the 5th ghost Posted September 19, 2007 Share Posted September 19, 2007 (edited) Is there any way to bring a dead power supply back to life? I've got one that looks fine cosmetically, but doesn't work. I was going to pitch it. Edited September 19, 2007 by the 5th ghost Quote Link to comment Share on other sites More sharing options...
Brian R. Posted September 19, 2007 Share Posted September 19, 2007 Is there any way to bring a dead power supply back to life? I've got one that looks fine cosmetically, but doesn't work. I'm was going to pitch it. A new one is only $15. http://www.best-electronics-ca.com/power%20guide.htm Quote Link to comment Share on other sites More sharing options...
the 5th ghost Posted September 19, 2007 Author Share Posted September 19, 2007 Is there any way to bring a dead power supply back to life? I've got one that looks fine cosmetically, but doesn't work. I'm was going to pitch it. A new one is only $15. http://www.best-electronics-ca.com/power%20guide.htm Thanks but I wasn't looking for a replacement. I have two working power supplies already. I was just wondering if the broken one was salvageable before I tossed it in the trash. Quote Link to comment Share on other sites More sharing options...
+Mitch Posted September 19, 2007 Share Posted September 19, 2007 It's probably a blown fuse. I've opened several dead 5200 power supplies and it's always the fuse. Depending on whether it is glued shut or has screws may make a difference on if it's worth fixing. The glued ones are a pain to open without destroying it. Mitch Quote Link to comment Share on other sites More sharing options...
the 5th ghost Posted September 19, 2007 Author Share Posted September 19, 2007 It's probably a blown fuse. I've opened several dead 5200 power supplies and it's always the fuse. Depending on whether it is glued shut or has screws may make a difference on if it's worth fixing. The glued ones are a pain to open without destroying it. Mitch Yep, that was my concern as well. It is the glued version. Pitch it? Quote Link to comment Share on other sites More sharing options...
+Mitch Posted September 19, 2007 Share Posted September 19, 2007 It's probably a blown fuse. I've opened several dead 5200 power supplies and it's always the fuse. Depending on whether it is glued shut or has screws may make a difference on if it's worth fixing. The glued ones are a pain to open without destroying it. Mitch Yep, that was my concern as well. It is the glued version. Pitch it? It depends if you want to take the time to carefully crack the glue seal. Mitch Quote Link to comment Share on other sites More sharing options...
the 5th ghost Posted September 20, 2007 Author Share Posted September 20, 2007 I got it apart pretty cleanly using my hammer and a few well placed taps. It doesn't look like anything I am capable of fixing though. I see the fuse, but I'm not sure how to remove or replace it. Quote Link to comment Share on other sites More sharing options...
Artlover Posted September 20, 2007 Share Posted September 20, 2007 So the sealed Atari PS bricks aren't potted then. That's good to know. Quote Link to comment Share on other sites More sharing options...
+Mitch Posted September 20, 2007 Share Posted September 20, 2007 I got it apart pretty cleanly using my hammer and a few well placed taps. It doesn't look like anything I am capable of fixing though. I see the fuse, but I'm not sure how to remove or replace it. The fuse is soldered in, if you have ever done any soldering it should be very easy, if you haven't, well... Ask around maybe one of your friends can do it for you. Mitch Quote Link to comment Share on other sites More sharing options...
SINGLE TOOTH Posted September 21, 2007 Share Posted September 21, 2007 Or else, you can leave the fuse in, and solder new leads on either side of it. THen attach a new fuse on the new leads. Just make sure you secure the new fuse down, so it doesn't rattle around and short something out. Quote Link to comment Share on other sites More sharing options...
