mimo Posted August 24, 2007 Share Posted August 24, 2007 And do the 2 port boards from Best come with the power connector ready fixed? I want to revive a dead 4 port as simply as possible Many thanks Quote Link to comment Share on other sites More sharing options...
Brian R. Posted August 24, 2007 Share Posted August 24, 2007 (edited) And do the 2 port boards from Best come with the power connector ready fixed?I want to revive a dead 4 port as simply as possible Many thanks I bought a two-port board from them recently for a two-port case. The power connector is on the board as it's supposed to be. No work is needed on it. My guess is if you want to put it into a four-port case, you'll need to open a hole in the case so you can connect the power. The power supply units are the same for either one. Just a difference in where it connects - switchbox for the four port, console for the two port. Best does have four-port boards. But I don't know if they come with the RF/power cord affixed to the board. If it does, you should get the four-port board, I think. If it doesn't, that would mean more work, which is OK if you can do it. Edited August 24, 2007 by Brian R. Quote Link to comment Share on other sites More sharing options...
