WIZZARD77 Posted July 18, 2007 Share Posted July 18, 2007 My 5200 works fine but when I use the 2600 adapter the games are dark and the colors bleed badly. My brothers system with his 2600 adapter looks great. Is there some sort of adjustment I can do. Its been cleaned and taken care of well. Any help would be appreciated. Thanx Quote Link to comment Share on other sites More sharing options...
Brian R. Posted July 18, 2007 Share Posted July 18, 2007 (edited) My 5200 works fine but when I use the 2600 adapter the games are dark and the colors bleed badly. My brothers system with his 2600 adapter looks great. Is there some sort of adjustment I can do. Its been cleaned and taken care of well. Any help would be appreciated. Thanx You could give Brad at Best Electronics a call. He may be able to help you on the phone, or by email. Dumb question, but your 5200 isn't a four-port is it? The adaptor doesn't work with most four ports, unless it's been modified. I'm not sure what an unmodified four port would do with the 2600 adaptor plugged in. The adaptor works primarily with the two port systems. Edited July 18, 2007 by Brian R. Quote Link to comment Share on other sites More sharing options...
WIZZARD77 Posted July 20, 2007 Author Share Posted July 20, 2007 Its a newer 2 port with the 4 port bios(according to my multicart). I did some checking with my games and some 5200 games are dark as well, mainly greens and greys. Quote Link to comment Share on other sites More sharing options...
WIZZARD77 Posted June 27, 2008 Author Share Posted June 27, 2008 FIXED IT! I used some De-Oxit electrical contact cleaner. That stuff is the best. It cleaned up the video signal and brightened the colors. There is also less video interference. Radio Shack has the stuff check it out it works great. Quote Link to comment Share on other sites More sharing options...
walter_J64bit Posted June 29, 2008 Share Posted June 29, 2008 FIXED IT! I used some De-Oxit electrical contact cleaner. That stuff is the best. It cleaned up the video signal and brightened the colors. There is also less video interference. Radio Shack has the stuff check it out it works great. Cool, I'll have to try this out my 2600 adapter my is doing the same thing! Quote Link to comment Share on other sites More sharing options...
