zincmann Posted August 14, 2007 Share Posted August 14, 2007 Any suggestions for cleaning what I think is real but thin aluminum on the 7800 Console and joysticks. I am refurbishing the unit I bought for $20 on ebay and I want to try to clean it up. Was thinking about using a dremel with a buffing bit or maybe a cleaner that is safe for it. Quote Link to comment Share on other sites More sharing options...
gambler172 Posted August 14, 2007 Share Posted August 14, 2007 Hi i use ISOPROPANOL to clean my 7800 system. greetings Walter Quote Link to comment Share on other sites More sharing options...
zincmann Posted August 14, 2007 Author Share Posted August 14, 2007 Thanks for the response, that is Is Propyl Alchohol (rubbing alcohol) correct? and tahst safe to use on Aluminum on the case? Quote Link to comment Share on other sites More sharing options...
gambler172 Posted August 14, 2007 Share Posted August 14, 2007 Hi Yes,this is correct.It is 70% alcohol. greetings Walter Quote Link to comment Share on other sites More sharing options...
zincmann Posted August 14, 2007 Author Share Posted August 14, 2007 HiYes,this is correct.It is 70% alcohol. greetings Walter Walter Thank you! Quote Link to comment Share on other sites More sharing options...
Nabuko78 Posted August 15, 2007 Share Posted August 15, 2007 DANG! >_< I used to have a large bottle of Isopropylic Alcohol at home! Now I can't find it! Thanks for the tip, too. Quote Link to comment Share on other sites More sharing options...
zincmann Posted August 16, 2007 Author Share Posted August 16, 2007 Well I did call best electronics and they dont carry replacement aluminum peices for the Atari 7800. So again if you have an old system you dont use or is busted let me buy those parts from you pleaseeeeeeeeeeeeeeeeeeeeeee Quote Link to comment Share on other sites More sharing options...
gambler172 Posted October 15, 2007 Share Posted October 15, 2007 Hi Guys I found another cheap solution at www.classiclean.net Have a look at his cleaning set;it is really good and not too expensive.And the seller is really fast and very correct. greetings Walter Quote Link to comment Share on other sites More sharing options...
Danno Posted October 16, 2007 Share Posted October 16, 2007 Armor All. Quote Link to comment Share on other sites More sharing options...
mimo Posted October 26, 2007 Share Posted October 26, 2007 or buy this http://cgi.ebay.com/7800-Replacement-Bezel...0QQcmdZViewItem Quote Link to comment Share on other sites More sharing options...
