007 Author Share Posted July 6, 2007 I'm assuming that you're getting the board from Best Electronics - is that what Bradley suggested? It seems odd that he would recommend replacing the entire board in the 5200 instead of just swapping out a few components. If that's the case, then I'm really not sure - I don't know what 5200s are going for nowadays. Either way, I'd hang onto it - and the old board if you DO replace it EDIT: and as far as I know the power supplies are interchangeable - I wouldn't be too worried about the one you found in the trash. It's probably fine. Yeah, it's from Best. I can't determine what's wrong with it or do the work myself, and he said it wouldn't be worth shipping it to him for repair. I think I'll put the order in for it soon, once I decide if there's anything else I want. And yeah, I'd keep the old one. Has anyone replaced the silver band on top of the console with a new one before? I understand they're self adhesive. If anyone has - After removing an old one, and cleaning up underneath it, does a new one go on OK? Or are there problems with it not sticking, sticking up, etc? Quote Link to comment Share on other sites More sharing options...
