Martin72 Posted August 26, 2007 Share Posted August 26, 2007 Today, i had a problem with my Atari 600XL. I want to play a game and the forward direction of the joystick doesn't work. I have immediately repaired the Atari (replacing the PIA 6520) and the joystick works fine. I see there's a difference in the schematic of the 600XL and 800XL. For example: in the 600XL from PA0 (pin 2 of U21) there's a capacitor (1 nF) to connector J6, the joystick connector. In the 800XL i see at the same place a resistor of 220 ohm to the joystick connector with a capacitor of 1nF to ground. Does somebody know why they introduced this difference? And is the solution they aplied to the 600XL is a bad solution? Could it be possible the PIA is dead by this solution? Quote Link to comment Share on other sites More sharing options...
Beetle Posted August 26, 2007 Share Posted August 26, 2007 They did it to save up space inside the stuffed 600XL, and it is of course not a good idea. Any accidental shorting (for example touching the joyport pins with a fingers ring) can result in immediate damage like yours. Anyway, if you use it with care, simple usage with Joystick won't damage anything. Quote Link to comment Share on other sites More sharing options...
Martin72 Posted August 27, 2007 Author Share Posted August 27, 2007 Ok, thank you. I think i will make a modification in the 600xl because i like to use the joystick ports also for other things and it is more safe. Quote Link to comment Share on other sites More sharing options...
