crash Posted July 27, 2007 Share Posted July 27, 2007 (edited) Greetings, I'm using Easymint with th 1.16 kernel, Xaaes, and Teradesk. I would like to find a way to mount a network share (drive or directory) so that I can open it up in a window on the desktop and do file operations. I've read about a few things, which are limited to command line browsing and file transfers like using the command line version of ftp. This is not what I need. I've successfully mounted a network share on a Windows XP machine using Sharity Light and the following command: shlight //computer/directory /nfs/name -U username -P password The "computer" is my Windows system name The "directory" is the name of the directory set to be shared from the Windows system The "name" is whatever you want to call it on the Atari side, but this must be preceeded by /nfs/ or it will not work The user and password were created on the Windows XP system so I can login to access the share I also had to add a line to my /etc/hosts file, which included the IP address [TAB] then the name of the computer that I was trying to connect to: 192.168.1.5 computer Still, all I can do is go to the TosWin shell on the Atari system and type cd /nfs/name, then dir or ls to show the contents. I'm sure there are commands to copy a file back and forth, but it is much easier to do that with and FTP client. What I want to know, is whether there is any way at all that I can mount a network share as, for example O: MiNT supports NFS, Samba, and Sharity Light, although I can't find any clear information as to how to mount a share so it appears as a device. This is sometimes referred to as a device mount. I just want to open a window in Teradesk (or any desktop) so I can get to work on archiving my software to the server. I have a monumental amount of work to do, and command line would kill me. If anyone has figured this out, please share your advice. Thanks Edited July 28, 2007 by crash Quote Link to comment Share on other sites More sharing options...
danwinslow Posted July 27, 2007 Share Posted July 27, 2007 (edited) Well, SAMBA works well with Linux, at least. I've not tried it on MiNT. The config file for it is iirc smbd.conf or something similar. It's pretty easy. Basically you make a mount point, then tell smbd how to export it, and some config about what users and perissions. Samba has a great deal of usage information on the web, notably starting with http://us3.samba.org/samba/. Samba itself runs as a daemon, and I don't know what MiNT does about those. Edited July 27, 2007 by danwinslow Quote Link to comment Share on other sites More sharing options...
crash Posted July 27, 2007 Author Share Posted July 27, 2007 It turns out that I just needed to go to U:/nfs/Atari and my share was ready to browse I'm using Teradesk, so I made a desktop icon that points to U:/nfs/Atari and now I have easy access to the files on my PC. No more running around with a floppy disk, woohoo! Quote Link to comment Share on other sites More sharing options...
crash Posted July 29, 2007 Author Share Posted July 29, 2007 Okay, after doing some more experimenting, I have found a problem. I have mounted a Windows PC share with Sharity Light, and an Netware server NFS share with NFS, but these are only functioning as read only. I can't determine how to "login" using NFS. With Sharity, I am using the following command: shlight //PC/Downloads /nfs/Downloads -U username -P password (actual usernames and passwords are used) With NFS, I am using the following command mount_nfs -o suid server:/data /nfs/data Any attempt to copy a file to either of these shares results in: Access Denied. Item is protected or it already exists I've made sure that I my user on the PC has appropriate rights to read and write to the PC. I've tried to add user rights for NFS, but I don't see any way to use a username or password with the NFS command. If NFS access is left at anonymous, I can browse and download fine. Ideas? Thanks! Quote Link to comment Share on other sites More sharing options...
krupkaj Posted July 29, 2007 Share Posted July 29, 2007 I am not sure how the Netware server NFS works, but in Linux you have to define rights in /etc/exports file for each line. This is from man page: # example of /etc/exports / master(rw) trusty(rw,no_root_squash) /projects proj*.local.domain(rw) /usr *.local.domain(ro) @trusted(rw) /home/joe pc001(rw,all_squash,anonuid=150,anongid=100) /pub (ro,insecure,all_squash) Quote Link to comment Share on other sites More sharing options...
crash Posted April 21, 2010 Author Share Posted April 21, 2010 I am not sure how the Netware server NFS works, but in Linux you have to define rights in /etc/exports file for each line. It is pretty much the same, with slightly different syntax in the exports file. The web based imanager application makes these changes so I don't edit the exports file directly. I've verified that the host has read/write access, but still get this error. I don't know if this originates from Mint, the NFS module, the server, or Teradesk at this point. I can mount all three of the network shares, browse them, and transfer files to the Mint system without any problem - but I can't copy a single file from the Mint system to the server, which is annoying since this was my objective. Thanks Quote Link to comment Share on other sites More sharing options...
+DarkLord Posted April 21, 2010 Share Posted April 21, 2010 I am not sure how the Netware server NFS works, but in Linux you have to define rights in /etc/exports file for each line. It is pretty much the same, with slightly different syntax in the exports file. The web based imanager application makes these changes so I don't edit the exports file directly. I've verified that the host has read/write access, but still get this error. I don't know if this originates from Mint, the NFS module, the server, or Teradesk at this point. I can mount all three of the network shares, browse them, and transfer files to the Mint system without any problem - but I can't copy a single file from the Mint system to the server, which is annoying since this was my objective. Thanks Personally, I'd take this to the experts on the MINT mailing list. Quote Link to comment Share on other sites More sharing options...
crash Posted April 22, 2010 Author Share Posted April 22, 2010 Thanks for the tip. I wasn't aware that there was one Quote Link to comment Share on other sites More sharing options...
+DarkLord Posted April 22, 2010 Share Posted April 22, 2010 Thanks for the tip. I wasn't aware that there was one Yep, been around for quite some time too - some very knowledgeable people on there. mint@lists.fishpool.fi is an address - hang on a sec... http://sparemint.atariforge.net/mailinglist/Mailing-Lists/MiNT-List.index.html is an archive... and here is where you subscribe I think: http://sparemint.atariforge.net/mailinglist/ HTHs. Quote Link to comment Share on other sites More sharing options...
wongck Posted April 27, 2010 Share Posted April 27, 2010 There's no issues using Sharitylight to write to the shared folder on the PC. I have been doing that often on my Atari & Windoze. Granted that I only share from WinXP and not from Netware. The error you stated, I would get if I forget to give write permissions on the share. As default shares are readonly, it an simple mistake to forget to permit write. But I suppose you shared the folders with correct permissions. The only other thing I can think of is that the password may have failed due to upper case conversion by default. You need put put -C to stop this conversion. However, it seems that you can still access it, so may not be a password problem. My webpage http://phsw.110mb.com/nw-shlight.html says something of this conversion. Quote Link to comment Share on other sites More sharing options...
crash Posted April 28, 2010 Author Share Posted April 28, 2010 I'll be sure to give these another try with Sharity. Since both were failing with the same permission denied for file creation error, I assumed that Mint was incorrectly configured. Thanks to a helpful user on the Mint mailing list, I've learned that I was doing it correctly, but the problem was (and is) with the server. I still don't have NFS working properly, but at least I'm confident that the problem isn't on the client side. The user I'm corresponding with can confirm that NFS does work in Mint. Thanks Quote Link to comment Share on other sites More sharing options...
wongck Posted April 30, 2010 Share Posted April 30, 2010 So must be Netware being the issue ? Have you tried on a Windoze shared folder? Quote Link to comment Share on other sites More sharing options...
leech Posted December 22, 2016 Share Posted December 22, 2016 I realize this is an old post, but my NFS started doing the same thing, any ideas what finally fixed this? It was working for me previously, but I'm betting an update messed with it. Now that Teradesk is giving me this exact same error. Quote Link to comment Share on other sites More sharing options...
